BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 Marketplace > SPONSORS Classifieds/Groupbuys/Specials Area > Engine | Drivetrain | Exhaust
Mporium BMW
      08-26-2013, 01:43 PM   #1
tom @ eas
BimmerPost Supporting Vendor
tom @ eas's Avatar
8312
18,880
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
▀▄ eas | S65 Rod Bearing Replacement Inspection/Services
Rod bearing inspections have been the subject of concern lately, we would like to announce that are now offering Rod Bearing inspection services for your M3.
This is a serious concern for M3 owners, especially those that have higher mileage or are supercharged/tracked often. For those looking to keep their vehicles for extended use, inspection is a must.
Complete inspection/service is $2395, which includes the following:
Services Performed
- Inspect/Replace Rod Bearings
- Install Upgraded Connecting Rod Bolts
- Inspect Rod Journals
- Inspect Oil Pump nuts
- Inspect Clean/Flush Oil Pan for debris
- Collect Oil Sample for Analysis
- Autologic QuickReport (determines required updates & scheduled maintenance)
- One-on-One inspection report
Items included
- WPC Treated Rod Bearings or BE Bearings
- ARP Connecting Rod Bolts
- OEM BMW Oil Pan Gasket
- Oil Change & Filter Change
- Blackstone Oil Report
Optional Services
- Replace Spark Plugs
- 240E Software Update
WPC Treated Connecting Rod Bearings
WPC is a proven process that has been utilized for many years in the racing and automotive industry. WPC is not a coating, it is a treatment that enhances the surface to reduce friction and strengthen engine parts. WPC achieves this process by firing ultra fine particles towards the surface of a product at very high speeds. The resulting thermal discharge permanently changes the surface, strengthening structure and creating a harder more durable final product.
The WPC process is unrivalled in treating engine parts and other surfaces that have contact points of friction. WPC is superior because it is not a coating; it is a permanent surface treatment that reduces friction while strengthening the part. It's unique micro-dimple formation pattern greatly reduces friction and is unmatched by conventional methods of surface treatment.
The fine grooves, that are intrinsically engraved into the product surface at the time of machining, are transformed into micro-dimple indentations by the impact of the ultra-fine media during WPC treatment. These dimples then act as oil reservoirs. Thus, oil that would normally drain away, through the grooves in an untreated product, when pressure is applied, is instead retained in the dimples of a WPC treated product. This helps to keep the surface lubricated.
Features
- OEM BMW Rod Bearings with WPC Surface Treatment
- Lower Friction
- Harder and More Durable
- Superior Oil Lubrication
BE Bearings
Designed and manufactured by Clevite to BE Bearing specifications.
These bearings replace the factory BMW rod bearings. The original BMW bearings have too little clearance, which leads to premature bearing wear and can cause early engine failure. Furthermore, the factory BMW bearings are made from tin-aluminum which are 5-times harder than a softer lead-copper bearing design. A softer bearing is better for your engine and more tolerant of foreign particles suspended in your oil.
These BE Bearings feature a state-of-the-art Clevite Tri-Metal design with the Clevite Tri-Armor(tm) coating.
Lead-copper design for greater durability and easy tracking with oil analysis like Blackstone (recommended).
- Designed with extra clearance to "fix" the BMW rod bearing design flaw.
- Designed for use with factory 10W60 weight oils.
- Tri-Armor coated for low conditions during cold start
- Ideal for start-stop vehicles
- Standard Size
ARP is the world leader in fastener technology. As builders of the finest fasteners in the market ARP is the choice when you want the highest reliability possible. Our ARP Con Rod Bolt Sets give you a clear advantage over the OEM Con Rod Bolts: unbeatable strength! Even cosmetically, the difference in construction and quality is apparent. If you look at many of the OEM bolts, you will see a taper on the threads which actually takes away bolt grip. ARP Pro Series connecting rod bolts are precision CNC-machined to exacting specifications and designed for optimum reliability. They are designed for full engagement and heat-treated with threads which are rolled to provide up to ten times more fatigue strength than standard OEM BMW fasteners.
