BMW 3-Series (E90 E92) Forum
A Couple of Codes
10-07-2013, 08:24 AM | #1 |
163
Rep 1,142
A Couple of Codes
My car threw a (29DC) code last night after a hard acceleration to about 3k RPM. I was able to read the code using Cobb as there was no error messages in iDrive but there was a noticeable loss of power. I restarted the car and it was normal again. I searched and some say it's the LPFP going bad. (I've been running E85 for a couple of months "E50").
Today, I started the car at 4pm after not being driven since last night and and it sounded like it wasn't able to fire up! And when it finally did, RPMs started going up to 2k and dropping to 600 for a few second and then it threw the half engine message and the RPMs became stable at 1k. I immediately connected Cobb and read a (29F1) code. I cleared it and the car became normal. I flashed the 98RON map and drove as normal. I still have a quarter tank of E85 mix. I also did a search and this code is associated with the HPFP failure! Now, should I just go ahead and replace the HPFP? Anyone of you guys who had HPFP failures experienced those symptoms or codes?
Current: 2018 M3 | individual Fire Orange
Gone: 2016 M4 | BSM |
10-07-2013, 04:42 PM | #2 |
900
Rep 6,285
Cant help much as my HPFP hasn't acted up, but don't rule out your LPFP also as they are 'strained' in E85 applications due to the extra fueling demands required when running E85.
10-07-2013, 06:46 PM | #3 |
163
Rep 1,142
Another rough start today. Same symptoms minus the RPM thing! The fan was on also. Half engine message and a new code (29F2).
The car seems to drive just fine when warmed up. Starts normal with no long cranks!
10-07-2013, 07:23 PM | #4 |
900
Rep 6,285
It's time to give Pete a call & book yourself into advan
http://www.e90post.com/forums/showpo...93&postcount=4 |
10-07-2013, 07:58 PM | #5 |
171
Rep 2,682
Hey Mo, I'm not sure about the LPFP but some of those symptoms and codes definitely sound like an HPFP failure. I've been through two. One on the E88 a while back at around 60,000kms and the other more recently on my E82 at only 38,000kms.
First was under warranty and the second one I bought a replacement from Stu and installed it myself. How many kms on your car now and has it had the HPFP replaced before?
10-07-2013, 08:10 PM | #6 | |
11
Rep 640
Have you had your HPFP replaced before?
08' E92 335I
Black Sapphire Metallic | M-Sport | GT-CS 19" Matte Anthracite | BMW Perf. Exhaust | JB4 | AR Design Catless DP | R1 Concepts Cross-drilled & Slotted Rotors | aFe DCI | ER Chargepipe with Forge DV | ER FMIC |
10-07-2013, 08:57 PM | #7 |
163
Rep 1,142
Thanks Shane, Alex and "zen".
The car has 95k kms and I had it since 56k kms. The first owner didn't even know what a HPFP was when I asked him if It's been replaced! So I guess it's on the factory HPFP.
10-07-2013, 11:11 PM | #8 | |
171
Rep 2,682
Symptoms I experienced were misfires and/or limp mode with hard acceleration, long cold cranks, stalling when cold starting, RPM drops with cold starts etc etc. Whether LPFP failure can also result in these symptoms I'm not sure but definitely all of the above are caused by HPFP failure. Unfortunately HPFP prices have gone up significantly since I did mine in May. I think I paid about $360 but the price is now like $480 or something . If you don't plan on DIYing it's about 1-2 hours worth of labour. If you DIY it can be done in under 3 hours as a first timer, or probably 1-2 hours if you've had some experience.
10-08-2013, 06:31 PM | #9 | |
163
Rep 1,142
What's the part # for the pump you ordered Alex and where from? I found this info online: "There is now a new type of HPFP available called Exchange High Pressure pump. This pump is fitted on the 1M with part number 13517616170 but its also the newest available for 335 MY 2007" http://www.ecstuning.com/ES2189759/
10-08-2013, 07:09 PM | #10 | ||
171
Rep 2,682
$520 isn't too far off from the BMR price but it's still cheaper from BMR I think. Around $480. Website is down so I can't be sure. If you need help doing it let me know. I reckon I could replace one in under 2 hours now that I've done one.
10-09-2013, 12:22 AM | #11 | |
163
Rep 1,142
$520 was BMR's quote! 13517616170 is exactly the part number for the HPFP from ECS Tuning. I'm going to order it from there for $348.80 shipped. And yes I guess I'll need your supervision!
10-14-2013, 01:01 AM | #12 |
163
Rep 1,142
Fitted the new HPFP on Saturday! Big thanks to Alex!
Car feels more responsive and accelerates better than before. I also noticed that my fuel consumption dropped from 15.8L/100kms to 13.5! Put in the RB PCV valve while I was at it and also emptied the OCC which was 30% full!
10-14-2013, 03:59 AM | #14 | |
171
Rep 2,682
10-14-2013, 05:58 PM | #15 | ||
73
Rep 1,546
Do you nothing anything different with the OCC or it's just a preventive mod?
Sold:08 BSM E92 335i JB4
Sold: BMW AW 1M , BMW Performance Seats, Revozport CF Front Lip, Revozport CF Trunk Lip, Revozport CF Roof Lip, Revozport CF Side Skirt Sold: Audi A6 C7 TDI Biturbo Now: BMW X5 F15 M50d |
10-14-2013, 07:25 PM | #16 | |
171
Rep 2,682
15.8 I'm probably averaging around 10 these days. Not really much traffic driving but not highway anymore with mostly back streets with lots of traffic lights too. When I lived in Newport I was averaging closer to 9. I've noticed that my manual tends to be significantly more fuel efficient than the 6AT convertible though. Could be weight but could be just different driving habits too I guess.
10-14-2013, 09:34 PM | #17 |
900
Rep 6,285
I get around 12.5L in city/suburban driving but I believe Moe runs an ethanol tune (maybe he only runs this at the strip?) which would use more fuel (ethanol burns faster)?
I also noticed on the bmw spec sheets the 335i AT are more fuel efficient than the MT which was surprising as generally it was the other way around with most cars (I guess that was back in the days of 5 spd manuals vs 4 speed autos!) |
10-14-2013, 09:49 PM | #18 | |
73
Rep 1,546
10-14-2013, 10:35 PM | #19 |
900
Rep 6,285
