04-09-2024, 05:32 AM | #1 |
245
Rep 883
Getting rid of in-cabin fake engine noise..
So just to clarify, the only way in the G87 to remove the speaker engine noises is to use Bimmercode? There is no longer a module where you can buy the bypass cable? Any other way to disable? Pull fuse or something?
///M
04-27-2024, 06:48 AM | #3 |
245
Rep 883
Doesn’t that also close the exhaust valves though?
///M
04-27-2024, 09:13 AM | #4 |
missed it by that much
124
Rep 63
With sound control off the exhaust valves follow the needs of the turbos, if the turbos are increasing pressure the exhaust valve will be open accordingly. you are right at light throttle/no boost the valves will be closed.
04-30-2024, 08:11 PM | #5 |
Driver
80
Rep 117
if someone has an eternal valve controller installed, does pushing the ASD override the open command from said controller and proceed to close it as said above?
05-02-2024, 07:23 AM | #6 |
2861
Rep 1,793
You need Bimmercode and an OBD adapter to do it properly.
2023 G87 M2 - Toronto Red | 6MT | M HAS | CF Roof | BMW 826M Forged Wheels | Mishimoto Skid Plate | Active Autowerks Single Midpipe
Retired: 2022 M240i xDrive | 2021 Audi RS5 | 2019 Camaro 2SS 1LE 6MT | 2016 428i GC | 2011 BMW 335is |
