Bimmerpost
4 Series
Technical Topics Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin How to reset break service warning
      05-21-2023, 05:30 PM   #1
Bamaleon
Drives: 2023 BMW M4
So I own a 2023 M4 and have tracked it to the point that I missed the wear on the rear brakes and had the sensor come on. I have changed the brakes and wear sensor even though it looked fine but am struggling to clear the wear warning. I have read several threads about getting into the diagnostic setting by closing the door, seat belt on, ignition on but not started, showing P in the display, hitting the start 3 times rapidly, and then holding the BC bottom until the selections show up on the display. This is where the issue is. I only have 3 choices - Oil change, brake fluid change and inspection. No brake choices.
Would really appreciate someone telling me what I am missing.
Thanks.
g20
