BMW 3-Series (E90 E92) Forum
Coding for Phone functionality, anyone know the codes?
04-16-2011, 04:16 PM | #1 |
43
Rep 161
Drives: 2017 BMW M3
I just installed a dension gateway 500 with bluetooth (bta-1500).
I need the phone functionality enabled in order to use the hands-free functions of the dension. Does any one know the codes/values to enable the phone functionality? I've found a few codes which may do it, but I'm not sure. I looked through the spreadsheet as well with no luck. Maybe it's an option code for the VO - K K638 TEL_PROFESIONEL / / retrofitting Car telephone Professional ? Thanks, Chris
2017 BMW M3 - Tanzanite Blue with Full Silverstone Interior
11-28-2011, 09:38 PM | #3 |
1918
Rep 13,117
Did you happen document your Denison DIY
Did you happen document your Denison DIY.
At least the coding part ? Did you just add the CD changer to both the CAS and Frm module. did you have to process the entire car afterwards? wouldn't the denison bluetooth/telephone be on its own hardware and not relate to the car software or hardware. I would call denision on that. |
12-05-2011, 10:04 AM | #4 | |
43
Rep 161
Drives: 2017 BMW M3
Per the Dension doc's, the phone functionality of the vehicle needs to be enabled (programmed). I purchased my Dension Gateway 500 with a programmer (from Enfig Care Stereo in NJ). However, I reinstalled it in my trunk and programmed it via NCSExpert, etc. I didnot reprocess the whole car, just enabled the VO code for the cd changer and programmed appropriately.
12-05-2011, 12:24 PM | #5 |
1918
Rep 13,117
Bluetooth Telaphone retro thread
http://www.e90post.com/forums/showthread.php?t=85149
Maybe there are some clues in the above thread. Does the Denison phone module actually have a connection to the Most Bus? In the BMW retrofit guide there is some rearranging of the Most bus Hub behind the rear passenger seat US drivers side seat bolster. |
