Bimmerpost
4 Series
Technical Topics Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin B48 coolant system diagram
      02-05-2023, 07:51 PM   #1
bimmerboy71195
bimmerboy71195's Avatar
68
115
Drives: alpine white 340xi
My 2021 330 is losing coolant in the main reservoir I don’t see any leaks on or under the car I purchased a coolant pressure tester kit I’m just curious if anyone has a official bmw coolant diagram to show all the compents in this system and also the smaller tanks cooling system thanks
      02-10-2023, 05:43 PM   #2
1WickedE90
1WickedE90's Avatar
198
1,009
Drives: 2022 330i
https://bimmercat.com/bmw/language/en
Try this site. I would bring it to the dealer as your car still seems to be under warranty period. Good luck!
      02-10-2023, 07:51 PM   #3
iv-128i
bmw
iv-128i's Avatar
46
238
Drives: 2017 m240i, prior : 2011 128i
2011 BMW  [0.00]
It seems to be a pretty common issue on b48 and b58 engines. I had it loosing coolant on my m240i and same now on my 2021 330i . My wife X2 has the same problem which became a bigger problem over time and she started loosing coolant very quickly. It ended up being a faulty/leaking coolant/water pump. Bmw replaced it under warranty. Not saying that it is your issue as well but so far for my m240i or 330i BMW is never able to find what is the problem even with pressure tests. They just say to continue top-off as needed and it is normal lol 😂
M240i F23
      02-15-2023, 05:36 PM   #4
bimmerboy71195
68
115
So I performed a pressure test today for about an hour and couldn’t find any leaks. While inspecting I noticed tons of dried up coolant all over the water pump I’m certain this is the cause of my very very slow coolant loss. I’m curious as to what part of the pump could be letting coolant seep out could be a gasket for the feed line or the return line but then I wonder if it could be leaking from the shaft that spins the pump itself.
g20
