proTUNING Freaks
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Cosmetic and Lighting Modifications
      06-03-2022, 03:57 PM   #1
TheGroundRoof
Norway
29
21
Drives: F80 m3 2018
Icon, Broken drl tube
So i managed to break one of the led tubes for the drl when placing the module…
Have anyone managed to somehow fix it or do i have to replace the whole headlight?[IMG][/IMG]
      06-03-2022, 04:57 PM   #2
TheGroundRoof
Norway
29
21
Drives: F80 m3 2018
It seems like i found a temporary solution by gluing a thin piece of glas to the led on the module
      06-04-2022, 02:12 PM   #3
TheGroundRoof
Norway
29
21
Drives: F80 m3 2018
Could you make a picture please? I have one with same issue. Thanks 😊
Well as it turned out, the tubing itself wasnt broken. It was those things that sticks out on either side.
If you look at the left tube you can see it had come loose from the plastic braket on the left side. Just needed to push it back
Doesnt seem to light any less than on my left headlight without those parts that fell off
      11-01-2022, 11:28 PM   #4
e90m3808
102
108
Drives: 2018 M3
I think I may have just done the same thing, I broke one of the brackets on one of the tubes.
After pushing back the tube into the bracket did you still need to glue that piece of glass?
If not how did your temporary fix work out? Is it still working? Also what kind of glue did you use?
f80post
