11-17-2020, 12:02 PM | #1 |
1231
Rep 2,602
Brake Shudder
Does anyone else experience what feels like brake shudder when threshold braking on track? Seems to happen when slowing from triple digit speeds. It's been the same since my first track day with the car through my latest.
It may not be the rear brakes but its felt in the seat of the pants, not the steering wheel or elsewhere. If I ease into the brake or brake a little lighter it doesn't occur. A friend said he felt it in his M2C. Some have suggested its the rear toe changes as the rear gets lighter, others the rear brake bias. Thoughts?
2020 X3M non-comp, Alpine White over black : Exec Pkg, ventilated M Sport seats, 20"s
2020 M2 Comp, Sunset Orange/Blk: Orange stitching, DCT, exec pkg, bicolor rims Gone '18 M550i, '16 X4 M40i, '15 M5, '13 X3 35i, '12 335is, '11 X5 50i, '09 Z4 35i, '08 550i, 06 X3, 06 650i, '02 M5, '99 540i |
11-17-2020, 12:26 PM | #2 |
3360
Rep 1,823
I’ve never gotten it in my OG M2. I know it doesn’t help. As for thoughts, first thing that came to mind was #neverlift
11-17-2020, 12:37 PM | #3 | |
1231
Rep 2,602
We also had a session in the rain. Less brake effort meant no shudder. The last 2 sessions I learned to ease into the brake, reducing the feel of it. Check out exactly 1:00 into this video, you can hear the GoPro mount vibrate from the shudder. https://vimeo.com/476870974
11-17-2020, 01:21 PM | #4 | |
524
Rep 584
1. Being on the brakes while sitting in the paddock after coming off from a hot session and burning brake pad material onto the rotor 2. Bad bearings (not likely) 3. Cracked pads 4. Not properly bedding in new pads with different material than previous pads 5. Changing pads, using old rotors. In my experience, I could comfortably get through a second set of front pads on old rotors, but by the time I get to the third set, the surfaces are just too different and the effect is severe judder I've experienced all of the above with the exception of 1, because I know better, and 2. My suggestions would be to first take a look at the pads and make sure you have more than a backing plate's worth of material and that there are no cracks. A cracked pad would be obvious. If all good, then likely the problem will eventually work itself out given enough time. I've had judder so severe on new pads before that it felt like the wheel was going to fall off. I actually had to check to make sure I didn't put them in with the backing plates facing the rotor. Just really hammer on the brakes for every corner, every session. I know you say you are threshold breaking, and I don't mean to question whether you are, but really get on them to where there is a slight lookup. Do this for a couple of track days and it should go away. Also, if you run with any of the nannies on, not sure how this can affects the brake feel.
2017 BMW M2 5Spd, 2007 VW Touareg, 2023 Yamaha MT09 SP
https://www.instagram.com/dvas99/ https://www.youtube.com/channel/UC2j..._as=subscriber |
11-17-2020, 01:58 PM | #5 | |
3360
Rep 1,823
It does feel like brake shudder. What pads are you using? I got a steering wheel shudder with Carbotech/GLock pads before on my Mustang. Felt like a low frequency vibration, but I mostly felt it in my steering wheel.
2017 BMW M2 German Spec
6MT, Driver's Package --> SOLD 2018 Camaro SS 1LE. Because race car! "Redline a day keeps the mechanics away" |
11-17-2020, 02:16 PM | #6 |
1231
Rep 2,602
Thanks for the replies so far.
It's stock pads and sufficient depth per the track inspections. Last fall they were near new with < 6k miles. I recall doing a light bedding in drive after returning from track last fall but each track day has felt the same, no better no worse although a good bedding in exercise wouldn't hurt. It will probably be spring before my next event so I may look into fresh track pads before then..... PS: Yes I've gotten on the brakes hard enough to activate ABS at times on track, mostly when miss judging the braking point for a given speed. PS: Even though I termed it brake shudder, I've had that before and this doesn't feel the same. More like the car is hopping on bad pavement but it's consistent in any high speed braking zone. I have few places to experience it on the street... maybe a nearby off ramp. But officer, I was only doing 100 mph to test the brakes.
5.M0NSTER3359.50 |
11-19-2020, 12:45 AM | #7 |
13
Rep 96
Had a massive issue due to warped stock rotors which feels like doesnt handle heat as well as some aftermarket rotors. Went to the exquis kit and never had the issue again.
This was for m2c with the original blue brakes not the new one.
Currently Driving:
Porsche GT4 '20 BMW M2C '19 Caterham S3 '01 Porsche 993 '96 Last edited by kvnchu; 11-19-2020 at 12:51 AM.. Reason: added information |
11-19-2020, 05:33 AM | #8 | |
518
Rep 744
Its happened to two of my friends with F80 and F82s. Search the forums and u will find tons of posts on it. Solution: Buy trackpads, bed them in, scrub the deposits, get vibration free brakes
AX 1.1 --> AX GTI --> NA Roadster 1.8 --> E39 528i --> Xsara VTS --> Volvo 940 LPT --> Focus RS MK3 --> M2C + NA Miata 1.8
11-22-2020, 06:57 PM | #9 | ||
3995
Rep 3,412
Street pads especially OEM aren't ideal for the track even at novice level. The brake shudder is real and super frustrating...
Not a Doctor, those are just my initials.
11-23-2020, 03:19 AM | #10 |
518
Rep 744
I had track pads for the M2C months before I even got it lol.
11-23-2020, 08:51 AM | #11 | |
3995
Rep 3,412
Ever tried a flex hone brush? Might be worth running over your rotors.
11-23-2020, 02:11 PM | #12 |
1231
Rep 2,602
I do need to get the car out and do a bedding in procedure. I've had good success cleaning rotors in the past.
However I don't think that is the problem. With pad deposits before, I've had low speed pulsing in the brake pedal with light pressure and a more chatter/out of balance feel at interstate speeds and moderate pressure. And can feel it in the brake pedal. What I'm experiencing is only from high speeds and threshold braking effort that feels more like wheel hop, or possibly rapid uneven braking side to side in the back. But I don't feel it in the pedal. It's not ABS as that is a different feel and sound all together.
