09-28-2021, 04:10 PM | #1 |
526
Rep 469
2022 M8GC amd Racechips not playing well.
Well!......
Looks like the 2022 M8 GC and the Racechips doesn't play well. Had to make a trip between Houston and Austin today and had some good strips of Mexican road along the way. Loving the added power of the racechips I felt like it was definitely time to open it up. Having ran the M8GC past 160mph prior I was ready to do the same with the Racechips in place. Had everything set to full bore and in S3 on the trans setting.... cars cooking and then wam!!! Hard defuel at 130mph which was mid 6k rpm in 5th and Check control light(drivetrain), and had figured it was associated with paddleshifting. Got to a gas station turned car off, yellow wrench light goes away. Go to do it again all the same with not paddles and same thing happens at exact same spot in the RPM/speed range. So I went and turned the car off again and turned the racechips off. Go to do another run without the racechips and the cars pulls just fine businesses as usual 150mph+. Going to call racechips tomorrow, but by the looks of things it's not playing well with the higher rpms and the 2022 M8s. |
09-28-2021, 04:42 PM | #2 |
4555
Rep 3,516
I've had issues with piggy back before, I tend to do flash tune or bench tunes, but then again I do that because if I plan to tune any car I do it deep, because I know warranty work will always be risky. lol If I due tune my M8, I'll probably go bigger turbo route and bench tune.
2022 M8 Comp Convertible
Resjudicata1604.00 |
09-28-2021, 05:53 PM | #3 | |
384
Rep 164
r33_RGSport12983.50 |
09-28-2021, 06:08 PM | #4 |
12984
Rep 18,723
Yea, OP called earlier.
Unfortunately, I can't help much since unit wasn't purchased from me, so I can't see which map version that he is having.
moonM8384.00 |
09-29-2021, 09:04 AM | #5 |
526
Rep 469
Spoke with Racechips today and based on what I experienced the main tech (who sounded like one of the guys in their videos that does the dynos) stated that likely being I had the car set to level 7 and the control popped up that the car I have is making more power from the factory than their test car from the factory and its hitting a power parameter failsafe that's in place from the factory that they obviously don't touch.
Essentially he stated to try running a lower setting then working up from there. |
09-29-2021, 08:02 PM | #6 | |
4425
Rep 4,109
Good luck with yours! |
09-29-2021, 09:01 PM | #7 | |
1604
Rep 2,937
09-29-2021, 09:07 PM | #8 |
526
Rep 469
09-29-2021, 10:16 PM | #9 | |
4425
Rep 4,109
09-29-2021, 10:19 PM | #10 | ||
4425
Rep 4,109
09-29-2021, 10:57 PM | #11 | |
379
Rep 389
I Myself returned the racechip and got the jb4 because i did not feel any difference between map 1 and 7 with racechip I am not sure if my racechip unit was not good or why i did not feel a real bump in power like i felt with jb4 even on map 1 |
09-30-2021, 08:17 AM | #12 | ||
4425
Rep 4,109
09-30-2021, 10:32 PM | #13 | |
526
Rep 469
I've been keeping it on 7 still since running to 130/6299 rpms I'm 5th isn't a norm and it performs just fine. I'm going to try and find an AWD dyno near me and see whats what. I'd be curious what oem output is. |
10-02-2021, 12:30 AM | #14 | |
118
Rep 123
After trying a couple different tweaks the RC techs told me that it would not be possible to make it work. Maybe there is something on our 2022’s that they have not figured out yet. I went the JB4 route and it worked out. |
10-02-2021, 12:40 AM | #15 |
118
Rep 123
Hey Limey, your car was running great times with JB4, why did you go to RC ? Are you running better times now?
10-02-2021, 09:29 AM | #16 | |
4425
Rep 4,109
10-02-2021, 12:16 PM | #17 | ||
1604
Rep 2,937
10-02-2021, 02:50 PM | #18 | |||
4425
Rep 4,109
Resjudicata1604.00 r33_RGSport12983.50 |
10-02-2021, 05:59 PM | #20 |
4425
Rep 4,109
10-02-2021, 06:27 PM | #21 | ||||
1604
Rep 2,937
but I don't recall the post or who posted it. |
10-02-2021, 06:31 PM | #22 | |||||
4425
Rep 4,109
moonM8384.00 r33_RGSport12983.50 |
