01-23-2021, 02:46 PM | #1 |
1641
Rep 2,286
Torque Specs Wanted for Strut Brace/Bar Screws
All,
I'm trying to gain access into my air box, but it seems the only way to get into it, is by removing the strut brace/bar. Removing this isn't a problem but when I re-tighten the E16 and 16mm screw/bolts that hold this in place, I would want to do it back to factory sepc. Does anyone know the torque specs this is tightnened to? I don't want it to cause any issues (structurally etc) if it was just tightened to 'feel'. I found a post online that said it maybe 250nm but with newtis not working anymore (for free), I can't confirm. TIA
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black |
01-24-2021, 01:14 AM | #2 |
163
Rep 321
250Nm, no way! That'd shear that bolt right off! It's one order of magnitude off
Spec for that bolt is 56Nm jointing torque with an additional 90 degree rotation.
2018 G30 540i xDrive M Sport | Carbon Black Metallic | KW V3 Coilovers | F90 Suspension | F90 Brakes | 20" HRE FF10 Liquid Black Wheels | Michelin Pilot Sport 4S Tires | Ivory White Dakota Leather | Carbon Fiber Trim | Executive Package | Bowers & Wilkins Diamond Surround Sound System | JL Audio 12W6v3 and XD600/1v2 | Ceramic Controls | BM3 Stage 2+ E50 ECU Tune | xHP Stage 3 TCU Tune | Dorch Stage 2 HPFP | MST Cold Air Intake | FTP Chargepipe | AA Catted Downpipe | Remus Catback Exhaust
admranger2989.00 |
01-24-2021, 03:34 AM | #3 | |
1641
Rep 2,286
When it says renew screw, does that mean use a new one after its been taken out or just put the same one back on? Thanks again, much appreciated.
IG: project540ix
01-24-2021, 11:56 PM | #4 |
163
Rep 321
Technically whenever it says renew it means to use a brand new part and throw away the old one. The reasoning is since the bolt is torque to yield, it slightly deforms every time that you tighten it down. However, for something like this strut bar, I doubt it matters. I've personally re-used TTY bolts in non-critical components (i.e. I wouldn't re-use TTY bolts securing the oil pan or wheel hub) without major consequence. But, that call is yours to make! Btw, PM me if you're interested in newTIS 2.0
Junebug851641.00 |
02-27-2021, 12:57 AM | #5 |
570
Rep 1,295
Hi, i’m also looking for the torque specs for the main strut bar that connects the two strut towers, would you have this? I’m replacing the g30 one with the f90 m5 variant, hoping to tighten the chassis a bit
02-28-2021, 05:22 PM | #6 | |
Retired Curmudgeon
2989
Rep 4,056
Bolts of the same diameter and made from the same materials typically have the same torque spec. Check to see if the ones for the brace you're looking at have the same diameter as the ones referenced above. TTY bolts make sense for the manufacturer and no one else really. Head studs, rod bearing cap bolts, and now even oil pan bolts are TTY. I'm old school and prefer studs with a set torque value even though I have a Snap On Techangle electronic angle torque wrench. When I did the rod bearings on 3 S65 (E9x M3 engines) I used the BE Bearings and special ARP rod bearings. Easy. No fussy angle torquing working over your head.
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
