      01-03-2010, 01:43 PM   #1
Diokaef
Engineer
Diokaef's Avatar
216
2,122
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
DIY keyless Comfort access for Z4
Everything start like a push start button but now I end up going a bit far. see the page 3 of this post http://www.zpost.com/forums/showthread.php?t=89369 and I will Finnish some extra tests and post some videos here soon.
Thank you for the guys that had the first ideas.
      01-03-2010, 01:48 PM   #2
Diokaef
Engineer
Diokaef's Avatar
216
2,122
Thumbs up This is the heart of the system!
so it need some small work on it and be installed on the car but the test proves that works, just waiting to get my car back in a few days to install it
      01-03-2010, 01:56 PM   #3
Diokaef
Engineer
Diokaef's Avatar
216
2,122
how it works?
When you get in the car with the key remote in your pocket you can press the start/shut off button and the car will turn on the ignition and start after you press clutch. when you want to stop the car just press the same button again and the engine will shut off and after 30 sec the windows will roll-up. that is it, look your car with the remote and the car will active the alarm if you have one.
also I found how to use the e90 button.
      01-03-2010, 01:58 PM   #4
Diokaef
Engineer
Diokaef's Avatar
216
2,122
I'm working to make sure that will be plug and play no wires cut.
      01-03-2010, 02:10 PM   #5
O-cha
O-cha's Avatar
218
4,726
Drives: Mcoupe
Not labeled well enough to make sense...
      01-03-2010, 02:11 PM   #6
Diokaef
Engineer
Diokaef's Avatar
216
2,122
help
My English is not of the best so can you help me out??
      01-03-2010, 02:16 PM   #7
Diokaef
Engineer
Diokaef's Avatar
216
2,122
Confort access is the name of the OEM system on the 3 Series. any suggestion ?
      01-03-2010, 02:23 PM   #8
O-cha
O-cha's Avatar
218
4,726
Drives: Mcoupe
Comfort access is the name of the keyless entry system, like no keys at all leave in pocket.
What you are suggesting makes no sense to me, which is weird since it was my suggestion.
You say you don't need the key to start the car but that's impossible, you HAVE to have the key in the ignition and communicating in order to get release for the car to be started.
I don't know what test you preformed that shows you don't need the key, but keep in mind the starter turning over does NOT mean you can start the car, you can get the starter to turn over but the car is not going to ACTUALLY start without the key in.
      01-03-2010, 02:45 PM   #9
Diokaef
Engineer
Diokaef's Avatar
216
2,122
yes you gave me the idea, you will still need for the blade to be install on the glove box, so if you are going to a place that you really don't fell comfortable or you will leave the car overnight you can complete disable the system.
      01-03-2010, 03:00 PM   #10
O-cha
O-cha's Avatar
218
4,726
Drives: Mcoupe
You lost me.
What I was suggesting would use some sort of remote transmitter device, I don't see that anywhere in your diagram.
      01-03-2010, 03:38 PM   #11
Diokaef
Engineer
Diokaef's Avatar
216
2,122
I said you just gave me the idea, so I completed, my idea was to use the RIFID of my keys to complete the process.
when you get in the car the remote will sen a 315mhz RF signal to the car and the car will repeat the signal and if they match, the car will unable the ECU to receive input from ignition. so when you press the button, the car will start and if you press again it will turn off. my diagram only explains how it does. the momentary signal of the button will trigger the first 2 relays that will power ignition after that the constant current for relay 3 will be closed and the car will send a one pulse for about 1sec. to the starter to start engine. ignition power will be on until the sequence is triggered again, so if you press the button again the 4th relay will cut the power of relay 2 what causes the ignition to go off turning the car off, when relay 2 is off relay PCB will change status and send a continue signal to the roll up module what will close the windows if they are open.
I'm also working on get the signal from the key to unlock the door if you touch the door.
      01-03-2010, 03:57 PM   #12
O-cha
O-cha's Avatar
218
4,726
Drives: Mcoupe
Wait really? are you SURE of that? I always thought the signal was sent through the key blade itself.
If that is true then it is more then possible to do a real push button start, in fact it will be relatively easy.
Can you detail your diagram a little better, I don't understand why it is so complicated then.
How are you handling ignition 2 activating/deactivating? I assume you are laving the blade only in the ignition on ignition 2, but then ignition 2 would remain on forever.
Can you also label the button contacts? I don't understand why there are 6.
      01-04-2010, 05:40 AM   #13
Diokaef
Engineer
Diokaef's Avatar
216
2,122
You can test for yourself, open the key take the remote out and put in your pocket, take the blade and start the car.