For those not local to our facility in Anaheim, CA., transport services are available.
Ordering Details
Phone:
You can reach us directly by calling 866.669.0705 to schedule your service over the phone.
Payment:
Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone)
Other Payments:
Money Order/Cashier’s Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods.
Tax:
All CA customers will be charged 7.75% CA Sales tax.
Shipping:
All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees.
Hours of Operations:
Monday - Friday from 9AM to 5PM PST
Saturday/Sunday - Closed
Retail Location/ Installation Center:
Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell.
Contact Info:
Phone: 866.669.0705
Email: tom@europeanautosource.com
Website: http://www.europeanautosource.com
Feel free to contact myself or any of our sales staff via email or phone if you have any questions.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      08-26-2013, 01:44 PM   #2
tom @ eas
tom @ eas's Avatar
8312
18,880
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Vehicle: 2008 BMW M3, 6MT
Production Date: 06/08
Oil Used: TWS Motorsport 10W-60, 7500mi intervals
Mileage: 106,XXX mi
Fuel: 93 Oct
Driving Habits: Mostly highway driving, no track use
Oil Analysis: None provided
Notes:
This particular M3 was fully serviced under scheduled maintenance and meticulously followed thereafter with oil changes every 7500mi.
The VF540 Supercharger was installed at 92K. Now at 106K, a VF620 Supercharger upgrade was scheduled. After some discussion, it was agreed that an inspection of the rod bearings was in order during service.
Connecting Rod Bearings, showing excessive wear on #4 & #8
Closeup, Rod Bearing #8
New vs Old Rod Bearing - Comparison
As seen, Connecting Rod bearing #8 suffered the most damage, with all remaining bearings showing considerable wear. Needless to say, prolonging this would have likely resulted in engine failure if not handled sooner.
      08-26-2013, 03:28 PM   #3
SYZ
SYZ's Avatar
34
454
Drives: :O
Is your shop able to complete this job in one day?
      08-26-2013, 04:06 PM   #4
DLSJ5
DLSJ5's Avatar
504
4,033
Drives: 2016 F82 M4 ZCP
Excellent price, EAS is a company I would trust if I ever needed this done. Good stuff guys.
16 F82 M4 DCT - ZCP - JB4 - 556WHP / 570WTQ
08 E92 M3 DCT - Bolt Ons - 60-130MPH 10.71s - 11.88 @ 118MPH - 377WHP
ESS VT2-625 SC 60-130MPH 6.80s - 11.30 @ 129.3 MPH 586WHP / 379WTQ
ESS VT3-750 - 60-130MPH 6.14s - 10.81 @ 135.13 MPH 690WHP/463WTQ
Shift-S3ctor E92 M3 - 1/2 Mile Trap Speed WR - 174.13 MPH
      08-26-2013, 08:23 PM   #5
aus
894
9,034
Drives: Odysse
Would it be cheaper to do without the VAC bearings?
Great service guys.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
      08-26-2013, 09:49 PM   #6
SHADY1
Hamann M3 Fan
SHADY1's Avatar
298
2,885
Drives: E92 M3 & F10 M5
2013 BMW M5  [0.00]
2008 E92 M3 Coupe  [8.14]
Talking EAS did a excellent job on my 2008 100K + mile E92 M3
I am glad I had EAS do my rod bearings, I drove from Central Texas to SoCal to have my rod bearings changed by EAS. The pics you all are looking at are from my E92 M3 as you can see I was riding on borrowed time. I highly recommend EAS if you need your rod bearings replace. I am back home in Texas I drove 1500+ miles back home after my rod bearing replacement
JZB,6MT, My mods 360 Forged 20inch wheels,VF650 Supercharger custom tuned,ARH Long Tube Headers,Hamann CF roof spoiler,H&R springs,CF grills,Hamann rear trunk spoiler,Hamann Side Skirts, ARKYM full CF bumper, Gintani Race exhaust, ARH X-pipe catless,RPI scoops,AA SSK, Arkym CF Double Sided Vented Hood,
      08-26-2013, 09:51 PM   #7
4corners
4corners's Avatar
391
1,133
Drives: 2008 Jet Black M3 Coupe
I want to see every single one you take apart to see the good and bad. Not just the bad. Then maybe I'll consider it. Do it right with analysis.
