10-13-2023, 02:15 AM | #1 |
58
Rep 115
F31 Winter tyre choices
I have a set of 18” square 405m’s with Pirelli Sottozero W240 which are reaching end of life and I’m weighing up my options.
According to RealOEM there are 2 winter options, the Pirelli’s or the Continental TS830P which I don’t think are in production any more… I want to keep runflats. When it comes to star marked tyres, presumably this only applies for a specific model? E.g. there are star marked Sottozero 3 but I think these are for the G20? The W240’s have generally been good, but I’ve noticed the back end can be very skittish, sometimes properly stepping out just coming off roundabouts at steady speeds with gentle throttle application. I noticed the same thing with my E91 winters too so I don’t know if this is characteristic of winter tyres or if the ESP just gets it wrong sometimes! I noticed Michelin have released the CrossClimate 2 ZP runflat which I thought could be more suitable for the UK, particularly on milder days but they are not star marked, but since it’s not x-drive I’m not sure how important that is… Surely 12+ years of tyre advancement can offset the benefits of star marked tyres for the F30? Thoughts? |
10-13-2023, 02:46 AM | #2 |
Idiotic lifter of heavy stones...
1988
Rep 2,167
Drives: 2015 F31 325D M Sport touring
No xDrive = use whichever tyres you want
I've gone for Goodyear Vector 4Season Gen3s all round on my freshly refurbed Style 397s, in 235/45/18 size I run 235/45/18 Goodyear Assym6s on my 405Ms for my summer wheels One size wider than OEM (225/45); so no stretched sidewall and a much better turn in feel Camskill are my usual go to; but Asda Tyres (delivered) were £75 cheaper this time around, worth looking Camskill 18" RFT winters: https://www.camskill.co.uk/m11b0s488...Runflat_inc_OE Camskill 18" RFT all seasons: https://www.camskill.co.uk/m141b0s92...Runflat_inc_OE I've gone with all seasons this time round rather than dedicated winters as most driving will be normal day to day with a few road trips up to the Highlands and back I did always run dedicated winters; but now I'm retired from traipsing around the backroads in Scotland looking for stones to lift; they're not needed as much 405M summers: 397 'winters':
My car: 2015 F31 325D M Sport Touring in Glacier Metallic Silver - Keeping it OEM 'Plus'
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298 |
10-13-2023, 02:53 AM | #3 |
2175
Rep 3,103
Conti's TS860 are * marked & RFT, maybe a good option for you. Also being skittish will depend on temperature / tyre wear / age of tyre. Once tyres get older the compound becomes harder, couple that with less rubber on the tread to allow flexibility, a rough surface and that's what you get. I'm no expert in the * rating but my understanding is that it is to do the the overall diameter of the tyres in the manufacturing process and the sensitivity of x-drive to a % wear front to rear. A 225x40x18 tyre will need to be the same diameter (or as near as possible) to a 255x35x18 (standard BMW staggered set up) therefore * rated are deemed to be, where as non * rated may have a bigger manufacturing tollerence so will be out by a margin and not good for the x-drive system. However, in your case with a square set up it may seem locical that if you buy 4No. 225x40x18's of the same type/manufacturer and same age they are all likely to be the same overall diameter/circumference, so the * issue becomes irrelevant ? I'm sure that there are many poeple who don't run * tyres with x-drive and don't have issues? Anyway if you can get the correct tyre at reasonable cost suggest that, even for peace of mind / warranty you just get * rated boots EDIT - Dan you beat me to it !! also just note 340i if F31 not x drive, so as post above * rating not necessary. |
10-13-2023, 03:21 AM | #4 |
1988
Rep 2,167
Just to add to this; the Michelins on Camskill look better priced than the others, so personally I'd go with them if they meet what you need Jim23k
I personally went for the Goodyears as Jon of Tyrereviews.co.uk really rates them and they were right up there with the Michelins on his YT videos; but I ran them on my previous Jap import E30 540i Sport saloon, late last year and through the beginning of the very cold December and they did a superb job... They did need a good scrubbing in; did that in mid Sept 2022 in a road trip around North Wales & Anglesey and back home
Jim23k57.50 |
10-13-2023, 03:30 AM | #5 |
154
Rep 192
I’ve had Michelin Crossclimate+ (the old one) on my F31 for the last few winters.
Yes they’re not as sure footed as proper winters in heavy snow, but for 99% of the time they’re way better as there isn’t such a vast difference to the summers, like there is with winters. Best of both worlds. I live in pretty rural South Yorkshire and we do get proper coverings of snow, with journeys over the Pennines to Manchester etc. I’m personally not bothered about the BMW star marked or even OEM fitment, but respect that you may want to stick strictly to OEM. But yeah, no issues moving away, so long as the sizes are OK. |
10-13-2023, 03:33 AM | #6 |
154
Rep 192
Which brings be to a question I’ve been meaning to ask…
I’ve got my eyes on a set of 397’s fitted with 245/45/18 (square). Any thoughts or experience on whether these will run too wide? I’ve checked and 245 is OK for 8J, but I’m wondering about the inner clearance against the damper/spring seat at the front. danb1979 - do you run spacers with your 397’s? |
danb19791988.00 |
10-13-2023, 03:39 AM | #7 | |
1988
Rep 2,167
I run 235s and there's no issues, but why run 245s, that's one size up again for an 8" wide wheel; 235 is about the idea that should be fitted IIRC, 245s will give you more sidewall flex (experienced that myself, makes for a weird drive TBH) The wheels on mine don't sit flush to the arches, so 10-12mm spacers would work easy enough I reckon (unless you're silly low) The chunkier tyres really fill the wheel/arch gap out well too Can tell the 397s are heavier though, can feel it in the steering compared to my 405Ms I'll soon get used to it
10-13-2023, 08:09 AM | #8 |
2260
Rep 2,051
Like you I won't use non-RFT winters so here are a few cents;
Hopefully some of that is of some use! danb1979 I suspect looking at 245 is same reason I am; 235/45 is not an option in RFT winter tyres unfortunately, only 225/45 or 245/45. And as I've previously mentioned, RFT is non-negotiable for me and sounds like it might be for the OP too. If there was space for a full sized spare under the floor I'd be quite happy to go non-RFT. |
10-13-2023, 12:47 PM | #9 |
1983
Rep 3,216
I used RFT Pirelli Sottozero 18" for 4 winters, they performed brilliantly, even on packed snow and ice (the ungritted lane up past our home is a Strava segment that is 15-17% in places, and the RWD F31 went up it perfectly fine).
