01-07-2021, 05:58 PM | #1 |
11
Rep 31
Mirror cap removal on a 2020
I am unable to remove my mirror caps. I popped the glass off-easy. Released the two catches behind the glass and pulled the cap back far enough that they stay released. Found 2 teeth on the inboard side of the cap and slipped it past them. After that, it will not budge. It seems there is a catch or catches on the bottom section below the blinker as that would not budge and there is not even enough room to get a trim tool in the crack. There are no current videos online that address this. Any suggestions? Thanks.
01-08-2021, 01:31 AM | #3 | |
1641
Rep 2,286
Found this video too which might help you-
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black |
01-08-2021, 03:35 AM | #4 |
11
Rep 31
No, I've seen that video and it is not helpful. There is something else holding the cap on besides those 2 main fasteners. As mentioned, I even removed the glass to have complete access. I had those fasteners completely released and the cap pulled back beyond them. I applied significant force and it would move no further. The bottom of the cap would not separate at all, that's why I suspect there is something else holding it.
01-08-2021, 08:58 AM | #6 | |
1641
Rep 2,286
IG: project540ix
01-08-2021, 09:03 AM | #7 |
1641
Rep 2,286
Pics...
IG: project540ix
01-08-2021, 04:42 PM | #8 |
11
Rep 31
Thanks for the pics. Didn't your blinker remain in the cap when you removed it then you removed those 2 screws? I did not expect the screws went through the frame then into the cap. Did the fastener at the arrow need to be released?
01-08-2021, 06:17 PM | #9 | |
1641
Rep 2,286
That arrowed fastener needs to be prised with the trim tool. On the first one I just used force and pulled it off but was lucky the clips all remained intact. On the second one, I knew where the clips were and worked the trim tool in that area.
IG: project540ix
01-09-2021, 03:37 AM | #10 |
11
Rep 31
It seems like that fastener might be an issue then. I am unable to get a trim tool even close to it nor can I get the inboard side of the mirror at the bottom to give any. Seems like the whole bottom won't release.
01-10-2021, 01:23 AM | #12 |
539
Rep 1,201
You need to brute force prying it off with a trim removal tool. Once you release the two tabs from the inside, use a trim removal tool to work on the outside, left to right or right to left. Just slide the tool into the crack and pry towards the outside as you go from one side to the other, and the cap should come off easily.
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD) |
Tags |
cap, mirror, removal, wing |
