10-16-2009, 04:04 PM | #1 |
1711
Rep 17,304
2010 Audi S4 vs. 2009 BMW 335i
"Given all the praise heaped on the BMW 3 Series over the years, we can't blame you for thinking there's more to the story. We've heard all the conspiracy theories, most of them involving checks in large denominations from Munich. This might seem believable to a certain segment of the population, but there's a far less interesting truth behind all those wins: The BMW was the best car. Sure, certain rivals often upped their game in one area or another, but the 3 Series always put it all together in a way that made it better. So now the 2010 Audi S4 is here to take another shot. It's all-new this year and the old V8 is gone. There's now a supercharged V6 in its place, along with a lower price designed to better align the S4 with the BMW 335i. The BMW 3 Series received a face-lift of its own last year. It was mostly minor trim changes and the like, but we're told that iDrive thing was tweaked again, too (oh, lovely). Sounds like a fair fight, no? Hope You Got a Bonus This Year Probably best to get the cost issue out of the way up front. These are not the entry-level sport sedans their names might suggest. The BMW 3 Series may start just below $34,000 on the low end, but once you add the 300-horsepower twin-turbo 3.0-liter engine — and you do want to do that — the base price jumps to $40K. That doesn't include much in the way of features, either, so our 2009 BMW 335i test car includes extras like a Sport package and a Premium package and a Cold Weather package and various other options. Final sticker price: $49,320. And if that number sounds steep, then consider that the 2010 Audi S4 is just getting started at nearly $46,000. Of course, Audi likes to point out that the S4's base price includes a long list of standard features, and it does, but our test car also had a Toyota Yaris worth ($12,425) of additional features, which pushes the grand total to over $59K. All this makes for a considerable price difference between the two cars, but on paper they actually match up quite well. Both use 3.0-liter engines with forced induction and both get standard six-speed manual gearboxes. The Audi also adds all-wheel drive, of course. There's an all-wheel-drive version of the 335i, too, but you can't combine it with a sport suspension, so the standard rear-wheel-drive version is a better choice for performance. And Now for Some More Interesting Numbers At those prices these sedans better do something special, and they don't disappoint. Say, for instance, you like to go very fast in a straight line. These sedans do that quite well. We know; we tested them. The BMW is the slower of the two, yet it still turns in a 0-60-mph time of 5.3 seconds (4.9 seconds with 1 foot of rollout like on a drag strip) and runs through the quarter-mile in 13.5 seconds at 103.8 mph. That's what 300 hp and 300 pound-feet of torque in a 3,607-pound sedan will do for you. The Audi is saddled with an extra 377 pounds, so it helps that its new supercharged V6 produces a healthy 333 hp and 325 lb-ft of torque. This is enough to deliver a 0-60-mph time of 4.9 seconds (4.6 seconds with 1 foot of rollout like on a drag strip) and a 13.2-second quarter-mile at 106.1 mph. How impressive are these numbers? Consider that the quickest of the new American muscle coupes, the 426-hp Chevrolet Camaro SS, turns about the same numbers down the drag strip as the Audi. Fast in a Nice Way You don't spend $50K on a European sport sedan to embarrass Chevys at stoplights, though. OK, maybe you secretly dream about doing just that, but for the other 99 percent of the time you want an ultra-refined, indestructible engine that makes all the right sounds. We've noted in the past that BMW's twin-turbo inline-6 is just such an engine. Surprisingly strong at low rpm and dead solid all the way to its redline of 7,000 rpm, BMW's force-fed straight-6 has no real faults. Or at least, it feels that way until you drive the S4. The Audi V6 is also staggeringly refined and full of torque, yet it delivers its burst of power even quicker than the BMW. It jumps off idle thanks to its fast-acting supercharger and doesn't fall flat once all the boost is dialed in. Instead, it charges all the way to its own redline of 7,000 rpm on a big flat mountain of torque. There's no buzzing or coarseness along the way, either. It feels like the BMW engine, only with an aftermarket chip already installed. Couple the nearly flawless engine with the S4's nicely weighted clutch and finger-light shift action and the Audi couldn't feel more perfect running through the gears. OK, a deeper and less raspy exhaust note would be nice, but we're nitpicking. Getting a Handle on All That Power Since any old Camaro can go fast in a straight line, we tested both sedans through the slalom and around the skid pad, too. The results are a bit closer, as both cars register 0.92g around our big circle. They do so in different ways, however. The S4 goes faster with the stability control left on, while the 3 Series makes its best run with it off. Seems as though the S4's computer is able to do a better job of moving the torque around than our test-driver. (He didn't take