12-09-2022, 09:26 AM | #1 |
BMW obsessed
9596
Rep 10,884
IND | MMR Performance G42 M240i Lowering Spring Set
The MMR Performance Lowering Spring set for the BMW G42 M240i delivers the perfect blend of improved dynamics and enhanced looks, yet without sacrificing ride quality. The 30 front / 25mm rear drop in ride height brings the G42 to life making it feel lighter, more direct and with significantly sharper turn-in. The MMR Performance Lowering Spring Kit is one of their best-sellers. Little wonder, as they've earned a reputation for delivering the perfect blend of improved handling, enhanced looks, yet all without sacrificing ride quality. The drop in ride-height makes a huge difference to the handling characteristics: by lowering the M240i G42's centre of gravity, it reduces body roll for better dynamics, whilst maintaining the ride quality and comfort of your car. Thanks to the carefully selected progressive spring rates the ride-quality remains unaffected and is actually nicer to drive at slower speeds. But push-on through the corners and the G42 chassis really comes to life, making it feel lighter, more direct and with significantly sharper turn-in. Just what the M240i needs. Meanwhile, the car's appearance is transformed. Our development has resulted in the springs providing a drop at the front of 30mm whilst the rear sits lower by 25mm. By getting rid of those nasty wheelarch gaps, it'll look just how it should have come from the factory! Go lower or stiffer than these MMR Springs and your car will bounce and crash as the dampers are mismatched to spring-rate, and the springs themselves run out of travel. Finished in MMR Metallic Grey, the Sport Springs are developed to be fully compatible with cars fitted with either static or Adaptive M adaptive dampers. A must-fit for any M240i! Product Details:
The MMR Performance G42 M240i Lowering Spring Set may be viewed at the following link to our online store: https://ind-distribution.com/product...ing-spring-set Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com
