08-16-2020, 09:12 PM | #1 |
69
Rep 165
RIP to my track car engine
At the end of one of my best track days this year, my engine decided to seize.
I was cranking away overtaking cars all day. It was 80 degrees in WA state and the track was hot. After my last session of the day I pulled into the paddock to pack up all my track stuff. I stopped, put the car in gear, turned it off and went to the bathroom. Came back, packed up my car, and it wouldn't turn on. I checked the fuses, battery etc and the car was saying there was a starter issue. A few of my buddies decided we should push start the car since AAA won't come pick up cars from the track. We push started the car and it started running. I drove the car on the highway for about 10 miles and then the car started flashing with drive train malfunction, then low oil pressure. I pulled over on the freeway and called a tow truck. After 6 hrs of waiting and towing I was finally home. The DME codes read VANOS issues. I replaced the starter, VANO solenoids, battery, checked all fuses, checked the starter relay box, literally everything I could think of. The car still wouldn't turn over. I decided to try to bar over the car from the front crank nut and the engine won't turn over. It's toast. I checked the oil filter for metal but there is nothing. The engine oil was just replaced by a local shop one track day before the last one where it crapped out. A buddy is coming to get it who is a BMW tech. I'm pretty sure it's done. I just dialed in the JRZ suspension and everything. Super bummed! |
08-17-2020, 12:59 AM | #2 |
1406
Rep 5,262
https://www.2addicts.com/forums/show...ght=starvation
this car is not designed for this kind of use apparently Was that pacific or the ridge ? |
Poochie9107.50 |
08-17-2020, 03:49 AM | #3 | |
Luxury at the redline :)
9108
Rep 7,563
It's a sporty street car, not one for negotiating high Gs, on the track.. OP, check online for a used N55, maybe the M2 version, with the enhanced oil pump and suction.. It would be a play and play job.. Good luck. |
08-17-2020, 10:55 AM | #4 |
Joint Chiefs of Staff
24378
Rep 191,194
08-17-2020, 10:59 AM | #5 | |
69
Rep 165
08-17-2020, 11:09 AM | #6 |
1104
Rep 736
Drives: Lexus RC F
LSx swap it!
Just kidding, sorry man but good luck in your search.
Estoril Blue E36M3
Mineral Grey M235ix/12.02 @ 115 Ultra White Lexus RC F |
08-17-2020, 01:42 PM | #8 |
5585
Rep 5,386
Spun rod bearing.
These motors are stout as hell, but if you're doing sustained high G driving, they really need the revised oil pickup/pump from the N55 M2 and S55. It's all bolt-on stuff. If you're looking for a used motor, make sure to get one from an M235 as the N55 used has a forged crank. Other N55s (except the N55 in M2) have cast cranks. Everything else is the same. Make sure to outfit the replacement N55 with the upgraded oil pump system.
08-17-2020, 04:17 PM | #9 | |
69
Rep 165
08-22-2020, 12:19 AM | #10 |
69
Rep 165
Well.... rod bearings it was. The engine is salvageable which is good. Crank shaft is good.
Doing a complete rebuild with everything under the sun. New crank hub, forged pistons, coated bearings, rods, ARP studs, m2 baffled oil pan and accessories, head gasket, seals, pure stage 2 turbo upgrade, spark plugs, coils, VANOS.... I just did a new clutch at the beginning of the summer so I'm good there. Is there anything else that y'all can think of that I absolutely do? Engine mounts? |
08-22-2020, 05:04 PM | #14 |
5585
Rep 5,386
Glad to hear it's fixable. Sounds like a competent shop or tech if they're comfortable doing the work, not like the n55 is super difficult to work on. Probably goes without saying, but make sure they clean out all oil passages if there was a lot of metal generated from the rod bearing. If they don't clean areas out, it could spin another one real quick.
And no LSD with track driving? Wow. You're going to be astounded by the difference. I would put every mod penny towards an LSD. It's a different car with the LSD. Even during 5/10 driving. Believe me. |
08-27-2020, 12:25 PM | #15 | |
Rep 1
My 2015 n55 engine might be done as well.
ICY: so the way my engine went out was a small burnout but once i started moving after lowering the pedal pressure the car instantly locked up and wouldn't start roll or anything. engine stopped completely. Only the dash and front radio system would continue to work. Rear wheels also got locked up. we just checked the crank and the engine was still and wouldnt move. |
08-29-2020, 10:28 PM | #16 |
163
Rep 216
Drives: 2016 BMW M235i
Sorry to hear that man.
09-01-2020, 03:03 PM | #17 | |
73
Rep 439
Drives: 2016 M235i Xdrive 8A
SOLD 23K Black 2013 F30 335XI 8A Msport | BMS Intake | BMS Front Mount | VRSF Charge Pipe | BM3 Tune
2016 F22 M235 8A HK NBTevo | CTS HEX Intake | CTS Chargepipe | Gplus Intercooler | VRSF DP | BM3 Stage 2+ | 18" CSL Replicas | XHP X-Delete |
09-01-2020, 03:06 PM | #18 | |
73
Rep 439
Your m235 is what I want mine to be lol May I ask what size the rims and tires are? The red looks nasty on the white.
09-02-2020, 11:12 PM | #19 | ||
69
Rep 165
09-02-2020, 11:16 PM | #20 | ||
69
Rep 165
I actually found a new n55 f series baffle from a company in Europe. I just ordered it. |
