06-25-2023, 08:54 AM | #1 |
148
Rep 552
Aux radiators to cool oil right or what
What do the aux radiators do in the 8 series? Are they supplementary to the main radiator or for oil or dedicated to the charge coolers?
06-25-2023, 10:03 AM | #2 |
161
Rep 201
There are a few. After shutting down rather engine the fans work still circulating coolant an ( oil ) ? to the turbo chargers .
There are also radiators for oil cooling transmission cooling charge cooling . May find this info in technical data. I am sure mire experienced members here can correct me and give more details. |
06-25-2023, 10:12 AM | #3 |
4603
Rep 3,548
Yea basically what Bulent Ali said is correct.
I forget the layout and total number. There are four separate cooling systems, one is the engine radiator, another is the charge cooler fluid, Oil rads, Transmission rads. When talking about turbo cool down the oil pump runs with a bypass engaged for turbo oil and the charge cooler pump and fans to keep cooling the turbo and engine down after shut off.
2022 M8 Comp Convertible
06-25-2023, 02:18 PM | #5 |
4603
Rep 3,548
Those are for the charge coolers.
Bulent Ali160.50 |
06-26-2023, 11:41 AM | #6 |
20
Rep 31
In 850 option list, there is a “Cooling and High Performance Tire Package” which mentions an additional engine oil cooler.
I assume the above mentioned continues cooling down is something standard without this option? Or I am wrong? I assume normal DD with occasional heavy gas push does not need this option? Can 850 owners have this option tell some feedback? 1550 is not a high price, I am OK to add it just not sure if this fit my purpose, otherwise pointless to add more weight. |
06-30-2023, 07:01 PM | #7 | |
148
Rep 552
If you look up the radiator and upper/lower hoses, you'll also see 'Motorsports package' but most dealerships have no clue what it means. I've called a bunch. The M8 and m850 have the same radiator and aux radiator so maybe there's a smaller version or piping. While the radiator is the same the piping for m8 is different so I doubt the inlets will work. However the best way to find out is to try! I'm doing some experiments now on other parts and will report back. |
07-03-2023, 09:20 AM | #9 |
148
Rep 552
https://autotecknic.com/products/cr-...-f90-m5-f9x-m8
These should fit the m850 so those of you with a tune, especially a Stage 2, this is probably advisable if you push the car repeatedly. I'm adding a push fan to the main radiator using this company: https://deltapag.com/products/18-bru...32780849479742 The push fan will help on slow downs such as turns, breaking, or in dd during traffic. |
07-03-2023, 10:00 PM | #10 |
259
Rep 5,012
I live in hot TX, where it's routinely above 100F for months, so I'll absolutely get that 'cooling' package, whatever it is. But I think the 2 lower side ones are for the turbo intercoolers.
