BMW M8 Forum and 8 Series Forum BMW M8 and 8-Series General Discussion Oil Change Specs
      08-22-2023, 02:46 PM   #1
f93_gc
No_Country
27
67
Drives: 2020 BMW M8 Competition Gran C
Oil Change Specs
Just got quoted $250 + tax for an oil change on my M8 from my local dealer... definitely not paying that much, will just do myself, so just wanted to ensure what im working with.
Can anyone confirm the following?
Type of Oil: 0W-30
Amount: From what I've heard should be about 11-12 bottles worth?
Plan on getting this kit from ECS: https://www.ecstuning.com/b-genuine-...50-slash-12kt/
Any help is appreciated!
      08-24-2023, 09:59 AM   #2
coupeforjoe
18
20
Drives: BMW 2019 M850i
2019 BMW M850  [0.00]
2019 M850i  [0.00]
Type of Oil: 0W-30
You were smart to get a quote on an oil change. I made that mistake
by not getting the price prior to the oil change (only). The stealer charged me over $320.00 for the oil change on a N63 (M850). I would suggest you replace the oil with full synthetic (European) oil. This would answer any questions regarding any (hopefully no) engine problems occurrence on the S63 engine with the warranty.
      08-25-2023, 11:58 AM   #3
Opie55
1213
2,926
Drives: '15 650i Convertible
Type of Oil: 0W-30
Probably can't hurt to have receipts for genuine BMW oil if you have a warranty claim, but it's not required. That's pretty expensive oil. Just get an oil that meets the spec for your engine - LL01 or whatever it is. Your manual will identify the approved oil viscosities. I put Castrol European 5W-40 in my N63TU because it meets LL01 and costs about $35 for a 5-gallon jug. I'd also find out exactly how much oil you are supposed to use. I would think that is readily available info. But if not, I can look it up.
      11-27-2023, 08:37 AM   #4
duar4612
Drives: BMW 840i
Type of Oil: 0W-30
I like to do my own oil changes also. Did you get this done? What did you end up using? Thanks
      11-27-2023, 09:52 AM   #5
Qsilver7
Qsilver7's Avatar
4539
7,588
Drives: F06 650ix GC / F15 X5 50i
Owners manual and iDrive's owners manual will reveal the viscosity required. Also check if the owners manual gives you fluid capacities for the various reservoirs. My N63TU engines take approx 10 quarts...I usually buy two 5 quart jugs of Euro oil from Walmart...which is usually around $25 a jug depending on if they are on sale or not.
You can see example of info about oil viscosity in the owners manual embedded in iDrive on my old 2013 650ixGC which has the old CIC version of iDrive...but this should also be in your newer version of iDrive, too.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
      11-27-2023, 10:02 AM   #6
Qsilver7
Qsilver7's Avatar
4539
7,588
Oil capacity appears to be 10 liters (which is approx 10.5 quarts):
      11-27-2023, 12:42 PM   #7
duar4612
Drives: BMW 840i
QSilver7 Thanks so much for the quick reply. Any specs or diagrams on the filter removal?
      11-27-2023, 04:44 PM   #8
Qsilver7
Qsilver7's Avatar
4539
7,588
Is it up top on the 840?
      11-28-2023, 10:55 AM   #9
duar4612
Drives: BMW 840i
Qsilver7, thanks so much. I'm a newbie picked up my 8 series last Friday, so one last question. I had a Range Rover that had an extractor tube that went to the bottom of the pan that was in the Oil Filler. I see that my 2020 840i does not have a dipstick or extractor tube. Has anyone had success sucking the oil out with an extractor rather than drain plug? Once again, thanks
      11-28-2023, 03:26 PM   #10
Qsilver7
Qsilver7's Avatar
4539
7,588
If you don't have a dip stick...then I don't think suction tools are going to work. There' no direct path to the oil pan to suction out the oil.
Tags
0w-30, bmw, change, f93, m8f93, oil, service
