05-07-2018, 11:18 AM | #1 |
658
Rep 345
2018 x5 3.5i xdrive 22 inch rims
I have a base model pearl white f15, was looking to throw fender flares and either 21 or 22 inch summer wheels on em. Was wondering if i need to get tpms put in the rims when i order them, also was just making sure that if i got 22 inch rims that i wouldnt have a problem with fitment or turning. Thank you
05-07-2018, 11:57 AM | #2 |
3243
Rep 5,066
All three X5's here are on 22" all season tires with zero issues with fitment.. You will need new set of TPMS if you plan to keep your originals.
2015 F15 X5 35i Msport Space Grey M Performance parts MPPK, MPE
05-07-2018, 12:08 PM | #3 |
936
Rep 1,180
Depending on offset and tire size you could have some minor rubbing at full lock. The more aggressive the width and offset the more likely you could get some rubbing. You should be safe though if you stay close to stock offsets and overall diameter.
And yes, you should get new TPMS sensors unless you plan to transfer the sensors from your stock wheels.
2018 X5 35i M-Sport
Dinan Stage 1 Tuner M-Perf Exhaust and lip Wheels: Winter - 469m; Summer - Vossen CV7 22s 2018 X1 28i M-Sport |
05-07-2018, 03:06 PM | #4 |
13100
Rep 18,777
^ Correct statement.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
Jars914658.00 |
05-07-2018, 03:34 PM | #5 |
1198
Rep 848
The warning light will annoy you without TPMS Sensors.
Jars914658.00 r33_RGSport13099.50 |
05-07-2018, 04:21 PM | #6 |
357
Rep 1,762
Drives: Porsche Panamera
I think you might experience the rougher ride quality. I took out a loaner with 19" today and man ride quality is so much better than mine with 20". Or did my car just crapped out on me? This loaner feels so much more luxurious than almost fully loaded car.
Jars914658.00 |
05-07-2018, 04:33 PM | #7 |
1198
Rep 848
If you go from 19 runflat to 21 or 22 runflat then yes it will probably be stiffer. But if you go from 19 runflat to 21 or 22 non runflat. The difference will be minimal.
Also, summer tires usually have a stiffer sidewall when compared to an all-season. Lots of variables to consider. Not just the wheel size.
Jars914658.00 |
05-07-2018, 04:41 PM | #8 |
658
Rep 345
I appreciate all the feedbAck, i definitely know that the ride will be a little rougher when going from 19-22s , in some cases people said their car was smoother on 22s which i find hard to believe. Im more concerned with getting the right offset and staggered set up. 22x11 rear and 22x10 front is what im goin for but i found a set 22x11 with 22x9 in the front, is that a problem?
05-07-2018, 05:53 PM | #9 | |
3243
Rep 5,066
Wavy1198.00 |
05-07-2018, 06:17 PM | #10 | |
1198
Rep 848
Jars914658.00 |
05-07-2018, 07:40 PM | #11 | |
13100
Rep 18,777
I was one of the first to put on and had to explained how much better it is compared to the 20" RFT. Few local customer couldn't believe it and took a ride in my X5. After the ride, they finally convinced on how much better it is. Also, the RFT ride will get harsher as the thread getting lower. For that wheel size, 22x9 front, 22x11 rear is fine. Offset is the most important to avoid fitment issue. The width of course 22x10 front is better since OEM is 20x10. And usually with 22", the tire size will be 295/30-22 which will looks bulging on 9" width wheel. While the rear 335/25-22 on 11" width is ok. I hope that help.
Jars914658.00 |
05-08-2018, 03:04 PM | #12 |
936
Rep 1,180
You could also run the tire setup I have which would work fine for the wheel widths you are looking at.
I'm running Atturo AZ850s in the following sizes: 275/35/22 Front on 22x9 315/30/22 Rear on 22x10.5 The front tires do bulge out a bit but I don't mind it and it provides some curb protection. They are also a little taller than the OEM overall diameter so provide a bit more sidewall height than the sizes Ben (RG Sport)mentioned.
2018 X5 35i M-Sport
Jars914658.00 |
05-08-2018, 03:24 PM | #13 |
658
Rep 345
Awesome how do you like those tires? Im looking at this set of wheels in 22x10.5 and 22x9
https://www.carid.com/savini-wheels/...104374430.html which has an option of delinte ds8 tires for an extra 450 bucks lol but i just dont know about them, definitely dont want to spend 1500 on pirellis either lol |
05-08-2018, 04:17 PM | #14 | |
936
Rep 1,180
Not a bad deal on the Delinte's, I just haven't done much research on them but have generally heard good things.
2018 X5 35i M-Sport
05-08-2018, 04:59 PM | #15 |
Rep 7
What are the details of the wheels and tires on the white no- M badge X5?
2017 X5 35i xLine Dark Graphite - Current
2015 IS250 Grey - Sold 2008 X5 3.0si Black - Sold 2004 X5 3.0i Black - Sold |
05-09-2018, 09:25 AM | #16 | |
105
Rep 1,761
I am looking at a 22" with a +15 offset.
2015 BMW X5 35i M-Sport (White/Brown) - 4/16/18 (Current)
2011 BMW 550i M-Sport (Jet Black/Cinnamon Brown) - 4/30/14 | 2007 BMW 328xi e92 (Jet Black/Coral Red) - PAST | 2005 Infiniti G35 Coupe (Ivory White/Stone) - PAST | 2005 Acura TSX (Obsidian Black/Black) - PAST | 1998 Acura Integra (Black/Black) - PAST |
05-09-2018, 09:57 AM | #17 |
936
Rep 1,180
I'm running a set of 22x9 +15 and 22x10.5 +20. The wheels are very flush to the leading edge of the fender flares. I can post a few pics if that helps.
2018 X5 35i M-Sport
05-10-2018, 11:03 AM | #18 |
845
Rep 1,497
05-10-2018, 07:50 PM | #19 |
936
Rep 1,180
2018 X5 35i M-Sport
05-11-2018, 02:38 PM | #20 |
105
Rep 1,761
Do you think 22x9 +15 square setup would look right?
05-11-2018, 09:24 PM | #22 |
13100
Rep 18,777
