04-07-2022, 12:30 PM | #1 |
127
Rep 316
Pre-LCI GTS Light Install, anyone directly wire to REM?
As title...
To install the GTS lights (VLAND) all videos on youtube show that you need to run a wire directly from outer lights to in the inners. That wire ends up on display and gets between the truck lid and the trunk lid gasket, looks not OEM and look IMO just plan old horrible! Seems there 2 work arounds but have not seen anyone actually do either, I'm wondering if anyone has done them: 1. Buy an LCI harness and code LED lights, cleanest most OEM way to go but I cannot find any examples online of anyone actually doing this. 2. Wire directly to REM, which seems no one has actually done either. Either those 2 methods do not work or no one is talking about it. Has anyone actually attempted those methods or anything along those lines? |
04-07-2022, 02:09 PM | #3 | |
127
Rep 316
(this video shows it on top of the gasket) (this shows it between the gasket and the body) How did you do it? Why not tap directly into the REM? I'll try to find a wiring diagram there definitely a more sleek way to do this mod. |
04-07-2022, 02:42 PM | #4 | ||
360
Rep 622
The wire has plenty of give so you don't have the issue you described when closing the trunk |
04-07-2022, 04:31 PM | #5 |
2663
Rep 1,471
Drives: 2023 G81 M3 Touring
Both of those videos are terrible.
The connector for the extra harness can easily be popped off the wires to run the cable through an unused hole in the chassis behind the light, then put back on. No drilling or janky running under rubber seals. The wire runs completely inside the existing trims and can’t be seen once everything is reassembled. |
