03-05-2013, 06:48 PM | #1 |
Rep 38
Sonar(Spyder) vs. Depo Headlight Quality
I am looking to pull the trigger on upgrading the halogens from my 128i soon. I prefer the look of the Sonar as they do not have the "bug eye" look of the Depo headlights. I think it is because the projector bulb on the Depo's is in front of the the housing. However I see on this forum that most people strongly prefer the Depo's. Any comments on the quality of the Sonar(spyder)? Thanks in advance for the responses.
03-05-2013, 08:29 PM | #2 | |
166
Rep 2,926
Check out my thread http://www.1addicts.com/forums/showthread.php?t=809467
03-06-2013, 01:05 PM | #3 |
Rep 55
I actually went for the SONARs. It really depends on preference as I preferred the corners of the Sonars because it looked more like the facelifted E90 LCI headlights. And no bug eyed look on the projectors. The build quality of the Sonars seem decent. The extra wires can be annoying but you increase your flexibility on how you want to wire them. Other than the wires for the Halos, everything else is pretty much plug and play.
Keep in mind that with both headlights, you're going to need to upgrade the Halo rings if you want that bring SMD LED look like Satalite's in his other thread. Although I think the DEPO V2's already come with the upgraded LEDs but I don't think anyone here has bought those yet. Had I waited a bit more, I would have jumped on the DEPO V2's so I wouldn't have to spend extra to get the LED HALOs upgraded. Last edited by Ashock; 03-06-2013 at 01:14 PM.. |
03-06-2013, 03:20 PM | #4 |
Rep 38
Ashock, thanks for the great info. The Depo V2's do look nice. How bad are the halo rings on the Sonars? I don't need for them to blind people but just enough so they get the point. How is the build quality / fit? Any condensation? Thanks very much.
03-06-2013, 05:15 PM | #5 | |
Rep 55
Check out this member's install. He kept the original rights. I think the AEs gets the point across in most cases. http://www.1addicts.com/forums/showthread.php?t=725428 |
