06-26-2008, 09:13 AM | #1 |
27
Rep 304
Zaino AIO Question
Until I can pickup a car cover I figured I'd put a nice coat of Zaino AIO on my 128. On Zaino's site the Application link instructs me to strip the old wax with Dawn and then use Zaino AIO and then other Zaino products... do I really need to do all this? I understand for the best finish I should but I'm not going to a car show or anything, just want a layer of protection.
Will I be ok putting the Zaino AIO on the existing wax? On the back of the Zaino AIO bottle it says to buff it with a 100% soft cotton cloth, can I use microfiber cloths for this? Thanks
Ordered: 128i Titanium Silver, Black Leatherette, High gloss black trim, Sport Package, iPod Adapter, Premium Audio, BMW Assist
06-26-2008, 09:31 AM | #2 |
Donkey Kong King
89
Rep 1,129
I would wash the car with Dawn, it strips the old wax and allows the Zaino to bond with the clear coat. So I would wash the car with dawn(ensure you keep rinsing each panel you wash to prevent any sort of spotting)...dry, then Zaino.
Microfiber is fine, this is what I use. Its actually hard to find 100% cotton towels of good quality these days.
[SIGPIC][/SIGPIC]
06-26-2008, 09:33 AM | #3 |
27
Rep 304
ok - gotta go get some dawn then but at least I can use my microfibers... thanks!
06-26-2008, 10:20 AM | #4 |
50
Rep 628
The reason why Zaino doesn't recommend microfiber towels is because they are of varying quality. Some of them are great but some are really bad and can scratch your car. If you have some that you like, it's certainly ok to use them.
Waiting on a 2015 M235
06-26-2008, 06:50 PM | #5 |
43
Rep 829
Get the true 100% cotton / 100% zero twist cotton loop. The zero cotton loop makes a big difference. Much softer.
Hanover was the softest brand I tried at Linen & Things. Although it's made in India (Zaino says to use USA towels), it was the softest one and moderately priced. |
06-29-2008, 11:29 PM | #6 |
125
Rep 404
Drives: 16' X5 M-Sport / Space Gray
Do we need another coat of wax on top of Zaino or is the AIO sufficient to protect?
06-30-2008, 04:28 AM | #7 |
13
Rep 645
06-30-2008, 09:29 AM | #8 |
Call
21
Rep 683
The real purpose of Zaino is protecting your car's finish. The shine is just a wonderful "side effect". Please don't cut corners with your car's finish. Leaving the clay bar process out is like polishing over a dirty, gritty surface. Clay barring a car is one of the easiest things you can do in protecting your car's finish.
Minimally do the following: 1) Strip the wax or polish off by using Dawn Liquid dish washing detergent and lots of water 2) Clay bar (Z18) the entire surface of your car (note before you start how rough the surface feels before starting and how smooth it feels afterward) 3) Wash with Z7 car wash concentrate 4) Apply Z AIO or most any of the other Zaino Polishes like Z2 5) Additional coats will provide even more protection and a deeper luster but that will be up to you. Once you have done the above at least once, you should clay bar at least annually; additional coats of polish at your leisure. It will amaze you as to how easier it is to keep clean your car after polishing with Zaino. Just a note, Zaino is a protective polish not a wax. Call
06-30-2008, 11:21 AM | #9 | |
18
Rep 534
07-02-2008, 09:36 AM | #11 | |
Rep 75
07-02-2008, 10:19 AM | #13 | |
Donkey Kong King
89
Rep 1,129
I've tried this, but I have found if you layer a couple coats of the Z-2, the "POP" you get far exceeds the wax. (and yes I used a very high quality wax). I would stick with just adding addition coats of Z-2 when you feel up to the task, the results are fantastic.
[SIGPIC][/SIGPIC]
07-02-2008, 10:22 AM | #14 | |
Donkey Kong King
89
Rep 1,129
The AIO will provide you with a good level of protection and a good shine. If you want to really get the "Bling/Pop" out of the paint, then I would add a several layers of Z-2.
[SIGPIC][/SIGPIC]
07-02-2008, 10:40 AM | #16 |
Donkey Kong King
89
Rep 1,129
This depends on the condition of the paint. The AIO has mild cleaners and polishes to remove any minor imperfections. The Z-2/Z-5 has no cleaners/abbrasives. I would use the AIO, then follow with a coat of Z-2. Then once a month I would throw on a coat of Z-2. If you feel your paint is in good conditon and does not require any polishing, then try the Z-2. Be aware the Z-2 really does not fill any minor swirls. Z-5 is used for this.
[SIGPIC][/SIGPIC]
07-04-2008, 10:17 AM | #19 |
19
Rep 709
They are waxed at your dealership unless you tell them not to (and they actually follow your instructions). As a general rule, the guy washing/waxing will be the lowest pay grade, and it will show.
