09-24-2021, 12:38 PM | #1 |
9077
Rep 7,630
Fuse box location
I'm considering hard wiring a radar detector, but don't want to use the mirror tap as I want to put it in a different location. Anyone know where the fuse box is and how to go about tapping it for a detector? Which fuse that is.
09-24-2021, 11:05 PM | #3 |
9077
Rep 7,630
Thanks. I'm looking to put it in the lower left window. I know not ideal for signal, but I've always had it down there and it's down out of the way. I don't like it hanging right below the mirror and if I put it high up on a side of the windor you can't put that visor down. Perhaps I could run a mirror tap down to the corner of the window.
10-05-2021, 08:26 AM | #4 |
30
Rep 36
i'm trying to get to the fuse-box under the glove compartment,
but having a moment removing the panel entirely so i can gain access. there are two plastic turn-to-release bolts which are easy. then there is a wire-harness for a little light on the underside of the panel. i was able to detach the harness itself using a paper-clip to push in the little tab to pull out the harness. now the wire itself is attached to the panel with another attachment clip and i can't figure out how to detach it from the panel to remove the panel completely. anyone get through this step that can share some detail? |
05-18-2022, 03:49 PM | #5 | |
1091
Rep 401
