08-21-2023, 11:40 PM | #1 |
33
Rep 67
Why wasn't GTS transmission standard on all F8x?
I've noticed numerous members on this forum mentioning that the GTS transmission flash by kubax86 offers only benefits without any drawbacks. Why didn't BMW implement this as standard for all F8x models?
I get that MDM exists because of liability considerations, and the choices around EDC/power steering cater to casual drivers who might not prefer a rigid suspension or steering. But why were the transmission and differential coding, which seemingly have only advantages, limited to the GTS models? |
08-22-2023, 09:53 AM | #2 |
2900
Rep 3,729
Because the GTS DCT, Diff, MDM are specifically tailored and tested using the GTS engine mapping, not standard or competition F8X engine mapping.
If you want the best configuration, you must pair all of the GTS drivetrain mapping WITH the GTS engine map.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
08-22-2023, 10:03 AM | #3 | |
7292
Rep 1,979
Drives: 2020 BMW M4 CS
I'm running kubax86's GTS drivetrain mapping on my M4 CS and it has made a significant improvement. |
08-22-2023, 11:36 AM | #4 | |
1039
Rep 927
08-22-2023, 11:43 AM | #5 | |
2900
Rep 3,729
With that said, always upgrade your heat exchanger and use Redline Water Wetter for best thermal efficiency.
tgb1974154.00 |
08-22-2023, 11:45 AM | #6 |
2900
Rep 3,729
Smoother and faster gear shifts, less kangaroo effect when starting off in 1st (i.e., reduces buckling).
It's just a better user experience for the DCT car.
mathys215.00 |
08-22-2023, 11:56 AM | #7 |
4999
Rep 4,139
to create more products and thus comparisons and thus reasons to make things cost more.
bmw doesn't give a fuck about whether they make the ultimate driving machine. its all marketing. They make amazing cars. but their slogan like all other companies is $$$$$$$$$ |
08-22-2023, 01:26 PM | #8 |
7292
Rep 1,979
08-22-2023, 01:28 PM | #9 |
7292
Rep 1,979
FrankMstein1038.50 |
08-22-2023, 01:34 PM | #10 |
7292
Rep 1,979
TractionControlDelete4602.50 |
08-22-2023, 02:46 PM | #11 |
1039
Rep 927
08-22-2023, 03:01 PM | #12 |
96
Rep 302
You have the kangaroo (buckling) effect when starting off in 1st in a DCT? I thought that's only an issue in manual cars. Think this mapping would help with that in a manual car?
08-22-2023, 03:43 PM | #13 |
33
Rep 67
Your reply doesn't really make sense. Everyone is reporting that the GTS DTC transmission flash is superior to the normal flash even on base or ZCP cars...
Theruleslawyer1023.00 |
08-22-2023, 03:44 PM | #14 | |
33
Rep 67
08-22-2023, 03:49 PM | #15 |
7292
Rep 1,979
First try this tip. If starting out from a dead stop. Lightly tap the accelerator pedal. When you accelerator you will notice a difference in clutch engagement.
dawei21395.50 |
08-22-2023, 04:04 PM | #16 |
96
Rep 302
It's only an issue on occasion only in Sports/Sports Plus mode, after engagement and if the car becomes unsettled from engagement to 2k rpm when it goes over bumpy roads. The only way to resolve it is to foot off the gas, wait until the car is settled and then give it gas again. It's weird.
540fan32.50 |
08-22-2023, 11:38 PM | #17 |
2900
Rep 3,729
It is superior but like I said, the GTS flash is meant to be paired up with GTS engine mapping for optimal performance. If you are using GTS DCT with stock mapping, you are not getting the most out of it.
08-22-2023, 11:39 PM | #18 |
2900
Rep 3,729
The GTS mapping is for DCT cars. I don’t think the GTS ever came with a manual option, only DCT.
08-22-2023, 11:44 PM | #19 |
2900
Rep 3,729
Are you running the GTS engine tune?
One thing to keep in mind is that the DCT is very sensitive to engine torque levels. That’s why I said the GTS DCT mapping is designed for the GTS engine mapping since target load for the GTS tune is different compared to stock, ZCP or CS cars. If you are pushing less torque than the GTS DCT map is expecting, then it may result in slower or spongy shifts. I’ve beat these settings to death on xHP and it’s hard to nail down the perfect calibration. Just look at the xHP discussion thread where people play with their torque reduction and torque punch settings.
08-23-2023, 06:14 AM | #20 | |
693
Rep 605
?18 M4 Comp
08-23-2023, 10:05 AM | #21 | |
154
Rep 419
Is that because the GTS map disables water injection? Sorry if this is a basic question, but I was concerned enough about it that I took it in to the shop (an indy) to make sure there wasn't an engine cooling problem developing. Thanks in advance.
2016 BMW F83 ///M4 Tanzanite Blue Metallic/Silverstone Full Merino // NBTevo ID 6 retrofit // G3x/F90 10.25" MGU display retrofit // GTS flash // SmartTOP // 437M + Pilot Alpin PA4 (winter) // 359M + ContiSportContact 5P (summer)
Retired: 2013 E93 M3 | 2015 F22 M235i xDrive | 2012 E70 X5 xDrive 35d | 2010 E90 328i xDrive |
08-23-2023, 10:12 AM | #22 | |
2900
Rep 3,729
With that said, the GTS tune isn't very aggressive relative to what's out there these days, so you should not be getting any overheating issues. I always recommend people use Redline Water Wetter for maximum thermal efficiency. Order 2 bottles and pour 1 in the engine coolant tank and 1 in the charge heat exchanger tank.
tgb1974154.00 TractionControlDelete4602.50 |
