11-05-2021, 11:12 AM | #2 |
90
Rep 345
That looks really nice. How hard was the install? Do you have any steps on the process of remythe old emblem?
2008 Toyota Tundra Super Charged Nautical Blue / Red Rock
2017 BMW M4 Vert. Atlantis Metallic / Silverstone 2019 BMW X5 50i Mineral White / Tartufo - Sold 2024 BMW X6 M60i Isle of Man Green / Ivory White |
chuss22.50 |
11-05-2021, 01:55 PM | #3 | |
23
Rep 36
PhatLyfe985.00 |
11-12-2021, 07:04 AM | #9 |
23
Rep 36
11-12-2021, 07:05 AM | #10 |
23
Rep 36
11-28-2021, 05:41 PM | #11 |
BimmerPost Supporting Vendor
2111
Rep 13,877
Drives: E92 M3 & F80 M3 & G82 M4
Fantastic choice. Definitely a must do and upgrades the interioe 100X!
Quite the top seller for F8X interiors for us. Plus, they don't scratch as easily so they last longer.
01-22-2022, 07:38 AM | #13 |
17
Rep 18
I did the same to my F80. Found a video on YouTube where the leather just comes off but it doesn't on mine for whatever reason (2016 F80). Had to pull the old emblem out, strip the wires, and solder the new ones in place with a very small amount of space. Then, I yanked on the cable and realised that it comes right out if you just pull on it hard enough. Haha. Looks super nice now.
01-22-2022, 10:11 AM | #14 | |
18
Rep 201
01-22-2022, 10:56 AM | #15 |
37
Rep 181
These emblems have been redesigned so that you don’t have to unplug them by opening the seat. You now cut the cord, crimp on a new connector and can plug in within the headrest. I haven’t installed mine yet but looks simple enough.
Part number 52 10 9 503 039 (they come individually so order 2) |
01-22-2022, 01:16 PM | #16 | |
18
Rep 201
04-08-2022, 09:53 AM | #17 |
90
Rep 345
I'm about to tackle this emblem replacement soon on my F83 and was wondering if disconnecting the battery is necessary? I did not see it mentioned in here. I wanted to check first before doing it then have something go wrong.
04-13-2022, 02:20 PM | #19 |
313
Rep 661
Just did this as well, didn't disconnect the battery.
Did some splicing since re-wiring the harness vehicle side seemed less than appealing. Removed the connector before realizing I didn't need to.
Winter: 13 PGM 3.5 E70|MHD
Summer: 15 6MT BSM F80|MHD|KW|SM-10 Gone: 09 AWD 6MT AW E90|FBO|MHD|XHP|KW|ARC-8 IG: 475_f80 Last edited by WordOnRoad; 04-13-2022 at 02:42 PM.. |
bigj505360.00 |
04-13-2022, 08:21 PM | #20 |
512
Rep 776
did you do this yet? if yes can you please provide the steps ?
04-14-2022, 10:54 AM | #21 | |
90
Rep 345
sna66512.00 |
04-18-2022, 07:46 PM | #22 |
90
Rep 345
Well, I was able to do this on my F83 this past weekend. Overall I'm happy I got this done. It took longer than I had expected. The most time-consuming part was opening the headrest to remove the emblem and connector. For some reason, the passenger side headrest didn't have any slack to take it out of the seat, so I had to follow the OP's link on how to remove the leather. Once I unclipped the cable, the headrest came out. I also followed the steps to open the headrest, but that was a challenge. Every plastic pry tool broke during the attempt to open the headrest (ended up with cuts from the broken plastic trim tools). I was able to pull out the cable, but fishing it back through was a pain in the ass because the opening is so small and trying to fish the connector in the hole was a pain. I was able to get it back in but during that struggle, somehow the connection wasn't secure, and the light was intermittent. So when I tried the same method for the driver's side, the wire came apart. So at this point, I figured I had to open the headrest. I ended up using a flathead screwdriver and that worked. Once the headrest was open, positioning the emblem and connector was a breeze. Also, I was able to reuse the existing connector housing for the silver emblems. Just remove the pins and swap them to the black emblem. Both black and silver emblems have different connector housings.
I don't know how the installation is for the F80 and F82, but for the F83, the most time-consuming part was figuring out how to open the headrest apart.
