Pandora Car Alarm System
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      10-01-2014, 03:27 PM   #1
M!
26
38
Drives: 2015 M4
Lithium Ion Battery Charger Availability?
I called a BMW dealer about buying a trickle charger for my M4's lithium ion battery and was initially told that there is only one genuine BMW charger for all models. When I pointed out that a lithium ion battery requires a specialized charger he told me that he would have to do a bit of research. A short time later he called back and said BMW does not offer such a charger, but that I should look for one on the after-market that has a 13.6 volt setting.
Does anyone have information about the availability of an appropriate charger? Can anyone recommend a specific charger?
Thanks.
      10-02-2014, 10:43 AM   #2
JamesM3M5
Some dude
92
1,780
Drives: E92 335i
I'd check with Deltran Battery Tender, first. They have Lithium Iron Phosphate batteries and chargers for them as well. I'd give those guys a call and see whether they're appropriate for the new BMW Li-ion battery. http://batterytender.com/chargers/
They claim they're the manufacturer for BMW, Harley, Lotus, and others.
More info on charging Li-ion batteries:
http://batteryuniversity.com/learn/a..._ion_batteries
RRT
E92 335i/6MT with stuff and things
      10-02-2014, 11:52 AM   #3
MasterC17
329
984
Drives: 2015 BMW M3
See my post here, this is direct from BMW NA. BMW themselves do not offer one at the moment.
http://f80.bimmerpost.com/forums/sho...7&postcount=49
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
      10-02-2014, 12:00 PM   #4
Gstone
142
555
Drives: '18 GT350, '15 M4 sold
I'm assuming you all want this for use during car storage, no?
My car will have limited use, if any during winter months. Can you recommend what things you would do during this time? Intermittent start ups?
      10-02-2014, 08:05 PM   #5
motex
2020 Mineral White 30d MSport
motex's Avatar
Costa Rica
524
2,146
Drives: 2020 Mineral White 30d MSport
Thanks.
Check this link on Ctek chargers and testers:
http://www.ctek.com/int/en/chargers/LITHIUM%20XS
....Life is too short to drive boring cars
      10-07-2014, 08:53 PM   #6
motex
motex's Avatar
Costa Rica
524
2,146
Thanks.
Are you 100% sure all M4's come with Lithium Ion batteries?
I own a Ctek charger and tester (still brand new) and don't know if it will work on my M4?
      10-07-2014, 09:04 PM   #7
huatian
73
240
Drives: SS M4
Are you 100% sure, i don't think the M4's or any BMW (maybe an i8) uses an Li-Ion battery. Open the hood look at the battery if you see liquid in the cells it's not a Li-ion. If it was a true LiPo it would super expensive and the charging circuitry very sophisticated indeed. Perhaps it's its an advanced glass mat battery or AGM (not a LiPO) good battery over conventional wet cell and you still need a very good charger as not to ruin the battery which is easy thing to do.
      10-07-2014, 09:08 PM   #8
motex
motex's Avatar
Costa Rica
524
2,146
Thanks, now I'm confused, will chek it myself, by the way, this is the one I own, great charger but also a tester, my former X6M used to have battery problems due to low usage and it worked just great.
http://www.ctek.com/int/en/chargers/...20AND%20CHARGE
Name:  MXS 5.0 TEST AND CHARGE_0.jpg
      10-07-2014, 09:19 PM   #9
huatian
73
240
Drives: SS M4
COLD/AGM: Charging in cold conditions and AGM batteries - Yes, this charger will work for an AGM battery most likely what's in the M4. Come to think of it, it's in the trunk right, then it would have to be an AGM battery as AGM don't out gas like a conventional wet cell, hence you can putt it in the trunk safely. They are popular in boats and RV's as well. Take good care of the battery a good AGM can set you back 250+ dollars to replace and you definitely charge it correctly. My RV uses AGM's and yes during say we say learning process I've ruined a few and was not fun replacing them.
