BMW M3 and M4 - The Icons
home
Classifieds Sponsors Classifieds Wheels and Tires
      03-25-2024, 06:15 PM   #1
IND-Distribution
BimmerPost Supporting Vendor
IND-Distribution's Avatar
9595
10,883
Drives: G82 M4 / G87 M2
IND | BBS G8X M3 / M4 LM-R 20" Wheel Set
*LIMITED STOCK*
When the goal is ultimate performance, a forged wheel from BBS is the answer.
BBS has been offering forged aluminum wheels in the aftermarket since 1983. Starting from a billet of 6,000 series, 7000 series Dura aluminum, or a special magnesium alloy, every BBS forged wheel uses our special multi-stage Die-Forging process which can require up to 18 million pounds of pressure to produce. Every stage of production is optimized to help create the best forged wheel in the industry. BBS forged wheels are not only light, they have been designed to optimize the stiffness to weight ratio while providing the safety and long term durability expected from BBS.
  • 2-Piece Die Forged Aluminum Wheel - Weight optimized by FEM analysis
  • 5x112 Bolt Pattern for 66.6mm Centerbore Fitment
  • CLEARS CARBON CERAMIC BRAKES
  • Wheel Specs:
    • 20x10 et12mm - 26.1 lbs
    • 20x11 et14mm - 26.4 lbs
  • "Standard" fitment. (Vehicles that have been lowered or altered will need to verify proper clearances to the fender and suspension. The tire section width and alignment settings are also important factors.)
The BBS G8X M3 / M4 LM-R 20" Wheel Set may be viewed at the following link to our website:
https://ind-distribution.com/product...r-20-wheel-set
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | info@ind-distribution.com
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
g80
