Next Level Auto Brokers
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Cosmetic and Lighting Modifications
      12-27-2021, 12:24 AM   #1
M4J0R T0M
V8K1LR
M4J0R T0M's Avatar
88
118
Drives: F80
Cluster lights always on after gauge face swap
Hello,
I installed some gauge faces from Venoxy and now my cluster stays lit up all the time, even with the lights off. I can't remember 100% but I'm pretty sure they weren't on constantly before the install. Can y'all confirm that your cluster is only light when the lights are on?
What could I have done wrong to make the cluster stay lit? I'm planning to pull the cluster again and check all my connections but my thought is that a loose connection would cause no lights, not constant lights.
      01-01-2022, 05:07 PM   #2
NSX2M4
NSX2M4's Avatar
1410
1,371
Drives: 2019 M4 ZCP- RIVIAN R1S QUAD
The cluster lights on my non modified car stay on for a few minutes after turning the car off if the key is in close proximity.
      01-02-2022, 07:29 AM   #3
M4J0R T0M
V8K1LR
M4J0R T0M's Avatar
88
118
Drives: F80
Thanks for the reply. Mine stay on at all times when the car is on or running, regardless of the light selector position or time of day.
Can someone verify that the cluster is indeed supposed to be off when the lights are off? I know I’m not going crazy and they were off before I installed the gauges.
f80post