General rule of thumb for AGM's
1. Never over charge them - so you need a good charger that is AGM aware and be sure to put the setting on the charger for AGM
2. Never let it get under the manufacture min voltage some as low as 12.3v, check the manual that came with it.
      10-07-2014, 09:27 PM   #10
SakhirM4
SakhirM4's Avatar
10785
8,852
Drives: '15 SO M4/'20 Z4 M40i
2020 BMW Z4 M40i  [10.00]
2015 BMW M4  [8.76]
M3/M4 use Lithium Ion battery
See this thread
http://f80.bimmerpost.com/forums/sho...d.php?t=964593
Also see:
http://www.autofocus.ca/how-to/techn...heir-batteries
And to answer your cost comment (from the link above):
"We figured a high-tech battery like this wouldn’t come cheap, and a quick call to a local dealer revealed the projected cost of these batteries is a little over $1,100."
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
The_Werm212.00
      10-07-2014, 09:32 PM   #11
huatian
73
240
Drives: SS M4
holy crap, wow - I'm super impressed. I feel better about the sicker price. Least I see where the money is going. Is great but a little scary too to keep this properly charged for winter storage. So easy to ruin a LiPo. Once I get my hands on the battery specs, I might just design my own charger to be safe.
      10-08-2014, 06:15 AM   #12
dave885
23
177
Drives: 2016 Porsche GT4
CTek makes a Lithium Ion charger. I emailed them and they said it should work for the M3/M4.
      10-08-2014, 01:46 PM   #13
AIRHEIR
X3M Comp
444
716
Drives: X3M Comp
Could u let me know which model they said works for the M3/M4? I would like to get one ordered.
      10-08-2014, 01:54 PM   #14
motex
motex's Avatar
Costa Rica
524
2,146
Check this out
      11-20-2014, 03:15 PM   #15
E92LNGCGY
439
1,732
Drives: F97/Q5/982 GT4
I bought the Ctek Lithium charger and it is awesome. The charger is very smart.
      12-02-2014, 01:09 AM   #16
BuLoOoSki
Kuwait
749
2,108
Drives: 2015 BMW M3
Have you already tried using it? How is it working for you?
Can you post pics?
2015 BMW F80 M3: Tractive EDC Suspension / Dinan Anti-Roll Bars / GC Camber Plates / KMP Dual Diff Mount / Girodisc Rotors / GT4 Brake Cooling Kit / PTF Flash Tune / Eisenmann Downpipes / CSF Heat Exchanger / BMS Charge Pipes
2007 BMW E92 335i (SOLD): BMS JB4 / Quaife LSD / Riss Racing DPs / Helix Intercooler / BMS Intake / STETT Charge Pipe / Forge DVs
      12-02-2014, 01:14 AM   #17
E92LNGCGY
439
1,732
Can you post pics?
Yes I have it works just like my other BMW trickle charger (non Lithium). Hook up the + and -, plug in wall that's it. It will do everything else on it's own. It even "talks" to the battery to see if it will accept charge first before moving to next step.
Will post some pics tomorrow.
      12-04-2014, 01:01 AM   #18
BuLoOoSki
Kuwait
749
2,108
Drives: 2015 BMW M3
Thanks, looking forward for the pics. BTW is there a way to use it without being connect to an electric outlet? My apartment complex does not have electric outlets in the parking lot.
      12-04-2014, 01:05 AM   #19
E92LNGCGY
439
1,732
Unfortunately no. It needs to be plug in.
      12-04-2014, 10:01 AM   #20
RocketBoots
RocketBoots's Avatar
1860
2,104
Drives: Horse Drawn Carriage
Just picked up one of these as well. Looks to be pretty good!
      12-04-2014, 12:25 PM   #21
jbtco
163
641
Drives: F80 M3
Do the F80 systems give any info on battery condition eg state of charge via the idrive as the lithium battery is supposed to be a smart battery.
M2 competition, Alpine White
Previously Owned :
X3 M 40i, F80 M3 Comp Pack, DCT, Yas Marina Blue, F80 M3, DCT , E92 M3 Comp Pack, E92 M3, Z4MC, E46 M3 CS, E46 M3
      12-04-2014, 06:14 PM   #22
E92LNGCGY
439
1,732
Here is a pic. Not the best but you get the idea.
XentSS296.00
f80post
