04-29-2008, 07:25 AM | #2 |
Rep 112
Its under the glove box, take off the panel (2-3 screws).
You'll see a metal box with some wires, instructions I had was to remove the cables connected to the metal box for better access to the filter casing beside it (I didnt disconnect the cables fearing throwing warning lights). The filter casing is black, to open it, the bottom flap can be removed by sliding. Take out the old filter and making note the way it came out so you know the wind direction. Slide the new filter in, matching the wind direction, then put everything back togather. |
04-30-2008, 01:30 PM | #4 |
2070
Rep 4,365
Why are you changing the filter on an 07?
09-02-2008, 11:20 PM | #5 |
Rep 17
Sorry it took so long to get back! Didn't see your question till today. I had changed the cabin filters on my 325i (very easy) and on my wife's CRV (more work than necessary) and wanted to be prepared for the distant day when my Z was off warranty!
05-27-2010, 09:13 AM | #6 |
Meinkugelschmerzen
Rep 46
Drives: 2003 BMW Z4 3.0i, B757-200
Here is a pretty good reason.
08-19-2010, 02:37 PM | #9 |
SSGT USMC - '78 - '86
13
Rep 487
Drives: Z4 3.0si
probably due to the fact that it allows air into the cabin and also that it has a heater and an A/C unit as well.
Thanks,
Bill 2007 3.0si Roadster Black/Red, sport, Piano Black F14 Forgestar's |
08-20-2010, 10:44 AM | #10 |
Accountant, 1st Class
Rep 237
Drives: 2006 Z4 3.0si Roadster, Black
air filter
The comment was made "tongue-in-cheek".
I usually have my A/C blowing full blast with the top down anyway. Just seems like an added manufacturing expense in a convertible. |
08-21-2010, 07:16 PM | #12 |
M = Midlife Crisis
65
Rep 2,006
2006 Z4MC - #LL93158
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM |
08-26-2010, 10:19 AM | #13 |
Rep 139
I'm in the process of doing mine, took some pictures as well and will post them.. There was like tons of leafs in my filter... have to vaccum it all out.. Wasn't as bad as the pic above but still...
08-26-2010, 11:39 AM | #14 |
Rep 139
Pics are 800x600, I can lower it if necessary
Once you unscrew the 2 little screws below the glove compartment, you just pull that cover down. Once you unlatch the filter compartment, get your vaccum ready... mine was cover with leaves... pretty easy to switch out.. So my existing airflow points UP, I hope thats right, unless the last person/dealer installed it wrong.. |
08-26-2010, 11:54 PM | #15 |
1135
Rep 2,866
Drives: Anything
Thanks for posting the pictures! I'll come in handy one of these days.
10-14-2010, 04:06 PM | #16 |
Rep 237
Air filter in a roadster
10-14-2010, 04:09 PM | #17 |
Rep 237
air filter
Thanks for the images. They will come in handy.
Really should checkout my filter soon. |
11-07-2011, 10:06 PM | #18 |
157
Rep 1,107
Swapping out this cabin filter was one pain in the a$$. 30 minutes and I had to yell the thing back together! If you don't like lying on your back under a dash stay clear.
11-08-2011, 07:28 AM | #19 |
2432
Rep 11,667
^lol, it is a bit of a contortionist special.
1st time is a bitch, 2nd time is easier.
'21 M2C Hockenheim Silver
03-25-2012, 12:38 PM | #20 |
More of this than that!
29
Rep 817
@LSTRATOS
Thank you for the perfect DIY. Followed your pictures and it worked as shown. The worst part was the actual light...the cable on mine was so short...almost impossible to even lower the plastic plate even an inch or two. Popped light out from underneath and then partially pushed through to get at the cable. then I could get at the rest. However I decided to remove the white box to get everything out of the way..making the job less challenging. Thanks again.
'06 Z4 3.0i Jet Black/ Biege/Black Leather / Premium Package / DICE Silverline DUO / Stubby Antenna / Matte Black Grill Ultimate Cup Holder x2 / Gaptech RCH+ / First Aid storagebox x2 / Acrylic Wind Deflector |
07-29-2015, 01:00 AM | #21 |
Down Under!!
1621
Rep 4,294
just did this today.. lol yeah a bit of good ol swearing involved.
now i don't have to smell the PO when i turn on the airco (which is a lot) nice clean air smell… YAY!! of to Yas Marina circuit today… for coffee.. too hot to drive hard..
2007 EuroSpec Z4///MC - Building/Developing Z4 GT3
Powered by |