It is complicated to bypass ignition 2, so if you press the button again will not damage your starter, will only kill the ignition 2 just like if you had turned your key. took me 24h of dedicated work to bypass that crap. now you only will take your key off if you want to use it as a kill switch.
Also after completed this diagram I was able to create an open circuit to do the same to the open closing doors+cheap alarm system that will be better then one very expensive + a roll up windows system automatically.
I'm working on this ones right now, so after I'm done with it I will post a complete diagram setup plus a video step by step of how to build it.
The only thing that I may not be able to do very soon will be install on the car because require lot of time, but in my video I will prove how the system works and show you guys how to test it before you put in your car so no one will end up with a big bill trying to fix damages of wrong setup. the system after complete will be plug and play, no cutting wires required. and also I will include an extra diagram of a 4 combination code kill switch for extra security. all DIY and step by step.
The system will include push to start and push to turn off engine with one button only + keyless open/close door + auto roll up windons after ignition is turned off + 4 combination kill switch code. also wire diagram for BMW's plug and play no wire cut. and how to install an aftermarket alarm on this system.
Please keep posting your questions because that unable me to make it better.
      01-04-2010, 08:53 AM   #14
GLF
GLF's Avatar
44
Drives: Z4, 3.0si SILVER
I keep watching, for the answer to the question. WHAT ABOUT THE MECHINCAL LOCK AT THE STEERING WHEEL THAT REQUIRES THE KEY???
ALWAYS GO TOPLESS
      01-04-2010, 10:05 AM   #15
Diokaef
Engineer
Diokaef's Avatar
216
2,122
Mechanical look
My does not have one . I took off because is useless.
But I can give you 4 different ways that you can do something about that if you want to keep yours.
Really not a Big..
      01-05-2010, 02:44 AM   #16
Diokaef
Engineer
Diokaef's Avatar
216
2,122
okay I need an input.
does anyone knows how to amplify, duplicate or receive and transmit signals from a rf design??
I discovered that not all z4 have a antenna for the coil that recognize the keys and that would require to move the receiver of rf signals from the steering wheels to the seat, to not need to put the key on ignition(remote only) but I want to have a receiver/transmitter on the seat so I don't have to move that.
anyone?
      01-06-2010, 12:18 AM   #17
Diokaef
Engineer
Diokaef's Avatar
216
2,122
http://www.the12volt.com/relays/page5.asp
http://files.thehoffmangroup.com/ins...letButtons.pdf
above are the links that you guys can use to check how this works.
I'm thinking if is reliable do to it because of the costs and time to do it, and because I found this one http://www.digitalguarddog.com/mm5/m...ry_Code=a20000
      01-06-2010, 10:53 PM   #18
Z4Kevo
Z4Kevo's Avatar
85
168
Drives: 2007 M Coupe
this kind of reminds me of an ultrastart 2250 i installed on my last car...put the valet key in a transponder bypass unit that pulsed during the start sequence to make sure the RFID signal was present for the ignition. Seems you could install pretty much the same type starter system for this application only it would operate with a start button instead of the handheld transmitter.
watching with interest...
2007 BMW Z4M Coupe | Sapphire Black | 19" ZCP Wheels | Michelin PSS - 245/285 | Carbon Leather
Black Corners | UUC Short Shifter | ///M Racing Pedals | OE Strut Brace | LED Accents | PEMP Android
      01-07-2010, 12:10 AM   #19
Diokaef
Engineer
Diokaef's Avatar
216
2,122
Yes almost same concept.
      01-09-2010, 02:01 AM   #20
Diokaef
Engineer
Diokaef's Avatar
216
2,122
Do you guys think I should keep going on this? do you guys think it is reliable? had anyone checked on the link that I posted??
      01-09-2010, 02:16 AM   #21
Diokaef
Engineer
Diokaef's Avatar
216
2,122
Anyone with access to a good place to buy electronic components? here I just found crap and I don't want to use crap stuff in my car,
Another thing the ignition switch I priced at 97$ at BMW
and the other end cost 10$ if you guys don't want to cut any cables.
the billet button will cost 100$ for the 22mm with shipping,
      01-09-2010, 09:41 AM   #22
GLF
GLF's Avatar
44
Here is where I found my button. http://www.alliedelec.com/switches-r...493+4294818361
I am sure you will find whatever you need at this site.
I am following your thread but it doesn't make sense yet.
ALWAYS GO TOPLESS
