12-04-2009, 10:43 AM | #1 |
104
Rep 2,474
Warped clutch, how?
Pops and I took the porsche out for a 45 minute ride. started getting sloppy about half way through. Turns out clutch is warped due to overheating. Now my questions is if it is possible to overheat a clutch within 30 minutes of street driving or is it most likely that there was an underlying issue beforehand. It was the original clutch on the car, so I am assuming the clutch has been worn over the years as it has been tracked and auto-x'd and resulting in a weaker clutch at the point of failure. Is it possible?
AW 135i w/ blackette, performance short shift kit, BMW alarm, Performance rotors, APEX ARC-8 wheels, Direzza Star Spec 235/275, Dinan stage 3 suspension, M3 wishbones/tension rods/front sway/rear subframe bushings and thats all folks! |
12-04-2009, 11:02 AM | #2 |
winter mode
62
Rep 2,057
Drives: 08 135i, 88 M3
is it technically possible to overheat a clutch in 30 mins of driving? definitely, but you'd need to be trying to do it. i'm sure it's some preexisting thing. the owner probably drove like a doosh...or had no feeling in his left foot
88 M3: BMWCCA J Sport
08 135: because streetcar |
12-04-2009, 11:09 AM | #3 |
Change for a Nickle?
14
Rep 875
This is your dad's car, not one he is looking at buying, right? If so, and 1 just called your dad a douche
"I tasted death many times on the river today. Do you want to know what it tasted like? Do you REALLY want to know? Well I'll tell you then: it tasted like BEEF JERKY." - unknown paddler 8/1/09
12-04-2009, 11:58 AM | #4 |
winter mode
62
Rep 2,057
woops...
12-04-2009, 12:11 PM | #5 |
104
Rep 2,474
Its my dads car. My dad has only had it for about 12,000 miles
12-04-2009, 12:13 PM | #6 |
104
Rep 2,474
My dad has no feeling in his feet either thanks to MS so you might be right, lol. don't feel bad though for saying that, you had no idea. I was driving at the time of failure anyways.
12-04-2009, 12:26 PM | #7 |
2148
Rep 10,176
Andy, on P-Cars it can be fairly common to have them warp if replacement is overdue. Take-up on a new Porsche clutch is usually immediately off the floor. If it was easy to use (read: take-up was nice and gradual, more like most cars), it was likely worn and due for replacement.
I spent last weekend under the 'ti replacing the clutch and flywheel (lemme tell ya, BMW should be shot for the difficulty of clutch master cylinder replacement). I did the master and slave cylinders at the same time. |
12-04-2009, 12:45 PM | #8 |
104
Rep 2,474
Ok, just got the verdict:
"Charles called, the clutch plate disintegrated with age, you just happened to be the lucky one. He said it was the original clutch. Tranny and flywheel okay. Your mother is really thrilled."
12-04-2009, 12:48 PM | #9 | |
104
Rep 2,474
12-04-2009, 12:49 PM | #10 | |
14
Rep 875
Andy, on your dad's car, is the clutch slipping or are you just getting excessive vibration? If it is not slipping, it may actually be an issue with the clutch disc hub. Unlike the rest of the motoring world, Porsche used rubber dampers in the clutch hub instead of springs. When the rubber goes, there's nothing left to absorb any shock in the driveline and it feels just like an excessively warped flywheel or pressure plate. Either way, the clutch has to be replaced. I would suggest getting a sprung clutch disc instead to the rubber mounted OEM disc. Ok, just saw your "verdict" post.
12-04-2009, 01:09 PM | #11 |
2148
Rep 10,176
Yep, and to disconnect the hydraulic lines you cannot see what you are doing, and generally need opossum sized hands. My ribs are still tender from laying on the seat rail sideways.
Andy, glad you got it diagnosed already. (and glad I know nothing about Porsche clutch replacement) |
12-04-2009, 01:35 PM | #12 | |
104
Rep 2,474
12-04-2009, 02:09 PM | #13 | |
winter mode
62
Rep 2,057
i'm sorry about the comment...thanks for being cool about it
12-04-2009, 02:14 PM | #14 | |
14
Rep 875
Of course he's being cool about it. He already told his dad. I'd be wary of the first post from arrutleds_dad....
12-04-2009, 02:33 PM | #15 |
2148
Rep 10,176
12-04-2009, 02:37 PM | #16 |
104
Rep 2,474
Ha, I did tell him about the comment. He got a good laugh out of it. We joke about his feet a lot. Its twisted, I know.
