BMW 3-Series (E90 E92) Forum
DCT shifting to Neutral by itself?!
11-16-2012, 12:54 AM | #1 |
23
Rep 185
Not sure if this topic has been discussed and my apologies if it has.
Has anyone with a DCT tranny experienced the gear shifting itself to Neutral when the car is running cold? I've had a few occurrences when I'm waiting at the lights on the way to work and the idle drops to under 600rpm and the gear shifts itself to Neutral - like a safety mechanism? Then it revs up high to about 1000rpm and drops back down to idle range @ 660rpm. Also, I'm not sure if this has got anything to do with it and the few times it has happened is when the car is in a bit of an incline? Weird. Not to mention the car next to me thinks I'm going to hit it at the lights! |
11-16-2012, 05:25 AM | #5 |
23
Rep 185
11-16-2012, 05:53 PM | #7 | |
Jedi samurai ninja turtle
619
Rep 3,021
Drives: X3 M40i 2018
11-18-2012, 12:18 AM | #9 |
259
Rep 1,165
Drives: f83 / E93 335 / E70 X5 40d
happened only once to me. I really didn't like the feeling; when you want it to be in D for drive, you want to be able to put your foot down and it should go.
I don't think that it is normal at all. |
11-18-2012, 12:40 AM | #10 |
27
Rep 185
Thanks skycat mine does it so often it has become normal to me, clearly it's not normal ! Will get SBM to do a software upgrade next service.
01-28-2013, 07:15 PM | #13 |
27
Rep 185
So , following advice from Skycat , had my DCT trans software updated and a couple of weeks later no shifting to neutral (touch wood)
Work done at Southern BM , again Andrew is a legend Last edited by Scootah; 01-28-2013 at 07:16 PM.. Reason: cause i cant type |
02-20-2013, 11:05 PM | #14 | |
Rep 62
01-06-2020, 07:07 AM | #15 |
Rep 1
Hi everyone,
I recently acquired a 2011 E92 335i with N55 engine. I have to say I'm in love with the car, but yesterday I had this issue. I was on a red light and all of the sudden the revs went down and the transmission shifted by itself to neutral. I couldn't set it to direct, so I tried turning the car off and then re-starting it, no problems putting the gear in direct or manual after that. Does this issue have the risk of the car not starting again or not being able to set it to D afterwards? I also noticed the launch control not always works, do you think this could be related? Something else that happened to me twice already, is that the car wont start for no reason. I parked the car and once I returned and tried starting it, it made a click sound but the engine wont start; after one or two minutes it would start normally. Do you think this issues are software related? I just got it 2 weeks ago and haven't been able to take it to a mechanic due to holidays and work, I want to take it this weekend but I would really appreciate your advice. Thank you very much in advance. Last edited by nachoxlopez; 01-06-2020 at 07:18 AM.. |
01-06-2020, 08:23 AM | #16 |
4545
Rep 11,903
Could be the dreaded cracked wires in the shifter assembly
