08-15-2023, 08:04 AM | #1 |
203
Rep 427
North America hitch from Stealth (towing a trailer)
I just got some info back from Stealth Hitch.
They are asking for folks to send an email to info@stealthhitches.com to help push the development of their version faster aka push it ahead of the future development list. I will be nice to have another option instead of 51126889278 https://parts.bmwnorthwest.com/p/Bmw...126889278.html The Stealth version is the one I'm gonna install |
08-15-2023, 09:04 AM | #2 |
12975
Rep 18,719
I have offered my service as their authorized reseller, but no reply from the engineering team.
The sales rep been responsive and forwarded all my inquiries, but no reply.
08-30-2023, 09:49 AM | #3 | |
18
Rep 19
I also inquired about when we can get one, see below. Quick question I assume installing this won’t void warranty would it? Also probably a no go for leased XM?
r33_RGSport12975.00 |
08-30-2023, 11:42 AM | #4 | |
203
Rep 427
I don’t believe so. My dealer did the install on my last x5m and will do this one on the xm when available |
SamKaz18.00 r33_RGSport12975.00 |
01-06-2024, 09:52 AM | #5 |
18
Rep 19
Has anyone put this on their XM yet? I’m ordering one soon curious if there’s any issues/side effects. My dealership said they can’t install it but U-Haul can do 🤔
01-06-2024, 09:55 AM | #6 |
7861
Rep 5,796
Drives: 2024 BMW XM Label
FYI, this does require permanent modification under the rear of the vehicle. Not sure if this makes a difference to you or not. This may be a factor if you are leasing.
01-06-2024, 04:25 PM | #7 |
203
Rep 427
I’ll do a custom install by the dealer in the coming weeks. I’ll buy all the kit from stealth but also the trailer control module from BMW to be able to use all the towing functions and that the dealer can retrofit the 3AC code with ISTA.
fbuzila367.00 |
01-17-2024, 09:18 PM | #8 |
348
Rep 451
Did you do this install yet?
01-29-2024, 04:53 PM | #10 |
203
Rep 427
In progress...
The stealth instructions says to put the pollak on the drivers's side but there's a precut section available on the passenger side. |
r33_RGSport12975.00 XM Label906.00 |
01-29-2024, 09:55 PM | #12 |
7861
Rep 5,796
Can’t wait for the final pictures! How much cutting did they have to do on the bottom? Are they also doing the programming?
01-29-2024, 10:44 PM | #13 |
12975
Rep 18,719
I believe the cutout on passenger side is for the Euro version fold-able hitch.
01-29-2024, 11:25 PM | #14 | |
348
Rep 451
Edit: Looks like Volvo makes the foldable hitch available on at least the XC60 and XC90 |
01-30-2024, 12:03 AM | #15 | |
12975
Rep 18,719
Everything is bigger and heavier in the US.
01-30-2024, 07:50 AM | #16 |
348
Rep 451
01-30-2024, 08:54 AM | #17 |
12975
Rep 18,719
No, because the Euro version is a fixed ball. Can’t be replaced.
I had customer with F85 years ago that wanted to install it. Bought it from Europe, arrived, and found out useless. Not enough rating to tow his boat and different ball size than US. He ended up switched to StealthHitches.
01-30-2024, 08:57 AM | #18 | |
348
Rep 451
01-30-2024, 09:01 AM | #19 | |
12975
Rep 18,719
As you’ve said, even if they do, tow rating is different.
02-01-2024, 03:58 PM | #20 |
203
Rep 427
Photo dump!
It took a while to complete (almost 10h), surely doable in less time for someone used to. Since the socket was put on the right side, they had to make a custom SS bracket for the Pollak connector because I had ordered only the rack from Stealth hitch, the ball, the ball mount and chain anchors. I used the wiring harness and 7-way connector from BMW in the retrofit kit and the trailer module I'm very happy with the result but I didn't test it yet. |
02-01-2024, 04:11 PM | #21 | |
7861
Rep 5,796
02-17-2024, 08:40 PM | #22 |
203
Rep 427
So I finally managed to test the install today for a quick 10 km drive with the empty closed trailer (8x16, around 3200 lbs empty and 400 on the nose). I activated the towing mode and the car adjusted the driving assists aids.
The car behaves well. I was sceptical of not having an air suspension, but for now, there's no concern. If I feel I need more support, I can always use the M mode. The car sank maybe a bit above 1 inch with the trailer. I wasn't able to test electric mode extensively because it didn't want to come on at 120 km/h probably because of too much drag, but it worked at lower speed. The retrofit is 100% functional. As you can see, all the towing gadgets work. I was pleasantly surprised by the trailer assistant. I was backing up with the Idrive controller controlling the steering wheel. It was fun. I'm using a Prodigy RF brake controller which worked well with my X5M before. No problem here. And of course, no problem with my trailer lights nor the parking sensor since I'm using the official BMW trailer module in the retrofit and only the Stealthhitch beam. Last edited by gan23; 02-18-2024 at 07:41 AM.. |
