07-27-2009, 05:19 PM | #1 |
56
Rep 76
Is it possible to access my Old Computer's HDD?
I just got a new Quad-Core Desktop. My question is, there's an old computer I have that's sitting in my closet right now and I'd like to get some data out of it. The old computer in question dates back to about 2001, maybe 2000?
My question is: Is there anyway to access my old HDD? The computer's MoBo (Mother Board) is dead. I can't even turn it on. Would there be any compatibility issues between the two computers (the old one and the new one)? Any suggestions guys? Is software/hardware required? |
07-27-2009, 05:20 PM | #2 |
エアーマンが倒せない
278
Rep 2,041
What OS is it running? What OS is your current PC running?
07-27-2009, 05:36 PM | #3 |
56
Rep 76
07-27-2009, 05:55 PM | #4 | |
Nosy Neighbor
Rep 21
Sure. Your old HDD is probably IDE. You just need to have an IDE controller on your new MoBo to hook it up to. If your new MoBo doesn't have one, you can get a USB to IDE adapter fairly cheap. Here's a link to one on Frys.com: Frys |
07-27-2009, 05:59 PM | #5 | |
56
Rep 76
What's an IDE Controller? Do most computers have this? |
07-27-2009, 06:14 PM | #6 | |
Nosy Neighbor
Rep 21
IDE stands for Integrated Drive Electronics, Read about it on wikipedia: http://en.wikipedia.org/wiki/EIDE Newer computers are usually Serial ATA (SATA) wikipedia: http://en.wikipedia.org/wiki/Sata Your new MoBo may or may not have an IDE controller, in which case you can use the USB to IDE adapter to get your data off of the old HDD. What MoBo do you have?? I'll look up the specs and tell you what you have. |
07-27-2009, 06:20 PM | #7 | |
56
Rep 76
07-27-2009, 06:20 PM | #9 |
597
Rep 5,946
07-27-2009, 06:22 PM | #10 | ||
Nosy Neighbor
Rep 21
If you bought it pre-built, what's the model number and manufacturer ?? |
07-27-2009, 06:24 PM | #11 | |
56
Rep 76
Friggin Computer Gurus I bow in your prescence! Hewlett Packard Model: a6700f BTW Do I have a decent desktop? I pickd it up for 1K |
07-27-2009, 06:38 PM | #12 | |
Nosy Neighbor
Rep 21
It may be easier for you to just go the USB to IDE adapter route. |
07-27-2009, 06:49 PM | #13 |
56
Rep 76
Okay so when I open up my Computer Case, where should I look for this wire? What does it look like? When I do find it, I can just plug in my old HDD into it, start up the comp, and access the information right?
07-27-2009, 07:00 PM | #16 |
56
Rep 76
Alright, so when I have some spare time later today I'll pop open my computer and look for that cable. Once I find it, I'll just unplug the old HDD and hook it up to this wire inside the new machine, correct?
07-27-2009, 08:35 PM | #17 | |
Nosy Neighbor
Rep 21
Your old computer will have the IDE drive and ribbon cable. If you remove it from your old computer, you can temporarily hook it up to the IDE controller in your new computer. HOWEVER, you probably need to go into your BIOS and see if the IDE controller is even enabled, and whether the SATA drive is set to boot first. It's possible that by hooking up the old IDE drive, it will become your "C" drive. Like I said, it's easier to get the USB to IDE adapter. Once you get the IDE drive out of your old computer, you just hook up the adapter, power and plug it into a USB port on your new computer. Your new computer should recognize it, same as it would a thumb drive, and you can then get your data. |
07-28-2009, 03:51 PM | #18 |
141
Rep 1,314
Don't forget the 4 pin power cable too. Most computers these days eliminated it but seeing how your mobo still has the ide, it probably has it too. However, seeing that since you have a HP, they may have maxed it out on the amount of cables so you'll need to buy one of those splitters from mwave/fry's or sites like that.
