BMW 3-Series (E90 E92) Forum
Engine fault & loss of power
03-09-2012, 10:19 AM | #1 |
Rep 24
Engine fault signal turn on when I drive over 120 km and instant loss of power. I had to turn off the engine and start it again, then the signal disappear what seems to be the problem anyone know? The only thing I did to the car is an ecu upgrade a few month ago. Should I take the car to a local BMW service ASAP or the company that remapped my ecu? Please help me out thanks
03-09-2012, 10:20 AM | #2 | |
Rep 24
03-09-2012, 10:34 AM | #4 |
Rep 24
03-09-2012, 10:54 PM | #7 | |
Rep 24
03-09-2012, 10:58 PM | #9 | |
86
Rep 1,993
Pay to play. Get it checked out by your independent BMW person whom installed the flash.
Vishnu PROcede V5 | VK Motorworks FMIC | AR Design OCC | Forge DV's | Bilstein PSS9 | M3 Lower Control Arms & Caster Rods | Quaife LSD | HiTech Exhaust | BMW Performance Illuminated Door Sills | BMW Performance Gear Selector & Boot | BMW Performance E-Brake Cover
03-10-2012, 05:53 AM | #11 | |
Rep 24
http://www.ramspeedautomotive.com.au...hives/tag/335i Last edited by D8888J; 03-10-2012 at 05:58 AM.. |
03-10-2012, 07:47 AM | #13 |
156
Rep 4,995
Take it back so they can check what error code you got. If it was a misfire it could be spark plugs, coils, injectors or several things that is starting to fail.
03-10-2012, 08:01 AM | #14 |
127
Rep 2,224
Has this only happened once?
The ecu flashes don't offer as much flexibility to changing conditions as piggy back tunes. It could be an airflow error or cyl6 misfire, etc which are typical for tuned N54's. I've never heard of kraftwerk, but best to take it to them so they can read the code and see what caused it, then erase it. Make sure you find out what the code is so they don't BS you. The dealer would likely fix it, but you face losing warranty plus all expenses. If you've done a lot of km's maybe you should also look at some new plugs, and coils etc? IMO, the extra power requires a bit more love, like more frequent oil changes, etc |
03-10-2012, 08:55 AM | #15 | |
Rep 24
oh wells i bring it back to ramspeed where i got my ecu upgrade and see what they got to say. Its only 3 months and if im not wrong, its a 1 year warrantycannot find my receipt |
03-10-2012, 08:31 PM | #16 |
156
Rep 4,995
Supposedly Kraftwerk are pretty famous in Sydney, they do a lot of high end cars.
We got a dealer over here but it is quite pricey for just a flash! If it is happening quite often then is most likely a consumable part in your engine is on its way out since you are pushing the car harder. But can't tell without those codes! |
03-14-2012, 09:40 AM | #17 |
Tyrepower North Melbourne
10
Rep 88
Go back to the dealer that installed the tune. I have the same tune & have experienced the same issue. Unfortunately, like what the others are saying this means that your putting more pressure on some of these parts.
My fuel pump was the first victim, but 335 fuel pump is known to have issues. I replaced it with the current fuel pump - same pump as the 1M - no more issues. My car recently showed the 30FF code, vacuum line issue, low boost. I haven't fix this yet. I believe there is a post somewhere about this issue. I would'nt be surprised if the coil pack is next. From my observation, these parts are often the ones that needs replacement sooner or later, since the tune puts them to work a little harder they go out quicker than usual. I'm trying to get better quality materials for these parts, so they can handle the tune. I only go into "limp mode" on track & never on the road. So, as long as your not pushing the car every time you drive hopefully it will hold until you found the answer. Hope this helps.
19" 230 Wheels/19" Work Meister S1R - Yokohama Advan AD08 - Stett CAI Intake - M3 strut brace - M3 Rear swaybar - KW V1 - Kraftwerk Tune - ER Charge Pipe - Forge DV's
