BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
EXXEL Distributions
      04-10-2009, 12:34 PM   #1
wolftrouble
16
148
Drives: 2008 M3 Sedan
Track pre-launch checklist
I was wondering if anyone else had a checklist (real or mental) they go through when tracking their M. Part of this is also my curiosity about whether I can 'pre-set' any of these things (some I know you can't, like the M button). Usually just before I head to the grid I do/check:
  • M-Mode activated (EDC to stiffest, Power mode on)
  • DSC off
  • iDrive display off
  • E-brake fully off (yes, I know it warns you, but I always check)
  • Seatbelt tight (I have a CG-Lock, so cinch down really hard on it at this point)
  • Center console info display off (I used to keep this on velocity, in addition to the regular speedo, but realized it updates too slowly to be accurate under hard driving)
  • Gas level ok
  • Temperature ok (this is as much to check if it's too cold as too hot, since redline won't be where I expect if it's chilly)
  • Mirrors aligned properly
  • One last glance at the floor to make sure nothing fell down there, just in case.
  • Pedals work as expected (feel like they have the right weight, not too stiff or too soft, etc.)
  • Cycle through 1-6 with clutch depressed, making sure action is smooth.
Note this is the 'sitting in the car' checklist, other tech stuff (tire pressure most importantly) isn't what I'm talking about here and should be done before getting on the grid.
      04-10-2009, 01:01 PM   #2
lucid
lucid's Avatar
374
8,033
Drives: E30 M3; Expedition
Nice checklist.
I use the "normal" throttle setting on the track. Gives me more control over the throttle input coming out of turns.
I also:
1. double-check to see that the wheels are still properly torqued (88 ft lbs)
2. double-check tire pressure
3. visually inspect brake pad thickness
      04-11-2009, 10:06 PM   #3
Dascamel
Dascamel's Avatar
48
1,664
Drives: 2008 e92 M3, 2010 e91 328i
Why turn the i-drive screen off?
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options
2007 Montego Blue 335i (retired)
      04-12-2009, 08:10 AM   #4
V1.47fan
1979
1,847
Drives: TheArtist formerly known as M3
Power,DSC Off (non tech pack car). Throttle control is very hard to achieve with the Power button on.
At least half a tank of gas to help with traction...for a car with a low torque engine it's surprisingly easy to break traction with the Power On.
      04-12-2009, 04:40 PM   #5
lugnut
lugnut's Avatar
354
Drives: 2008 E92 M3 Space/Fox
On a track it serves no purpose, except as a possible distraction.
18 XC90 T6 Inscription (Silver/Black)
16 981 GTS (All Black Everything)
12 E70 X5d Black Saphire/ Tobacco (RIP)
08 E92 M3 SG/Fox Red Gintani Race (sold), RG63
02 E46 M3 Cab Imola, E36 Z3 Atlanta Blue/Tan
      04-14-2009, 11:40 PM   #6
wolftrouble
16
148
Exactly. There's nothing there that has information you need to see on the track, all it can do is distract you.
Similar reason why I set the center LCD console to nothing: I used to have it on velocity, but the sample rate is too low. I realized I was glancing at it rather than the speedo coming into turns, and when accelerating/braking hard the speed shown may be the speed you were going a second ago. If I'm going to into a turn and I have a specific attack speed in mind I need to know the speed I'm going, not the speed I WAS going a second ago.
m3post