      08-26-2013, 10:07 PM   #8
regular guy
427
1,947
Drives: Sprint car
Very glad you dodged this bullet. Props to EAS for offering this service.
      08-27-2013, 01:35 PM   #9
tom @ eas
tom @ eas's Avatar
8312
18,880
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
This is a job that cannot be rushed. With the amount of items being covered, 2-3 days is best.
Great service guys.
Difference is only $95 between the OEM and VAC bearings.
There are plenty of examples to reference with a quick forum search, we'll do our best to provide samples of our own.
Appreciate the feedback guys, thanks!
      08-27-2013, 01:57 PM   #10
4corners
4corners's Avatar
391
1,133
Examples of failures are well documented. Agreed. As you proceed, if an engine is dismantled and the bearings are ok, I want to see that too. Along with the build date of the car, the part numbers used, mileage, and other notable factors. Then we can all make informed choices instead of knee jerk decisions based on ticking time bomb rhetoric. Just saying.
      08-27-2013, 08:32 PM   #11
REP1KRR
My other car is a Scooter'ia
REP1KRR's Avatar
87
1,303
Drives: M3 Saloon
Also interested in seeing other bearing samples. It would be very helpful in making a decision to replace.
A91 Edition Supra | Armytrix | Rays
M3 Saloon | Akrapovic EVO | B&G Sport
M3 Saloon | VF540 | Klässen ID M52-R | Akrapovic | Vorsteiner GTS5 | KarbonWerke CSL [SOLD]
      08-29-2013, 11:35 PM   #12
Top_Gear
90
Drives: M3-E90-6MT
I am worried about this problem as well but before I spend the 2+ I would first like to see at least one car whose rod bearings were pulled, inspected, photographed, and determined that they did NOT need to be replaced.
Other than when they are brand spanking new, we just don't know what these bearings should look like as you accumulate the miles.
      10-19-2013, 04:38 AM   #13
MFKN3
MFKN3's Avatar
Australia
127
2,224
Drives: supercharged 4.4L stroker E92
Good work Tom. Just curious if you pull the engine for this and also whether this requires vanos to be dismantled and re-assembled? Does the bearing replacement fix the problem, or is it still an ongoing concern that needs to be addressed every X miles?
Is it only a large concern for 2007/2008 models and why are BMW NA ignoring what is essentially an engine defect?
      10-19-2013, 01:37 PM   #14
REP1KRR
REP1KRR's Avatar
87
1,303
Drives: M3 Saloon
I'd like to see more examples. Surely you've performed this service more than just this once Tom?
      10-20-2013, 04:33 PM   #15
jphughan
jphughan's Avatar
594
4,488
Drives: '16 Cayman GT4
This. I mentioned this in the Official S65 Bearing Specification/Clearance Wiki thread, but right now IMHO it's unclear whether this is a widespread problem or a bunch of FUD, and I think that's mostly because, like many other issues we discuss on these boards, information is heavily negatively biased, which isn't conducive to making informed decisions. It would be immensely helpful if vendors like Tom@EAS and others who perform several bearing inspections on our cars would comment on what percentage of cars have bearings that look just fine, along with other information like model year, mileage, operating climate, driver habits, modification status, and oil change intervals to help identify trends where problems are occurring. I understand that if the answer is that a fair number of cars have bearings that look fine, that would be bad for business, but it would sure go a long way toward either reducing the FUD or supporting the argument that owners intending to keep their cars long-term should consider this.