I don't think you'll find many better winter RFTs |
10-13-2023, 03:26 PM | #10 | |
2260
Rep 2,051
It's always so difficult to do fair comparisons these things, and it's not as if we're all trying multiple tyres back to back in the same conditions and on the same car. I much preferred testing MTB tyres, much cheaper and much simpler, albeit similarly challenging to get consistent conditions to test in. |
10-17-2023, 06:15 AM | #11 |
58
Rep 115
Thanks for the info all, much appreciated.
I'm leaning towards the CrossClimate's as I'd already seen the decent offer from Camskill right now: Michelin Cross Climate 2 ZP Runflat 225/45 RF18 95Y XL RFT TL £155 with £60 cashback via Michelin promo, allowing £15 fitting/balancing per tyre would make £155 the all-in price which is significantly better value that the full winters. I've asked several dealerships about the Sottozero 3 star marked tyres and they have all said that they would be fine for the F31 (despite not being OE), at 225/45 R18 95V XL RFT* One dealership told me that using non-star marked tyres could have an impact on warranty, however I also called the BMW insured warranty helpline and they told me that tyre choice has no impact on cover (although I could see this being a factor if non-standard sizes are used for an x-drive vehicle). |
danb19791988.00 |
10-17-2023, 06:19 AM | #12 | |
58
Rep 115
Yours looks very glossy! My ceramic coating is still holding up well 3 years down the line. |
danb19791988.00 |
10-17-2023, 06:23 AM | #13 | |
1988
Rep 2,167
Some dealerships do talk tosh at times... You'll be spot on with those tyres; you don't need star rated as your car isn't xDrive etc
10-17-2023, 06:25 AM | #14 | |
1988
Rep 2,167
Glad I stuck with satin black for the 397s too; they suit that colour well and as you said; it's a good contrast in colour and matches the cars OEM black trim etc
11-08-2023, 04:28 PM | #15 |
2260
Rep 2,051
Well my winters turned up today from Camskill. A set of Continental TS850 P SSR in 245/45/18 (ironically both * and MO marked despite not hunting them out). At worst they'll be a max of 1mph over, but I suspect they'll be closer to bang on the money as the PS4S were about 68mph at an indicated 70mph. We'll see once they get fitted. It was already -6c on the way down the road last week so it's definitely time to get them on. I normally get a local guy to fit tyres for £10 each but his machine's out of action at the moment so it'll be closer to £20 each tyre. As there's a local place that does wheel refurbing as a deal for £150 in boggo silver at the moment I'm going to go for that. I think the 396M suit silver best anyway. I'll get them dropped off in the next day or two so hopefully early next week I'll have them on the car. It'll certainly be interesting to see how the ride changes with the bigger sidewalls, despite still being run flats.
11-11-2023, 03:11 AM | #16 |
58
Rep 115
After much deliberation I decided to stick with the full winters and got a set of Continental TS860S SSR * 225/45 R18 95V.
I was quite surprised that my local dealer could supply and fit them for less than the tyres alone cost from Camskill/Black Circles etc which was surprising, so it's always worth talking to their parts department to see what they can do. Still bedding them in but first impressions are good. Very quiet and responsive turn in. One thing to note is there is pretty much no rim protection compared to the Pirellis but I can't remember the last time I kerbed a wheel so fingers crossed this won't be an issue. 405Ms are back on 😍 |
danb19791988.00 |
11-11-2023, 05:23 AM | #17 | |
1988
Rep 2,167
The rim protection is why I went for 235s all round as opposed to the OEM 225 fitments; straighter sidewall too
Jim23k57.50 |
11-11-2023, 02:19 PM | #18 |
24
Rep 35
I bought 4 Continental T870P's (225/45/18) on 400M's last year. Can't fault the all round performance of them in the colder weather plus they worked really well in the snow on my RWD 4 series.
11-11-2023, 02:49 PM | #19 |
2260
Rep 2,051
Oi, stop showing off all your TS860 and TS870's! If only either of them had been easily available in the larger 245 I'd have gone for them, but I decided that snow performance would be sufficient (ground clearance is the issue with these cars more than anything), and I wanted the extra rim protection from craters. I'm just jealous.
I did notice the rim protector seems minimal but looking at Jim23k's wheels above, even the 225/45 seems to have a nice amount of bulge to the sidewall to take the outer point of the tyre away from the rim so hopefully it isn't an issue. |
Jim23k57.50 |
