07-14-2008, 06:38 PM | #1 |
374
Rep 8,033
Be careful when adding engine oil!
After the break-in service, the oil indicator was one notch above the center line. At 4400, it dropped to the lower end of the range (the lower triangle) and a message came on saying "add 1 qrt". So, I went to the dealer and picked up the quart of oil for $12. I figured it would be best to add in increments since I don't want to overfill. So, I put in 1/2 qrt, and drive. It takes 15 minutes to report oil level again, and the indicator is still sitting at where it was before with the same message on. I drive around for another 15 minutes nothing changes.
Then, I add the other 1/2 qrt. It takes another 15 minutes to report, and this time all of a sudden, the oil level is all the way at max of the allowable range (the higher triangle). Luckily no overfill message. So the first 1/2 qrt has no effect (the indicator was not bottomed out to begin with, so you can't say I had no resolution at the bottom end at that point), but the second 1/2 all of a sudden moves it from the lowest to the highest allowable. That's very precise, ha? So, my advice is to add the damn oil in 1/4 qrt increments to make sure you don't overfill if your oil ever runs low. If you overfill, you'll need to go to the dealer, and they will probably charge you $200 for an oil change.
07-14-2008, 06:51 PM | #4 |
48
Rep 1,664
Why did you pay for the oil? Get freebies on oil all the time...
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options 2007 Montego Blue 335i (retired) |
07-14-2008, 06:55 PM | #5 |
374
Rep 8,033
I didn't have time to deal with finding my service guy, having him call someone downstairs, etc. I just bought it and drove to work. Not a big deal.
07-14-2008, 07:05 PM | #6 |
O! So Sour!!
552
Rep 15,615
Drives: Fast 240z / Slow M3
THis is why a dipstick is FTW.
07-14-2008, 07:16 PM | #8 |
127
Rep 3,071
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
I'm at 3400 (2200 since service) and no drop yet.
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
07-14-2008, 07:30 PM | #9 |
153
Rep 493
Drives: '23 M4 G83; '23 M850i
07-14-2008, 08:25 PM | #11 | |
374
Rep 8,033
That is assuming the warning would go away when oil is drained, and does not require the dealer to turn off some kind of fault code electronically.
07-14-2008, 09:25 PM | #13 |
374
Rep 8,033
It could get messy though. I don't know if you can cleanly drain "some" oil from the pan without a whole lot coming out.
07-14-2008, 09:47 PM | #15 |
64
Rep 268
You guys are not so stupid to realize that the indicator says add +1 liter (not a quart) and that the oil from BMW comes in 1 quart which is 1.25 liters....I am just asking.
So when you added 1/2 a qrt and the car asked for 1 liter and then you added another 1/2 qrt, you in fact added 1.25 liters. ps. When you go overfill you really mess up the vanos pressure unit and engines have needed replacement because of this.
"Motion does not equal progress"
"I love the smell of cosmoline in the morning" |
07-14-2008, 10:03 PM | #16 |
602
Rep 5,448
the manual says if you add less than 1/2 a liter/qt. the i-drive cant get an accurate reading.
No Dipstick FTL!
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
07-14-2008, 10:51 PM | #17 | |
96
Rep 545
Check the oil container. Also the S65 M3 engine does not use a high pressure pump for the Vanos units. The S65 M3 engine operates the compact double Vanos system at normal oil pressure. The S85 engine in the M5/6 uses a high pressure pump and system for the Vanos. Additional oil in the S65 M3 will not affect the Vanos system because it operates at normal engine pressure. More oil in the sump does not raise the system operation pressure. Overfilling the engine can cause other problems....like leaks and oil use, and others. |
07-15-2008, 06:28 AM | #18 | |
374
Rep 8,033
07-15-2008, 06:36 AM | #19 |
337
Rep 8,811
Who you calling a dipstick? lol
07-15-2008, 06:57 AM | #20 |
55
Rep 649
where else can I get the oil for the M3? My jack-ass dealer didn't give me any.
This may be the lsat BMW I buy if this oil and no-dipstick becomes and issue for me. I live 40 minutes from a dealership I need extra trips there like I need a hole in the head. |
07-15-2008, 10:31 AM | #21 |
602
Rep 5,448
when they overfilled mine - i noticed higher than normal oil temps , 20 minutes before I finally got an i-drive reading.
07-15-2008, 10:38 AM | #22 | |
Moderator / European Editor
1545
Rep 6,754
Best regards, south
