04-25-2024, 10:41 PM | #1 |
Rep 16
Recently sold my 23’ M850 and have 1 tire for sale. Changed the car over to Non run flats, and kept an extra front sized tire when I needed to buy one. As new condition, tread and rubber are perfect. used it once has less then 50 miles on it. Stored in a climate controlled garage since this has stock summer tire rubber. 245/35 ZR20 95Y Michelin Pilot Sport 4S, Non-run flat Pick up only, Morris county NJ |
04-27-2024, 06:46 PM | #3 |
65
Rep 153
You have to be very careful about diameters of tires on all wheel drive cars, wear changes tire diameter. Unless you possess an exact match to this tire's size it won't work. That is why a shop will recommend a two tire change at a minimum when buying tires.
