BMW 3-Series (E90 E92) Forum
Can the JB3 2.0 read these 3 parameters
04-13-2010, 12:06 PM | #1 |
325
Rep 2,663
Drives: BMW 335xi Sedan; BMW M3 ZCP
DME BOOST ACTUAL
DME BOOST TARGET THROTTLE BLADE POSITION I see that the "DME Boost Actual" is read by the ECU as the JB3 is outputting that signal in to the ECU. The "DME Boost target" is the output of the JB3 TMAP sensor. And from those two "Throttle blade position" is modeled. Is this correct? |
04-13-2010, 12:25 PM | #2 |
Joint Chiefs of Staff
4927
Rep 116,006
The boost the ECU observes, DME actual boost, can be read by any tune. That is what they adjust to trick the ECU in to thinking it is running the stock boost.
The target boost is modeled by the JB3. It's not directly read. Same for throttle blade position. The structure of the JB3 boost control system doesn't require precise target boost information as the ECU itself is doing the fine tuning on the targeting and it already knows that value. The JB3s job is just to rescale the value in to a range the ECU is happy with. Mike |
04-13-2010, 12:30 PM | #3 |
325
Rep 2,663
Got it! Thanks
335xi Sedan 6AT | Weather(70-85°F) | N54 Tune Comparison Chart || N54 Turbo Upgrade Comparison Chart
-PROcede Rev. 2.5 ~ v5 (3/17 maps) / JB4 (8/21 maps) / COBB (Stg2+FMIC LT Aggressive maps) †Procede Map2(UT 45 - IGN 40) Aggression Target 2.0 | 0-60 in 4.0sec || †Cobb E30 LT (35% Ethanol/65% 93 Octane) | 0-60 in 3.9sec AR Design Catless DP | BMS DCI + OCC | ETS 5 FMIC | Alpina B3 Trans Flash |235/265 19" Michelin PSS |
04-13-2010, 12:42 PM | #4 |
1748
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
More misleading info. None of those parameters are read by the jb3. DME actual boost is not read either. What is read by the jb3 is the desired MAP voltage output it is sending to the dme. The actual voltage being fed into the dme and what boost actual reading the DME translates this voltage to is NOT read by the jb3. These values are all internal to the DME. Reading with an external device (jb3) is only possible by reading data off of the CAN network.
Shiv |
04-13-2010, 12:50 PM | #5 | |
4927
Rep 116,006
Mike |
