BMW M8 Forum and 8 Series Forum BMW M8 and 8-Series General Discussion M8 vs M850i weight savings
Thread Tools
      07-10-2024, 01:30 PM   #1
TupperBMW
1641
1,161
Drives: 2023 BMW M8 Comp GC
Comparing the M8 Competition GC vs the M850i GC, I generally notice that the M8 is about 300 lbs lighter (giver or take) than its M850i counterpart.
I've been looking online but I can't seem to find how those weight savings are achieved. I know that RAS is one difference between both cars, but surely there are other areas where the M8 is saving weight.
Does anybody else know the answer?
My channel:
https://www.youtube.com/channel/UC4W...lUKB1w8ED5bV2Q
2023 BMW M8 Comp GC
2022 Ferrari F8 Tributo
      07-10-2024, 01:49 PM   #2
ViO
ViO's Avatar
667
476
Drives: X6M
I know the M8 Convertible has the “Carbon Core” as part of its door sil logo… I’m not sure if the M850 has the same “Carbon Core” structure? If it doesn’t then I believe that would be the answer (or part of) to your question. 😊
And If it does… Then perhaps the rear wheel steering assembly of the M850 weighs more than not having it on the M8?
And of course it could be any combination of the two. 😊
Appreciate 3
TupperBMW1640.50
Volcanic168.00
KB7291.50
      07-10-2024, 02:07 PM   #3
ElloM8
94
140
Drives: BMW M850i
I believe if you are comparing the M8C against the M850i it will be the roof, four wheel steering, front seats and few other bits like the wheels. All of that stuff will add up.
Moopai470.50
      07-10-2024, 05:53 PM   #4
rickyr17
183
204
Drives: 2024 BMW M850i Vert (G14)
M850 has Carbon Core.
Appreciate 3
KB7291.50
Saker_88.50
      07-10-2024, 10:31 PM   #5
bloozemanAZ
bloozemanAZ's Avatar
4691
4,724
Likely down to the RAS and seats (but only if the M8C GC has CF buckets). The CF roof is optional on the M850i. Wheels and ceramic may make a difference on the M8C as well.
      07-10-2024, 10:35 PM   #6
bloozemanAZ
4691
4,724
Yes and technically across the entire 8-series.
Saker_88.50
      07-11-2024, 11:33 AM   #7
TupperBMW
1641
1,161
^ I looked today and mine doesn't say "Carbon Core" on the door sil
My channel:
2023 BMW M8 Comp GC
      07-11-2024, 01:38 PM   #8
Gr8 Ape
202
223
Drives: M8 Coupe; X5 M60i
Try B pillar?
KB7291.50
      07-12-2024, 07:02 PM   #9
bloozemanAZ
4691
4,724
It has it no questions asked.
Saker_88.50
      07-13-2024, 08:38 AM   #10
TupperBMW
1641
1,161
Originally Posted by Gr8 Ape View Post
Try B pillar?
Yep, that’s where it was hiding
Saker_88.50
      07-14-2024, 07:58 AM   #11
Dasky_spas
352
1,037
Drives: Bmw
Active roll bars and the rear steering are the bulk of the weight. Also the rear battery (li-ion vs huge agm). Carbon roof is only like 10lbs if that I read ( unless there's a sunroof).
      07-24-2024, 12:26 PM   #12
dhoggm3
dhoggm3's Avatar
298
1,318
Drives: G87 M2, E46 M3, B8 Alpina
And the M850's electronic stabilizer bars, as well.
E46 M3, G87 M2, Alpina B8
      07-30-2024, 01:30 AM   #13
Sophisto
Sophisto's Avatar
58
104
Drives: BMW i8 roadster / BMW M850i
The carbon roof plus carbon exterieur package on my 850 reduces the weight by about 30kg. I didn't think it would make that much of a difference.
85Shark1638.50
      07-30-2024, 10:40 PM   #14
Dasky_spas
352
1,037
Drives: Bmw
You can reduce weight ( 45lbs) by switching to lithium battery but you'll need to check it the specific battery is compatible. I tried Antigravity and it didn't work however it did work on someone's m550.
      10-19-2024, 03:41 PM   #15
Dasky_spas
352
1,037
Drives: Bmw
How did you determine this? Your carbon exterior bits are in place of lightweight abs so how do get over 60lbs delta on an aluminum to carbon roof that is about 3- 4'?