it too hard, though.) The S4's big advantage here is its torque-proportioning rear differential. It's able to send power to the outside wheel to help get the car turned and eliminate understeer. It works well through the slalom cones, too, as the S4 is slightly faster with a 68.8-mph run compared to the BMW's 68.4-mph sprint. Our test-driver eventually managed to finesse both cars through the cones with no help from electronic aids. He found the Audi surprisingly willing to bring its back end around thanks to the sport differential, yet it is easily controllable. The BMW has no such help, but is more predictable and stable and only fractionally slower. Confidence Builders On the street, it's a slightly different story. Both cars have high limits thanks to the sticky rubber included in their respective sport packages: Bridgestone RE050As on the BMW and Dunlop SP Sport Maxx GTs for the Audi. You can then throw it around as hard and fast as you want, yet it never gets out of shape. Getting the most out of such tires takes a more skilled hand in the BMW. It's still a lenient partner for the most part, with precise steering and predictable handling. But as you get closer to the limit it feels more on edge than the sure-footed Audi. The S4's all-wheel-drive system is the difference here. You simply feel more confident when you know that an ill-advised stab of the throttle won't send the rear end sideways. The sport differential makes such a sideways cornering attitude possible if you have the skills, but to the average driver it simply feels like the car is tracking better and more planted. Audi's Drive Select adjustable dampers help here, and Dynamic mode dials out what little softness is left. You can then throw it around as hard and fast as you want, yet it never gets out of shape. The BMW isn't too far behind, but push it too hard and even the sport suspension starts to feel just a little soft. They Go Slow Well, Too Keep in mind that so far we've been talking about only the most aggressive driving here. Go easy and these cars are still immensely rewarding to drive. Even with their big wheels and tires and sport suspensions, both cars ride comfortably and cruise quietly. We still prefer the more natural feel of the BMW's steering to the S4's responsive but slightly over-boosted setup. Both have incredibly powerful brakes. The Audi stops from 60 mph in just 109 feet, while the BMW only requires two additional feet. Pedal feel is light and precise on both cars. Gadgets Galore For your sizable chunk of cash, you would probably expect a healthy dose of luxury with your sport sedan. Both these sedans deliver, but the Audi's extra cost gives it an advantage. Included in its pricey Prestige package are extras like a Bang & Olufsen audio system, keyless ignition, voice-activated audio and telephone controls and a navigation system with video game-style graphics. All this comes in addition to the S4's standard features like sport seats, a sunroof, xenon headlights, heated power seats, Bluetooth connectivity and an iPod hookup. In other words, at $60K there's nothing left to add to this car. It all sounds overwhelming, but once you're behind the wheel the S4's layout doesn't look complicated. All the electronic gadgets are easily accessed through the MMI controller and none of the protocols take much time to figure out. Like the fancy suspension, though, you probably wouldn't miss much if you left most of it out. The BMW didn't have a navigation system or a high-end audio system and it still looked expensive inside — solid construction, quality materials and a simple layout. Both sedans have that typical German austerity that's traditional but hardly warm. Neither car has much of an advantage over the other in terms of front seat comfort, but the Audi's more spacious backseat makes it reasonably comfortable for four adults. S4 for the Win So the 2010 Audi S4 finished well ahead of the 2009 BMW 335i this time around. Have our biases changed? Did we want to shake things up? Are we partial to canary yellow cars? Not a chance. Like every comparison test before it, this one comes down to which car puts it all together in the most compelling package. We drove the cars in every imaginable situation, and every time someone got out of the Audi he was struggling to find a flaw. It was much the same way with the 335i, but driven back to back, the Audi feels a step ahead. Slightly faster, easier to push hard and more comfortable on the inside, the 2010 Audi S4 is as good as it gets when it comes to sport sedans in this price range. It's a lofty range, but if you're going to spend that kind of money, you might as well get what you pay for." http://www.insideline.com/audi/s4/20...-bmw-335i.html |
10-16-2009, 04:39 PM | #2 |
38
Rep 114
Very conservative numbers for the 335i but kudos to Audi for stepping up! Now they just need to offer some good lease rates
"Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise." |
10-17-2009, 04:27 PM | #3 |
D to the X to the B!
348
Rep 2,106
Nice......BMW 335 will just fightback with it's upgraded version of the 3 series (BTW, 740I in UAE is rated at 326hp and 335i is rated at 306 hp ) Both have the N54 engine.
