Bimmerpost
4 Series
Technical Topics Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin Rear Diff fluid at 30,000 miles
      09-18-2023, 08:08 PM   #1
Delighted_Jester
Delighted_Jester's Avatar
41
81
Drives: BMW M340i
I changed my diff fluid last week in my 2020 M340i w/M Sport Differential. I used Hypoid Axle Oil G-4 P/N83222447362. Pictured is the old fluid versus the new G-4 axle oil. I also used the differential tool from FCP Euro B33000000.
      09-18-2023, 11:59 PM   #2
dhock_holiday
211
345
Drives: VW Jetta
Pretty dark for 30K, I guess I’ll be doing mine earlier.
      09-19-2023, 05:52 AM   #3
Delighted_Jester
41
81
Drives: BMW M340i
I think BMW recommends changing it at 60k. Ill do it every 50 with the transmission from now on i think.
      09-19-2023, 08:17 AM   #4
weinerbarn
Unapologetic Tool Hoarder
weinerbarn's Avatar
734
964
Drives: 2020 X5 M Competition
I wonder if a lot of that has to be the friction material from initial break-in. This was from my X5MC at the 1200 mile service. Did you see a lot of suspended metal in the fluid?
      09-19-2023, 01:43 PM   #5
Delighted_Jester
41
81
Drives: BMW M340i
Now that you posted that pic, i feel a little better. I dont really see anything suspended in my fluid. Your fluid looked worse than mine did but being that its only 1200 miles im certain BMW factory filled fluid IS NOT the specified G-4 fluid, rather something else that is "forever fluid".
How did yoy extract the fluid? I used that tool and a $40 oil pump from northern tool. Im sure your diff also lacks a drain plug?
      09-19-2023, 02:07 PM   #6
weinerbarn
weinerbarn's Avatar
734
964
Fortunately the rear diff on mine (F95) has separate drain and fill plugs. I used a "syringe" from Harbor Freight to refill. I think it's called a "Lubricant Suction Gun". I'm probably going to buy one of the ratchet pumps for doing the transfer case and transmission fill. I haven't the oppty to change the fluid yet in either the 540i or M340i yet.
      09-24-2023, 04:31 AM   #7
hayko_M340
139
238
Drives: 2020 BMW M340I
Well that's not good to see, just passed 46K and diff is untouched and "sweating" per dealer. Took it in and they said it's normal per TSB. Gonna try taking it in again before warranty ends to hopefully get a new cover and some fresh fluid in there.
      09-24-2023, 06:02 PM   #8
Delighted_Jester
41
81
Drives: BMW M340i
Sorry to hear about that. If you get a new cover, youll also get new fluid, so i hope they replace it for you! Leaks are never "normal" but some can be ignored. Thankfully my 2020 does not sweat any fluid.
      02-28-2024, 02:17 AM   #9
hayko_M340
139
238
Thought I'd update, got it changed out at 50K and I'm glad I did. Fluid came out looking like metallic nail polish. Measured 700ML that came out and ended up filling 900ML. Clunk/thump severely reduced especially when cold, obvious since it seeped out a good amount. Highly recommend if you plan on keeping long term and if driven hard.
g20