      10-19-2024, 07:35 PM   #16
M6-Coupe
M6-Coupe's Avatar
4102
8,601
Drives: F92 M8 Competition Coupe
According to BMW website M850 GC weighs 4696 lb while M8 GC weighs 4480 lb so the difference is 216 lb.
The weight difference between M850 Coupe and M8 Coupe is 132 lb (4427 lb vs 4295 lb) and for Convertible is 130 lb (4560 vs 4690).
I believe the majority of this difference is coming from the followings:
Roof: CF roof vs Metal roof
Rear Steering: M8 does not have this feature
Wheels: M8 has tubeless tire but M850 has RFT and I assume M8 has light weight rim.
Seats: M850 has more luxury seats with some additional options such as massaging. M8 has more sporty / lighter weight seats.
Suspensions: M8 has light weight suspension with lots of aluminum parts.
In addition probably the other components like engine, gearbox, differential might have some weight saving on M8
Current : 2024 F92 Black Sapphire M8 Competition- ZF8
Gone : 2020 F92 Black Sapphire M8 - ZF8
Gone : 2018 F80 Mineral Gray M3 Competition - 6MT
Gone : 2016 F82 Austin Yellow M4 Competition - 6MT
Gone : 2013 F13 Sakhir Orange M6 -7DCT
      10-19-2024, 08:52 PM   #17
Dasky_spas
352
1,037
Drives: Bmw
I've torn the car apart. The M8 has more robust suspension parts, more bracing in the under body.
The metal roof..is thin aluminum. Not much weight savings with a small carbon roof, likely 10lbs. It's all the rims, rotors, active sway bars, rear steering.
Moopai470.50
      11-21-2025, 03:00 PM   #18
komalol
17
24
Drives: M8
I do not know your source, but in BMW Technical data sheets (for Europe from 03/2021), the weight difference between M8 and M850i is just 33lbs (GC). (66lbs for Coupe ; 55lbs for Convertible)
      11-21-2025, 03:27 PM   #19
M6-Coupe
M6-Coupe's Avatar
4102
8,601
Can you share the weight of all individuals?
      11-21-2025, 03:48 PM   #20
komalol
17
24
Drives: M8
M8 Coupe F92 : 4.180 lbs
M850i Coupe G15: 4.246 lbs
M8 GC F93 : 4.389 lbs
M850i GC G16 : 4.422 lbs
M8 Convert. F91: 4.455 lbs
M850i Convert. G14 : 4.510 lbs
kerb weight (90% fuel, no driver)
M6-Coupe4102.00
      11-21-2025, 04:03 PM   #21
M6-Coupe
M6-Coupe's Avatar
4102
8,601
Thanks.
This is from BMWUSA website:
M8 Coupe F92 : 4295 lbs
M850i Coupe G15: 4427 lbs
M8 GC F93 : 4480 lbs
M850i GC G16 : 4696 lbs
M8 Convert. F91: 4560 lbs
M850i Convert. G14 : 4691 lbs
And it says curb wight. No mentioned about amount of gas!
      11-22-2025, 03:08 AM   #22
komalol
17
24
Drives: M8
Thanks.
In Europe, there are two weights : DIN(100% liquids 90%fuel) and EU (DIN+165lbs for driver and luggage)
So BMWUSA weights are probably with driver.
The rest can among others be explained by different serial or regulatory equipment (exhaust, driver assistance systems etc.). In 2021 for example, the weight of the M8 increased by 33lbs mainly due to new emission regulations (cat's) ....
We also have the real weight in the official papers (including optional equipment). A few examples:
Carbon ceramics : -50.6lbs (confirmed)
Carbon seats : -21lbs (confirmed)
Carbon roof : -13lbs (confirmed)
Heat comfort package : +4.5lbs (estimated)
Driving Assistant Pack Professional : +1lbs (estimated)
Parking Assistant Pack Plus : +2.5lbs (estimated)
Bowers & Wilkins : +6lbs (estimated)
The wheels and tires also have differences in weight...
Based on my data, the max. configuration weight range for the 3 models of the M850i is 225lbs (for the M8, it's only 114lbs).
Appreciate 3
M6-Coupe4102.00
A_1573.50
Copyright ©2000 - 2026, vBulletin Solutions Inc.
