03-21-2022, 12:28 PM | #1 |
Chief Petty Officer
645
Rep 518
Autocross Tires
Anyone scooped up some 200 TW tires and put them to the test yet?? Any recommendations for size? My G82 xdrive should be here next month (hopefully) and I'm sure it'll hunt some cones sooner rather than later. I'd like to get some tires on order soon so I dont end up waiting forever.
03-21-2022, 12:32 PM | #2 | |
1449
Rep 924
Try the r888r , they heat up quickly and are available in oem sizes.
2023 F90 M5
Retired - 2021 G82, 2019 440xi, 2020 X7, 2019 X5, 2013 F10, 2010 F10 |
03-21-2022, 12:49 PM | #3 |
Chief Petty Officer
645
Rep 518
R888R is a 100 TW tire. Can't use in street classes, and as you mention the Cup 2 isn't a preferred tire either. Doesnt seem like many manufacturers make a tire that would work well on this platform yet.
03-23-2022, 03:52 PM | #4 | |
18769
Rep 14,121
Drives: G82 M4C X-Drive
04-04-2022, 07:00 PM | #5 |
Chief Petty Officer
645
Rep 518
I've decided to go with a square set up of the yoke A052 in a 275/35/19 on a 19x10 +20. The A052 may say 275, but the tread width is 10.2 inches, which is an inch wider than the stock P Zeros, and 1.3 inches wider than the stock PS4S up front. Hell, the 285/30 stock rear is only 10 inches wide.
Anyone know of a reason why this wouldn't work?? |
08-31-2023, 03:23 AM | #6 |
17
Rep 13
How was your experience with 275 a052 squared?
I just received 4 of them and I am not sure whether to run them squared on stock 9.5Jx19 wheels (I have 4 of them) or just combine it with cup2 285/30 20 in the rear. Trackdays and amateur races. |
12-15-2023, 06:52 PM | #7 |
486
Rep 274
Drives: 2023 M3 Comp
Following…I also have a set of stock 19’s and looking for xdrive tire setup for track.
