      05-16-2009, 01:54 PM   #1
mivec4g
Drives: 4g
lowering springs installation
I saw someone post that they did however there were no step by step on how to. chuck has some info, I was thinking maybe we can put one here for future reference.
thanks
      05-18-2009, 07:41 PM   #2
mivec4g
Drives: 4g
chris, is it ok if I post here what you emailed me along with the email you got from chuck for future reference for other members who are planning to put it some springs?
      06-02-2009, 12:25 AM   #3
Matty C
Matty C's Avatar
Germany
20
324
Drives: 2007 Z4 M Roadster, 2006 M3
Please put it up as I have a set of H&R Springs sitting here and was planning to install tem this weekend. Thanks in advance!
      06-04-2009, 10:28 PM   #4
DirtBag335
DirtBag335's Avatar
15
283
Drives: 07 Z4M
Troll from the mitsubishi forums?
      06-05-2009, 08:27 PM   #5
Zed4M26
Zed4M26's Avatar
31
208
Drives: 2007 M Coupe
Of course, please post and share with the others
BONE STOCK
      06-07-2009, 03:18 PM   #6
wasupdu
wasupdu's Avatar
25
413
Drives: Z4 3.0, CLS63 AMG
I'd love to see a how-to for spring install. I've contemplated this on both my e60 and e85 but I don't have the guts to attempt it yet. I know I'll need to take it to a shop to have the alignment done, but I'd love to actually be able to do the install.
2005 BMW Z4 Roadster 3.0 - Black Sapphire with Red Extended Leather / NAV / Premium & Sport Pkgs / 19" wheels / M steering wheel / Xenon
2013 Mercedes CLS63 AMG
      06-08-2009, 08:33 PM   #7
Chuck I
Chuck I's Avatar
20
259
Drives: '03 Z4 + '07 ///M Roadster
OK with me...
You can certainly post what I sent you... hopefully it will help someone... Chuck I
      06-10-2009, 12:29 PM   #8
Z4MCJJ
Z4MCJJ's Avatar
448
Drives: Z4MC
Funny thing...not really but....
I had Dinan springs that I placed a couple months ago. I used Loctite red....big mistake...my bolts were almost welded to the steering knuckle.
I snapped the lower knuckle bolt off and had to drill it out when I placed my TC Kline D/As...I recommend going with loctie blue FWIW.
      01-26-2010, 06:05 AM   #9
dfine
Z
Belgium
65
Drives: Z4
Hope this DIY is posted, planning on installing lowering springs...
• What we Z in life, echoes in eternity •
      01-27-2010, 01:29 AM   #10
BimmerZealot
61
1,210
Drives: 2019 BMW X3 xDrive30i
Springs are pretty straight forward. Removed the wheel, remove all the bolts from the arm, sway bars, etc. that attach to the coil. Remove the 3 engine bay nuts, pull out the entire spring/strut combo (front). Use a spring compressor and then unbolt the top hat, replace spring, replace top hat, replace strut.
Rears: Remove wheel, release e-brake, unbolt shock, step on the control arm and pull out the spring, make sure to put upper/lower rubber grommets back onto new spring in same orientation, again step on arm to get spring in then release.
I dont have pictures, bolts sizes or anything but its quite simple. Coilovers would be even simpler because you just replace the whole strut, only thing with coils is the rears will take probably 2 or 3 times longer then the front because you have to unbolt the OEM rear shock, which is a pain to get to.
      06-24-2014, 01:49 PM   #11
bjbstewart
bjbstewart's Avatar
9
370
Drives: 2007 BMW Z4MC
I searched on "lowering spring installation" and found this from 2010. I didn't see anything else that documented the process. Have some new springs that I want to put on - can anyone point to a DIY guide? Appreciate the help!!
[SIGPIC][/SIGPIC]
      06-24-2014, 02:38 PM   #12
Jroc
13
415
Drives: Mcoupe
You should be able to use any coilover DIY.
Less steps in the rear.
More steps up front(Slightly)
07 TiAG Coupe
@Jroc561
      06-24-2014, 03:28 PM   #13
bjbstewart
bjbstewart's Avatar
9
370
Yeah, but I know there will be some "gotchas" along the way. Would sure like to make sure I avoid those while installing...
[SIGPIC][/SIGPIC]
      06-24-2014, 04:08 PM   #14
Javizquierdo
13
39
Drives: BMW Z4 2.0 2008
I can show you my DIY in 2.0 but it's in Spanish
http://www.roadstersportclub.com/for...p?topic=3092.0
      06-24-2014, 04:45 PM   #15
bjbstewart
bjbstewart's Avatar
9
370
Brilliant! Well done - I understand enough to know that I don't want to attempt this without at least a bit of instruction.
I can't believe no one has documented this process in english!!
[SIGPIC][/SIGPIC]
      06-24-2014, 05:02 PM   #16
Javizquierdo
13
39
Thanks, I hope it help you!! You can ask me that ever you want about it. I change about 7-8 times in diferents Z4.
In Spanish is better!
Note: Translate you in english!!
