XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > X1 DIY (Do-It-Yourself) Discussions
Register FAQ Calendar Today's Posts
      04-03-2014, 10:11 AM   #1
DNheartsBMW
DNheartsBMW's Avatar
51
Drives: 335is, X3, X1
Bi-Xenon Upgrade/retrofit
I just found an incredible deal on a 2014 X1 28i with X-drive for my commuter car. The only problem is that is does not have the bi-xenon headlamps, and I am very spoiled for good lighting.
1. Is it possible to retrofit the bi-xenon assembly into the car?
2. Other than a dealership, where can I purchase a new OEM assembly with ballast, etc.?
3. Would I be able to do this myself?
Thanks for your help.
      04-04-2014, 01:05 PM   #2
EpistemicConfusion
Likes Cars
56
Drives: X1 xDrive28i
The answer, in its shortest form is
1) No
2) See number 1
3) See number 1
That said - it can, and has been done before.
      04-06-2014, 08:51 AM   #3
DNheartsBMW
51
I just put Osram bulbs into the car as a first step. It's been a long time since I have used halogen lamps and to be honest, I was surprised to see that they work well. The reflectors in the BMW headlight assembly are good plus putting a good bulb in makes the headlamps almost as good as Xenon.
      04-09-2014, 10:22 AM   #4
nillan
23
Drives: 2015 X1 x28i
which osram bulbs
hello,
can you please detail which bulbs you replaced, ie. daytime, h7.. fog
also, can you say what bulbs you chose as replacements.
thanks
nillan
      04-11-2014, 01:04 PM   #5
Trout34
Fly fisher
United Kingdom
20
Drives: XI SE petrol
Just a word of warning for. UK drivers ,I am told that the new MOT will require all Xenon headlights to have headlamp washers ,I do not know if this true or just the manufacturers
way of selling more expensive extras
      04-16-2014, 12:29 PM   #6
DNheartsBMW
51
I purchased the Osram H7 bulbs high and low beams, and did not replace the fogs.
      04-24-2014, 09:42 PM   #7
kurtthewurt
kurtthewurt's Avatar
9
30
Drives: '13 X1 sDrive28i, Mineral Grey
I used Osram Sylvania ZXEs and I am quite impressed by them. I actually made a post about switching them out somewhere in the DIY forum. Sadly, I forgot to take comparison photos.
      08-24-2014, 07:11 AM   #8
LatinBimmer
Peru
135
578
Drives: X5 2014 Sparkling Brown
Of course you can! I did it last year...when even your dealer says "it can't be done"...I googled everywhere and found the solution. I bought my bi-xenon headlamps from a german seller on ebay for around $500 and then I went to my dealer and asked for the list of modules, cables and components required...is my friend, so he gave me and I ordered everything from my dealer (around 1,000 including installation). They work perfect...
Ftp6610.00
      01-21-2015, 04:32 PM   #9
06D
Drives: E84
lightwerkz? I just bought a set off Alibaba, direct swap with base light so far so good
      01-26-2015, 09:33 AM   #10
jiudia
China
11
48
Drives: X1
Definite yes. I would say. My ride is the X1 6MT made in China with halogen headlight. Now it's with Bi-oxen headlight. I have also retrofit a lot of useful things, like cic, cruise, lumber support. Please be patient to see my post. I need to take some pics before i finally send it.
Ftp6610.00
      01-26-2015, 09:34 AM   #11
jiudia
China
11
48
Drives: X1
See my new headlight. Hid.
Ftp6610.00
      03-01-2015, 10:11 PM   #12
Petersonjosh87
Drives: BMW X1
Do you have the instruction on how to do the retrofit? I have a 2014 X11 and purchased a complete set of xenon headlamps. I plugged them in and added some ground wires. When I turn the power on without starting the car they work perfect but then as soon as I start the car the lights shut off after a few seconds.
      03-08-2015, 08:13 PM   #13
spoolinX1
38
133
Drives: X1
06D - Would you happen to have any photos or comments regarding the Alibaba direct swaps for halogens? I got my performance grille from there and it's dead-on. Perfect fit, finish. Quick shipping.
At this point, in strongly considering picking up the headlights. Would love the opinion of someone who actually has them.
      03-17-2015, 12:40 PM   #14
Njerts
126
545
Drives: x3 m40i
Where did you get your lights? Is it somewhere on Alibaba?
      08-26-2015, 08:54 PM   #15
louisli
28
Drives: X1 2011 X25I
hey guys, i am in HK,
my car originally has Xenon light but 2011 style candle light ones,
i bought the new LCI headlight and install,
asking China comapny for remote coding using teamviewer, finally i can make it, now using 2013 onwards style Xenon.
so it can but you need to do a lot of preparation and better searching smart dealer to do it nearby your area. its my advice.
fyi if you just plug and play new xenon, the angel eyes will flash bec different voltage & different electricity input way,,,etc
      08-26-2015, 09:32 PM   #16
Njerts
126
545
Drives: x3 m40i
See the last post in this thread:
http://e84.xbimmers.com/forums/showthread.php?t=1109510
      10-19-2015, 09:56 PM   #17
halfmoonclip
42
336
Drives: X1 28i
A (cheaper than $1k) solution; I put E-code lights, 100w bulbs, and RELAYS to connect them to the power source, rather than running the from the steering column, in an 11 year old Wrangler Jeep. With the upwattage lights and relays, they are darn near as good as the xenons in my X1. For the Bimmer, I'd look for upwattage bulbs, and relays to avoid the power loss between the steering column switch and the bulbs themselves. Works great.
Moon
      10-23-2015, 10:17 AM   #18
Njerts
126
545
Drives: x3 m40i
Moon
I don't think the X1 housings will survive a high wattage bulb.
Now that my housing is out i can already see a dull spot on the reflector, that is after 1 1/2 years with a standard bulb.
All i can say is do it properly or don't do it al all.
      10-23-2015, 10:47 AM   #19
vstolpner
25
673
Drives: 2019 F39 X2 m35i
Has anyone tried high power LEDs? Theoretically they should give you significant increase in light output while maintaining the same power usage and reducing heat (which I'm assuming is the main reason for that dulling of the reflector)
      10-25-2015, 02:25 AM   #20
Njerts
126
545
Drives: x3 m40i
I think LED lights can work. I have seen LED bulbs that allows you to ajust the focus/hotspot. That way you can tune the amount of glare.
That is the theory 😉
      10-27-2015, 10:59 PM   #21
louisli
28
i have done the job few months ago,
changing from old xenon (candle light) into BMW new white bright LCI,
cost roughly:
transformer : use the original one $0
new lights: about $1000
FRM : use original one
installation: $300
coding: $40 (China remote service)
coding is most difficult.... (X_X )
xbimmers