And with respect to this bearing issue specifically, I have yet to see photographic proof that any of the proposed solutions (thinner oil, WPC-treated bearings, or the VAC coated bearings suggested here) actually result in reduced or eliminated bearing wear. Has anybody who had bearing problems, especially after relatively low mileage, and implemented one of these solutions gone back and rechecked them after the same number of miles to determine whether their solutions are actually providing any benefit?
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten:
'11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015)
      10-21-2013, 02:04 PM   #16
tom @ eas
tom @ eas's Avatar
8312
18,880
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
You probably wont, for some time at least. Not many people will be tearing engines apart a second time to inspect as the miles simply have been racked up yet.
Engine remains in the vehicle, the subframe is lowered in order to allow the oil pan to be removed and access the rods. There isn't a specific mileage that can be given, but getting regular oil analysis reports would be a good start in creating a paper trail - while not breaking the bank in the process.
Absolutely. Here's a photo and oil analysis Bearings from a low mileage 2011 M3, at 18,xxx mi. Here's a copy of the last Blackstone report:
reference:
Bearings were replaced with VAC coated rod bearings/APR bolts and oil switched to Torco 10W40 SR-1R Synthetic Racing Oil, as this M3 will see regular track use with the supercharger.
After some miles, we'll have oil changed and analysis performed on next oil change.
Any questions, please feel free to call, PM or email me directly.
      10-30-2013, 11:30 AM   #17
tom @ eas
tom @ eas's Avatar
8312
18,880
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Feel free to contact us if you should have any questions on service.
      11-24-2013, 01:57 PM   #18
xchosun1x
Track Duty
xchosun1x's Avatar
270
2,467
Drives: Track build 08 E92 M3 DCT
what other parts or items do you usually find needing replacing during this inspection? other than the bearing and rod bolts themselves...
also i'm curious, do you offer any sort of warrant with the service, parts, usage etc etc?
thanks
      11-25-2013, 11:27 AM   #19
tom @ eas
tom @ eas's Avatar
8312
18,880
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
thanks
Luckily, nothing yet, we've done a few of these and are about to attack the track car next week to prepare for 2014 race season. All work is warrantied, parts carry their own manufacturer's warranties.
It's essential the other areas are inspected. Even if it sounds a bit overzealous - just to make sure there are no other issues that could arise later, which could have been prevented.
      12-19-2013, 12:11 PM   #20
tom @ eas
tom @ eas's Avatar
8312
18,880
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
WPC Red/Blue treated bearings, all ready for the race build:
Race build in current (stripped) form:
      04-02-2014, 01:08 PM   #21
tom @ eas
tom @ eas's Avatar
8312
18,880
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
2008 BMW M3: 53,XXX mi
Info
Production Date: 05/08
Mileage: 53,XXX mi
Fuel: 91 Oct
Driving Habits: Mostly highway/street driving, no track use
Notes:
Here's a recent inspection on a 2008 M3 with ~53K that came in. When engine was warm, a "knock" was heard at 3500+ RPM. Upon inspection of #5 journal, the bearings were discovered to be in terrible condition:
Crank also shows severe damage, engine will need to be pulled and crank/bearings replaced. With this much damage on the journal, there's really no need to inspect the others. Higher resolution photos can be found here on our Flickr page.
Engine is relatively stock other than aftermarket exhaust, vehicle has never been tracked. An oil sample has been sent simply to see what numbers are present in this type of situation.
Engine approved for replacement under goodwill from BMW: http://www.m3post.com/forums/showthread.php?p=15421814
      04-30-2014, 12:31 PM   #22
tom @ eas
tom @ eas's Avatar
8312
18,880
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Thanks for the inquiries - all PMs replied.
Tags
bearing, eas, journal, rod bearings
m3post
