06-20-2022, 06:40 PM | #1 |
Rep 3
2021 M550i Oil related question.
Good evening everyone and thank you for letting me join this group.
I just purchased 2021 M550I WITH 15000 Miles yesterday. First ever BMW and Already for a famous sidewall bulge on my Pirelli tires I have 0 knowledge. All the previous vehicles were Corvettes :P Main question is I plan to get engine oil changed pretty soon at the local BMW dealer and how good are the OEM Oils? seems like Liqui moly is famous... Other than this, any maintenance that I need to look for? P.S There is no way to display engine oil temp on this vehicles?????????? Thanks in advance! |
06-20-2022, 07:45 PM | #2 | |
154
Rep 290
Drives: 2021 m550i
Regardless what BMW tells you, change the oil every 5000 miles, not 10000. Also, I've had them put another oil by accident and they drained and refilled with the correct oil when I showed the service paperwork, so make sure LL01 is mentioned during your visit. You can code the oil temperature in the sport menu using binmercode, or access it using the hidden menu as described here: Instrument Cluster Test https://g30.bimmerpost.com/forums/sh....php?t=1415845 ** Edit ** I have to double check but I think if you go to the full sport display screen on the 2021 it shows the oil temp without coding. |
Mosaud19983961.00 |
06-21-2022, 05:38 AM | #3 |
445
Rep 750
OEM change schedule is 20k, if you do tons of short trips, drive the car hard, live in extreme conditions or all three, changing the oil more regular is fine. I personally do every 8-10k. Every 5k feels like a bad deal for the environment if we all do that!
06-21-2022, 09:36 AM | #4 | |
3961
Rep 2,657
Drives: 2019 BMW 540
Current: 2019 BMW 540 (AWD)
Sold: 2009 BMW 328 (AWD) Last edited by Mosaud1998; 06-25-2022 at 08:25 AM.. |
06-25-2022, 12:35 AM | #5 | ||
1509
Rep 1,487
Motul X-Cess 5W40 GEN2 would be my go to. Liqui Moly is mediocre oil but they are pushing their oils hard to shops pitching as "German oil fir German cars." Take into consideration that no German manufacturer uses Liqui Moly products. Any products! |
Mosaud19983961.00 430Scud253.00 |
06-28-2022, 06:12 PM | #6 | |
Retired Curmudgeon
2985
Rep 4,047
Manufacturers use oil for a very specific reason: cheapest that meets their spec and won't cause them any warranty issues. I don't know that I'd read too much into what car manufacturers do. I want to be clear, I'm not saying Liquimoly is awesome or even acceptable, just saying I don't think relying on what a car manufacturer chooses to use in a car is always in the consumer's best interest.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
06-28-2022, 07:40 PM | #7 | ||
1509
Rep 1,487
Liqui Moly cannot nor it will be able to offer what Shell, Mobil1, Castrol etc. can. Redline falls into same category, though Ravenol is bit more serious and capable company. Contracts involve development, racing, marketing etc. My point was that Liqui Molys marketing revolves around Made in Germany BS. |
07-18-2022, 01:37 PM | #8 |
7390
Rep 6,780
Drives: '18 M550i|'21 X5|'03 540i
Garage List 2013 VW Tiguan [0.00]
2015 Infiniti QX60 [0.00] 2021 BMW X5 [0.00] 2003 BMW 540i [0.00] 2018 BMW M550 [10.00] |
Per the manual, BMW spec is LLF01 or LLF 14 0W-20/30 or 5W-20/30. The LLF01/14 is the most important part to pay attention to. Personally, I use LM LLF01 5W-40 all year round. My performance shop swears by it. When I was using BMW 0W-30, I had consumption between oil changes. Since switching to 5W-40 I have zero consumption. Something doesn't sit well with me about a super thin oil that burns off.
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| |
09-30-2022, 10:48 PM | #10 | |
253
Rep 298
Personally, I believe LL-01 would be superior with a higher HTHS (high temperature high sheer) rating...but may conflict with warranty. At the dealer, always request the 0w-30 over the 0w-20 when given the choice. The 0w-20 has a very low HTHS rating |
Joe-BMW337389.50 Mosaud19983961.00 |
10-05-2022, 12:44 PM | #11 | |
Retired Curmudgeon
2985
Rep 4,047
430Scud253.00 |
10-05-2022, 08:49 PM | #12 |
3961
Rep 2,657
I used LM 5W-30. I haven't noticed anything abnormal so far. I don't think using another weight oil is going to void warranty as long as it is BMW-approved.
Sold: 2009 BMW 328 (AWD) |
10-14-2022, 04:33 AM | #13 |
37
Rep 164
I am using Castrol Edge 5W-30. BMW recommends to change oil after 30k kms (20k miles), but I change the oil each 15k kms (10k miles). Consulted with engine specialists and go by their recommendation - I want my car to last. I get no oil consumption between the changes.
11-15-2022, 10:39 AM | #15 |
7390
Rep 6,780
Nope, but I use Liqui Moly 5w-40. I switched from 0w-30 at my shops recommendation. When I used to use 0w-30, I would consume a quart or so between changes, with 5w-40, no consumption.
11-16-2022, 12:42 PM | #16 | |
Retired Curmudgeon
2985
Rep 4,047
Have a kolache for me. My Czech grandmother used to let me help her make them!
11-16-2022, 09:06 PM | #17 |
1509
Rep 1,487
11-18-2022, 06:14 PM | #18 |
104
Rep 934
So does this mean that QS Euro 5W-40 is just as good as the Pennzoil Euro? It is supposedly the same stuff
11-18-2022, 08:25 PM | #19 | |
1509
Rep 1,487
Current PPE 5W40 API SP is better stuff. Lower KV100 and higher HTHS. It has more GTL, potentially PAO. Pour Point in PPE indicates more sophisticated base stock. |
12-30-2022, 04:32 PM | #21 |
148
Rep 134
Just for some input I am going to be doing the following maintenance cycle that differs from BMW recommendations on my M550.
1. oil changes every 5k 2. Transmission fluid change at 50k 3. Transfer case fluid change at 50k |
admranger2984.50 |
12-31-2022, 11:36 AM | #22 | |
Retired Curmudgeon
2985
Rep 4,047
The PITA about the transfer case is that xdrive fluid is $60/liter (you need less than 1 liter iirc) and then you need to reset the clutch adaptations after putting in the new fluid. That has to be done with a scan tool with BMW software, not a generic one iirc. I have a buddy with a shop so it's easy for me, but DIY folks need to know it's not like changing out the diff fluid.
