02-19-2019, 08:42 AM | #1 |
483
Rep 317
Using M sport steering wheel from other models
Is it possiable to install other model m sport steering installed into your f15 x5. I was looking at some f30 m sport steering wheel thats for sale locally and was curious to see if it can be retrofitted.
02-19-2019, 10:14 AM | #2 |
208
Rep 258
I've been wondering the same thing for a while it's a lot easier to find other model M steering wheels
02-19-2019, 10:56 AM | #3 | |
4148
Rep 7,164
Drives: F90 M5 / F15 50i
'07 Yamaha R1 (sold)
'06 C55 AMG (sold) ?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe '14 X5 50i (wifes now) |
DuSh2113.50 |
02-19-2019, 02:56 PM | #5 |
13053
Rep 18,757
1,2,3,4 series steering wheel will fit. But it is a tad smaller in overall diameter.
If you are fine with it, then it is a direct fit.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
maDjzo872.00 |
02-19-2019, 05:31 PM | #6 | |
483
Rep 317
Steering part number F30 32307851514 F15 32307848339 |
Rated M4Speed2.50 |
02-22-2019, 06:56 AM | #7 |
2812
Rep 1,859
Drives: 23' X7 40i M Sport
F15 has the same wheel used in the F30/F80 (Boots may or may not be the same).
If you had a F10 "LCI" update, the wheel looks the same, but has a different hub(flat). Our F15 hub is concave.
maDjzo872.00 |
03-02-2019, 01:43 AM | #8 |
1103
Rep 7,063
Any of the interchangeable ones have a flat bottom? That would be killer
E90 Build Thread (SOLD) http://www.e90post.com/forums/showthread.php?t=809436
F15 Build Thread (SOLD) http://f15.bimmerpost.com/forums/sho....php?t=1064084 |
03-17-2019, 12:40 AM | #9 | |
23
Rep 55
I've also long wanted the X3 M Sport wheel: |
03-17-2019, 02:15 AM | #10 |
483
Rep 317
I thought I would update this, I got done with the steering retrofit, as for the airbag, it appears that all M sport steering wheel airbags are interchangeable with each model.
I was able to find one for $350 a dealer take off airbag from a 2018 BMW M2. No airbag light, no hidden error codes from ISTA/D, and it fits perfectly. |
HJ478.00 |
03-17-2019, 12:36 PM | #11 | |
23
Rep 55
Do you know the exact part numbers I would need in order to upgrade from my current wheel (seen below) to this thicker one you have there (or a similar one)? |
03-17-2019, 04:43 PM | #12 | |
483
Rep 317
What i did is to make sure it was removed from a F15 X5 or F16 X6, because the 2 and 3 series are smaller diameter and matching with options that I have ie Lane change warning (vibration motor), no heated steering, no dynamic cruise control no pedal shifter. The pedal shifter came with the steering so i just left it there its not functional (additional wiring and coding is needed for that for Xline in order to work) It took me 7-8 months of Ebay stalking to find one that matches my spec and that is locally sold here stateside. Try not to get from ebay in Latvia, Romania, Ukraine they sell smaller F30 steering wheel claiming to fit in F15 (which it does fit but it looks weird). As for the airbag US model are dual stage or 2 plugs in the back of the airbag otherwise the single stage airbag or "euro airbag" will throw airbag errors. |
08-15-2021, 08:50 AM | #14 | |
182
Rep 708
As for me, I am thinking of buying X5 F15 wheel to install it on F30 since the F30 wheels are so expensive now while I found an X5 F15 wheel that is cheap. I am upgrading from a sportline wheel which is ugly |
08-17-2021, 03:53 PM | #16 |
47
Rep 483
I’ll have a suede performance wheel with red stripe and no air bag for sale soon!
sukhk5272193.50 Rated M4Speed2.50 |
08-18-2021, 12:01 PM | #17 |
69
Rep 162
One thing to be VERY careful of when buying a used wheel. Ask the seller to state that the wheel did NOT have an airbag deployment. The airbag backing plate will be bent (and even by a MM or so) and your airbag will NOT fit correctly and will be next to impossible to remove (ask me how I know)
And BMW does not sell the backing plate separately so you will have to find a new (used) one on eBay. |
