04-24-2021, 02:26 PM | #1 |
12
Rep 18
330E Engine Lottery
Has anyone worked out the B48B20A or B48B20B logic? Definitive rule?
Is it saloon vs touring? RWD vs xDrive? Stock car vs custom options build? Trim level? LHD vs RHD? Etc. |
05-20-2021, 07:38 AM | #3 |
141
Rep 395
Check the label on the engine
https://g20.bimmerpost.com/forums/sh...2#post27096582 |
06-03-2021, 03:10 PM | #6 |
Rep 9
it do seem really random, the same day as i got mine someone else got one and we talked for like 15 min and found out the i got the B and he have the A. both are m-sport so seems really random.
06-03-2021, 03:37 PM | #7 |
219
Rep 262
So I need to clear the air - what's the difference? I have a B46D 330i as most if not all in the USA do, but why the prodding into the engine code? Is there really a difference between engines with different alpha characters? Besides the obvious numeric B46/B48 SULEV differences..
06-05-2021, 12:06 AM | #8 | |
153
Rep 280
If you are in the US and have a non hybrid 330 you have the B engine The distinction between A and B are as follows The A engine is used exclusively in 20i and 30e models, the B engine is used in both 20i,30i and 30e models. The engine differ in many of their components which affect how much you can push them with stock parts (the most obvious and major difference is the A engine utilizes higher compression pistons which limit the boost you can make) When the B engine when utilized in the 20i application it's detuned in purely software compared to the 30i application Last edited by Knifeedge2k1; 06-05-2021 at 12:24 AM.. |
bquatt218.50 |
03-06-2023, 10:48 AM | #9 |
BIMMER LOVER
Rep 16
I am considering buying a 30e and want to know if there are any differences, and also, if there are any ways to accurately tell if I have the B or the A variant.
Is bimmercat 100% accurately if I go and check the short engine code? I also have access to TecDoc Catalogue as I own a car parts store, would it be more accurate? |
03-08-2023, 05:01 AM | #10 | |
64
Rep 142
Drives: BMW 330e 2021
Bimmercat is probably not accurate since AFAIK they stopped updating some time ago when BMW starting to ask for money for that information. |
03-10-2023, 04:59 AM | #11 |
18
Rep 30
Drives: 2023 330e
Outside the US, that is possibly true. The 2023 330e I took delivery of in January has the B engine (US 46 version). The 320i isn't sold in the US so it's likely easier to consolidate to the single 46B engine for all US cars.
03-10-2023, 05:44 AM | #12 |
64
Rep 142
Note the 46 can be both the A or B (it was C or D for the 46 or the other way around? Don’t remember), what is the exact code on your engine bay?
03-10-2023, 05:48 AM | #13 |
64
Rep 142
I just saw that BMW USA list the 330e compression ratio as 10.2 (which is really the only difference because of the piston heads) so it looks like you lucky bastards are getting the B.
03-13-2023, 09:54 AM | #14 |
Rep 18
Any news with getting 20b engine in Europe?
I checked 5 cars at German market dated 07-10/2020 almost all of them come with 20a:-( I'm looking for xdrive touring and cannot find any... Seems have to switch to smth like m340d while was so excited with this PHEV... |
03-14-2023, 08:17 AM | #15 |
36
Rep 82
Same; 2023 330e. Nobody has mentioned the country of origin--it wouldn't surprise me if Mexican production only has the B variant available.
E92 335i/G20 330e
05-02-2023, 02:21 AM | #16 |
64
Rep 142
02-20-2024, 12:29 AM | #17 |
421
Rep 510
any update on this - do we know which engine 2023 330e is coming with since the change to mexico production?
2023 G80 M3
www.instagram.com/modern.classica |
