BMW 3-Series (E90 E92) Forum
Will these fit?
10-01-2010, 09:22 PM | #1 |
83
Rep 1,543
Will these fit?
Hi, does anyone know if these will go on a 320i standard suspension pre-lci? The seller says they will but cross checking,
http://www.e90post.com/forums/showthread.php?t=437708 Thanks
Tiag E90 | JBSPEED Spli t t ers | JBSPEED ACS style Roof Spoiler | JBSPEED M3 style Trunk spoiler | Euro plates | K&N Intake | BMW OEM Performance Exhaust | Debadged | OEM Chromeline trim |230 OEM rims | 19" Michelin Pilot Sport PS2 Non runflats | OEM Burr Walnut Gear knob | OEM Blacklines | OEM Spacesaver |
10-01-2010, 09:51 PM | #2 |
36
Rep 738
Drives: G30 530i
19x8.5 et 47 23.0 lbs
19x9.5 et 27 24.2 lbs massive offset in the rear... they are made for M3 and will rub what is the offset of your current rims? the info should be on the wheels itself
G30 530i
10-01-2010, 10:17 PM | #3 | |
83
Rep 1,543
************************************ Originally Posted by EuroTrip I run these on a E90 sedan. FYI, you will need a 20mm spacer to fit the fronts. Also you will need to roll the fender if you want to fit a 265 tire in the rear. I dont believe these will fit on an E92 or E93 because the rear has less room. Mine rubs some on the sedan. Just giving ppl information, GL with the sale. I got these rims only from some guy who thought they were reps and I paid $1k LOL
10-01-2010, 10:19 PM | #4 |
36
Rep 738
Drives: G30 530i
Let me just note... this is one WEIRD set of rims in terms of Offset
Assuming your current wheels are 8" et34 all around, then: Your fronts will have - 19mm LESS clearance on the strut side, and the outside edge of the wheel will RETRACT 7mm Your rears will have - 12mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 26mm Assuming your current wheels are are 8" et34 front and 8.5" et37 rear, then: Your fronts will have - 19mm LESS clearance on the strut side, and the outside edge of the wheel will RETRACT 7mm Your rears will have - 3mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 23mm
G30 530i
10-01-2010, 10:20 PM | #5 |
36
Rep 738
Drives: G30 530i
I would never use spacers, instead find the perfect offset.
G30 530i
