2010 2011 BMW 5 Series Forum F10 Change standard front lights? |
06-12-2012, 04:20 PM | #2 |
22
Rep 144
Philips Diamond Vision should do what you want but I'd be inclined to go Philips Xtreme because at least that way you will be able to see more than from the standard headlights even if the Xtremes aren't 'white' lights.
10-10-2012, 05:05 PM | #6 |
163
Rep 619
Hi, adding to this, which bulbs do I need to change, are they H7's type that are fitted under the bay under the bonnet, or the bulbs you have to replace via the front wheel well?
My problem is mainly low beam on my Halogens, they are terrible and you can hardly see the road and object on each side of the road... thanks
Sunset Orange G20 330e xDrive M Sport Pro - Tech/Pro Pack, Park Assist Plus
Bluestone G30 M Sport - Gone to Stud Alpine White F10 M Sport - Gone to Stud |
10-11-2012, 12:43 AM | #7 |
22
Rep 144
The headlights are replaced through the wheel arches and the main beam are the ones you access under the bonnet.
It's a bit fiddly but only a 10 minute job. You don't need totale the wheels off, just turn them to full lock to make more room. The screwdriver in the car's toolkit is a perfect fit. Good luck. |
10-11-2012, 05:53 AM | #8 |
1402
Rep 8,088
It's stupid that a £30k + car does not have xenons as standard as halogens are so shite.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
10-11-2012, 07:20 AM | #9 | |
163
Rep 619
10-11-2012, 07:59 AM | #10 |
1402
Rep 8,088
Voltage? All bulbs are 12v and in halogen cars the high and low beam are both H7. It's simply the postion within the parabolic reflector that changes the beam pattern.
Ian
10-12-2012, 02:50 AM | #11 |
163
Rep 619
Gottit, I've ordered four of these (Philips X-treme Vision H7), will let you know the results....
10-12-2012, 08:17 AM | #12 |
Rep 1
hi sorry to change the subject i have recently just bought a f10 12 reg and i can get adaptive headlights quite cheap i was wondering if they are easy to fit (plug and play) ?
thanks |
10-12-2012, 08:23 AM | #13 |
1402
Rep 8,088
Definately not plug and play. Do you already have xenons? If not you will need:
* headlamp washers * level sensor, front * level sensor, rear You will then need the LKM coding for xenon lights For the adaptive to work you will need: * Steering angle sensor * HBA light sensor * HBA rear-view mirror housing * LKM coding It aint going to be cheap.
Ian
10-13-2012, 01:14 PM | #14 |
26
Rep 47
Drives: 2018 M6 Convertible LCI
Just replaced all 4 bulbs on my car. I went for Philips X-treme 100%. Just hope they are an improvement. Also I'd like to meet the muppet that designed the front end access.
10-15-2012, 05:25 AM | #15 |
163
Rep 619
+1, the access through wheel well was designed for monkeys with small hands
10-15-2012, 05:30 AM | #16 | |
163
Rep 619
I noticed the stock bulbs are basic Osrams... consigned them to the bin. The new ones are brilliant! Give a great white beam, and I can actually see it now and it lights up the road very, very well.... worth the cost and time... (eBay from Upgrade Bulbs company)
