BMW 3-Series (E90 E92) Forum
RE .. engine noise E90
11-13-2010, 07:16 PM | #1 |
Rep 11
Well guys more reports on the engine noise I reported earlier. I had new belt tensioner put in and ......... no difference...... I now reckon the noise is coming from the tensioner as when i put a shifter on the nut and apply pressure the vibration stops and so does the noise, but... something else is causing the tensioner to rattle and vibtrate!!..anyway car is going back to garage this week for further investigation...comment from daughter who has a mazda 2 " what a crap car you been ripped off "
11-16-2010, 07:48 AM | #2 | |
Rep 42
Let me know if you ever get to the bottom of this. |
11-23-2010, 02:43 AM | #3 |
Rep 11
serpantine belt
well looks like things are getting more clearer here regarding the noise from the tensioner. I had a new belt put in that is from an audi, it is 5mm shorter than the bmw one. The noise has been deadened by approx 85% , My mechanic recons the noise is being caused by vibrations from the air conditioner condenser. next plan is to look at the air con to see if new bearings can be applied as the new one is $1800 new. Also he is looking to isolate the air con from the the tensioner by using two belts instead of the one serpentine so that sounds like a plan....getting to the end now hopefully
12-03-2010, 06:31 AM | #4 |
Rep 11
just another note on e90 320i cold start rattle, my mechanic replaced the a/c compressor on a similar car and niose and rattle went so it looks like it may cost $1800 but I think I will get one from a low km wreck too close to xmas for that kind of money.
phew at last a solution |
12-04-2010, 05:22 AM | #5 |
171
Rep 1,537
So does it still make the noise with the belt off?
If not then i would look at the Alternator, take the belt off, grab the neck of the Alternator pulley and give it a twist, a flick of your wrist, after you flick it, hold the pulley tight and see if you can see the insides of the Alternator moving, if the inside moves, then no issue, if it doesn't move the pulley needs replacing, the front pulley is actually a clutch and drives all the time when it requires replacing and grumbles. |
