04-27-2009, 12:35 PM | #1 |
84
Rep 628
Your opinion is needed on tires!!
I just cannot decide on tires and rims.
I would love to have the same setup as Lucid, but the new Volk TE37's are too expensive for me. The Advan RS will not come in 18x10.5 or even 18X10. I would like to keep the staged setup so now I am leaning towards the 18x8.5 and 18x9.5 Advan RS which is the OEM size. Will this be enough with 245/40 and 275/35 BFG-R1 tires?? I was thinking about the TRMotorsport wheels, but the 44mm offset on the 18x8.5 wheel is just too much. I could go with the 18x9.5 on the front and the 265/35 front but I dont think I need that much if the rear is just 275/35. What do you guys think? By the way I go with the Carbotech XP-10 pads, no Pagid is available now. |
04-27-2009, 12:43 PM | #2 |
374
Rep 8,033
I'd say don't go with the 8.5" front. Wider front tires help with braking. If you want to keep the staggered setup, you should be able to go with the 9.5" / 10" TR Motorsport wheels, and still fit 265/285 tires, but I guess check with tirerack on that.
04-28-2009, 08:03 AM | #3 |
84
Rep 628
Thanks Lucid,
I think you are right. My only issue is, tirerack does not have the 18x9.5 for the front. so I may mount the 265/35 on the 18x9 wheels which is OK but not ideal. Someone mentioned that oversizing your tire on a rim may harm your steering. By the way, did you put TPMS sensors in your track set?? Thanks |
04-28-2009, 09:53 AM | #4 | |
374
Rep 8,033
My understanding is also that it is indeed desirable to use a wide wheel. I did not install TPMS in my track wheels. There have been no issues. You get the TPMS warning and it then goes away.
04-28-2009, 02:17 PM | #6 |
266
Rep 770
Last two events, I used 18x9.5" D-Force LTW5s with 12mm spacers on all four corners with Nitto NT-01 275/35 tires. With a square setup like this, you just have to be a little more careful since the car will want to rotate more than stock but still has excellent balance. The really big plus comes under braking, where the wider tires up front HELP A TON! I was out-braking almost everybody in the last two track events, and I only have stock brakes except with Pagid yellows. Some were from nearly 150mph on a front straight that lead to heavy braking all the way to 2nd gear for a slow turn 1. First time I did it, I couldn't get the smile off my face at how much better braking I got from the square set up.
2021 A6 Allroad, 2020 SQ7, 2019 M5 Comp, 2011 GT3
past: A4, S4, X5 4.8is, SLK55, E60 M5, RS4, ML63, E92 M3, Q5, Touareg TDI, Escalade, SQ5, RS7, Velar FE, Q7 |
04-29-2009, 09:56 AM | #7 |
84
Rep 628
Well, I could not wait, eventough I agree with Lucid completely. I got the 18x9 front 18x10 rear TRmotorsport wheels with 265/35 front 285/30 rear BFG-R1 tires, Carbotech XP-10 pads (will change to Pagids as soon as they wear out). I had to be cheap. Maybe next year I can afford the Volk TE37's. The stock PS2 got so much beating last time after 3h on track (3x1h session) that I want to keep them alive for street use. I have a feeling they would not take more than maybe another 3h on track. So I needed something relatively soon. I am thinking 10mm spacers front would yield 25mm offset and 5mm spacers rear would yield 17mm offset.
Oh, I am getting the AA ECU tunning!!! |
04-29-2009, 09:47 PM | #9 |
455
Rep 377
I am very happy with a square 275/35-18 setup. You can get all the details on the thread here: http://www.m3post.com/forums/showthread.php?t=255573
04-29-2009, 09:47 PM | #10 |
455
Rep 377
I wouldn't but it is possible for that distance.
04-30-2009, 03:23 PM | #11 | |
30
Rep 915
You run the risk of puncturing one of them - not recommended - question, are they street legal in your state? Congrats on your set up. vz
Previous Track Toy |
04-30-2009, 04:10 PM | #12 | |
266
Rep 770
Besides, a spare set of tires fits easily in the E90 & E92 M3 with the seats folded down. Doubtful for the E93 though. The last event I managed to fit my R-comps mounted on track wheels, a floor jack, two large toolboxes, pair of jack stands, two folding chairs, camera gear bag, suit case, and other odds and ends in my E92 to drive 200 miles to the track. That's without taking up the passenger's seat. People were quite amazed I was able to fit it all in there. Who needs a trailer when you have an M3?
04-30-2009, 04:22 PM | #13 |
84
Rep 628
So I should not be that lazy! You guys are right, I will change them on the track. Just wanted to avoid some hassle. I need some cooling down anyway before I drive on the track.