11 corvette C6
10-17-2009, 06:17 PM | #4 |
11
Rep 23
honestly stupid combo...
they should have mated a 330i with the M package... or if they compared a reg 3 series to a S model maybe they should put this S model against a 60k m3 sedan and see what happens lol |
10-17-2009, 06:55 PM | #5 |
31
Rep 1,917
The way Audi is doing things now the S models are pitted against the x35 BMW's. It's the RS series that's comparable to the M cars.
2014 EBII 435i xDrive M-sport
Gone: 2011 TiAg F25 X3 xDrive35i M-sport Gone: 2008 TiAg w/Coral Red E88 135i Cab M-sport |
10-17-2009, 07:05 PM | #6 |
97
Rep 1,209
its actually not stupid and is pretty good for bmw. shows that a "regular" 3 series can compete and keep up with another brand's higher model.
10-17-2009, 07:46 PM | #7 |
1711
Rep 17,304
10-17-2009, 09:16 PM | #8 |
463
Rep 5,319
Isn't the 335i due for a power bump ?
10-17-2009, 09:47 PM | #9 |
313
Rep 2,576
I'm always amazed at the same stupid arguements?
What else should they have compared to the 335i in Audi's line up? The 2.0T is Audi's comparison to the 328, the S4 is the 335i and the R series is the M's competitor. It is not that hard to understand is it fanbois!? |
10-17-2009, 10:07 PM | #10 |
31
Rep 1,917
^^^ No doubt. Appreciating a different vehicle doesn't diminish your own vehicle.
10-17-2009, 10:13 PM | #11 |
11
Rep 23
10-18-2009, 12:33 AM | #13 |
68
Rep 1,456
Drives: 2008 E92 335i
He misspelled "Investor" as well.
"Yeah; well, my interior is better."
10-18-2009, 05:24 AM | #14 |
1153
Rep 8,027
How many S4 vs 335 threads does there really need to be?
And while I'm asking this question lets ask another, why does these comparison produce such defensive reaction from so many people? The weird thing is other brands when compared to BMW they get discussed without such negativity. The problem appears to be that in the US Audi don't appear to offer a full range that competes with BMW line up. 316 vs A4 1.6 320 vs A4 1.8T 325 vs A4 2.0T 330 vs A4 3.2 335 vs S4 M3 vs RS4 Maybe looking at the full line up from each brand might help explain where each model is and which is should compete with. |
10-18-2009, 06:18 AM | #16 |
1711
Rep 17,304
10-18-2009, 06:26 AM | #17 |
1711
Rep 17,304
apples to apples is the S4 and 335i. you are truly a moron if you dont come to that realization. also, fwiw, there is no M-package on the 330i; at least not in the states. you could add an M-tech front/rear bumper and sides, but i doubt that would enhance performance substantially . youre simply making yourself look like more of a fool as you try to refute what every one else is saying.
10-18-2009, 07:52 AM | #18 | |
1690
Rep 6,607
Great post! I give the Performance advantage to Audi to the lines in bold. |
10-18-2009, 08:07 AM | #19 |
tiamat
382
Rep 1,476
they should compare the 335i competition package with the s4!!
It makes no sense to compare a regular 3 series with a S audi(not a regular a4). The audi ,from what i have heard costs 60 k wich is a lot more than a regular 335i and is just a little bit better than bmw 335i!! |
10-18-2009, 08:40 AM | #20 | |
10
Rep 181
false statement +1 again. S4 is NOT alot more than 335. if you go spec a 2010 335i with similar options in S4 such as 19' rims, M package, sound upgrades, nav, etc, you will end up pretty close. this has been talked in another thread.
2010 GT-R Black/AMS custom ECU/AAM Competition Mid-pipe/HKS intake
2010 X5M Sliverstone(Tuned by Powerchip) 2009 AW/FR M3 COUPE:HP AUTOWERKS ECU, BMC FILTER, RPI SCOOPS,ROGUE ENG PULLEY(SOLD) |
10-18-2009, 10:53 AM | #21 |
tiamat
382
Rep 1,476
pretty close means how much difference?!!?
10-18-2009, 12:01 PM | #22 |
1158
Rep 12,445
The problem is if you attempt to price them closely you pretty much lose the game-changing LSD and Audi Drive Select. Include those and your price tag will be much closer to 60k.
Past: '15 Mustang GT|401A|PP|6MT Current: '20 Shelby GT350|6MT |
